12 Pages «<101112
Another Del Prado Re-Fit Options
#221 Posted : 18 August 2014 14:00:04
Hi Alan.
Superp job on your gun port lids.
Look forward to seeimg your progress IanCool Cool BigGrin
Hans
#222 Posted : 18 August 2014 14:05:21
Good job there Alan, she already looks great and I'm sure she look fantastic when done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
Gibbo
#223 Posted : 20 August 2014 19:42:47
Hi Alan
What did you use as eyelets for your gunport lids, is that part of the etch kit or something else, i was thinking of using some very small fish-hook eyes ?
Paul
sparks
#224 Posted : 22 August 2014 22:40:51
ian smith wrote:
Hi Alan.
Hi Ian,
Thanks for your comments, much appreciated.
sparks
#225 Posted : 22 August 2014 22:41:55
Hi Hans,
sparks
#226 Posted : 22 August 2014 22:43:08
Gibbo wrote:
Hi Alan
Paul
Hi Paul,
Have sent you a PM
#227 Posted : 22 August 2014 22:45:12
Some very nice re-work taking place here. Never an easy task on a completed kit but you seem to be doing very well.
Happy modelling
sparks
#228 Posted : 22 August 2014 22:51:35
Happy modelling
Hi Tony,
Unfortunately my Victory is nowhere near finished, even though I've been doing it on and off for about 10 years Blink
But I am in the process of upgrading some of the previously completed works, and as you say, its not an easy task.
But I like a challenge BigGrin
sparks
#229 Posted : 06 November 2014 22:50:08
Hi all,
Back after another long absence, but haven't been completely idle BigGrin
Finally finished the gun port refurbishment on the starboard side. So that's all the gun ports completed. Cool
So decided to turn my attention to the channels.
As you may recall I had already made the channels and deadeyes some years back. I didn't like the idea of just gluing them to the hull edge on as there would be some tension on them when ratlines are installed. So I made some small locating pins from 0.8mm brass rod, and drilled 0.8mm holes in the rear edge of the channel. Below is the portside main channel, the brass strip at the top of the picture is basically a set square made from a piece of PE sprue so that I could glue them square to the hull sides, as every proper square I have was too large.
I fitted the three main channels, (fore, main and mizzen) to the port side and it was only when I came to fit the smaller channel aft of the mizzen, I realised there wasn't enough room to fit it between the mizzen channel and the aft most gunport where it should be.
PANIC Cursing
On further investigation I realised that I would have trouble fitting some of the chain plates on all the channels as the deadeyes clashed with some of the gunport locations.
As already mentioned, I'd made these channels years ago, I must have got the dimensions, layout etc from somewhere, I doubt I would have followed the Del Prado instructions and I definitely wouldn't have guessed it !! Upon checking drawing and plans, It became clear that the main channel was too short, and the fore and mizzen units were too long !
Only one course of action Crying
The above photo is the result of removing the fore channel, some damage to the hull and minor damage to a couple of gun port lids, the others were a similar story, nothing that can't be sorted Mellow
I must admit that the brass pin method of fixing was very good, the channels split into pieces as I was rocking and twisting them up and down with pliers trying to loosen their grip on the hull Laugh
Well, a lesson learnt, at least it will give me the opportunity to do a "making the channels" section on the build log BigGrin
#230 Posted : 06 November 2014 23:44:01
Some lovely work there Alan! Cool I know the 'do it again' feeling all too well and I also prefer to add those brass re-inforcing pins too. Theoretically the chains should 'take the strain' as in the original but theories don't seem to work very well in 1/100 scale!!BigGrin
I still have the main channels to do yet and I'll probably be using the McGowan book again for the dimensions but I might have to employ a little 'tweaking' when it comes to drilling the holes to place the deadeyes - those gun ports do crop up in the most awkward places underneath!Blink
Great work though and really nice to see you back again!Cool
Robin
sparks
#231 Posted : 07 November 2014 23:14:47
Thanks Robin,
Well, I was "working" from home today, didn't get much invoicing done BigGrin
But made a start on the new channels, so here is the work so far.
Started with some pieces of 1.5mm thick hard wood sheet that I've had since starting this build, in fact, its the material I used to make the previous,(now infamousBigGrin)set of channels, but in those days it was 1/16 inch thickLaugh . I've used it for various other projects over the years, but still have a bit left.
Using the various books and drawings I have, I converted the information to 1/100 scale, double checking I had it right this time Blushing, then marked out and cut 2 sets of channels from the pieces of hard wood I have. Each pair was then clamped together before final shaping to make sure they were pretty much identical. Below is one set of shaped channels.
Although I have marked these for the port side, at this stage they could be either.
Offering them up into position on the hull, I marked the positions of the gun ports on the channels, ports below marked on the front edge, ports above marked on the rear edge. Then, again using plans etc, set out the deadeyes on the channels, marking the centre of each one and double checking that the chain plate below or the shroud above would not conflict with the gun port openings or anything else.
Once I was happy that all was OK, I grooved out the front edge of the channel to take the deadeye strops.
I started with the starboard side fore channel as most of the books I have show a good detail of that one.
Next I fitted the strops to the walnut deadeyes and glued them in position on the channel. The largest are 5mm, then 3mm and 2mm.
I am using the PE strops from the same manufacturer that produced the gun port hinges etc, and they come with all the chain plates too.
As you can see, the very small ones need some tweaking, as this PE set was made to enhance the Heller Victory kit which I assume doesn't have the smaller deadeyes. But I can sort that out.
Then I adapted and fitted the brass edging piece that I had salvaged from the first set.
In this case, it had to be made shorter by cutting a section out and butting together, the new main channel edging will have to be extended.
Below is a photo of the old and new channels showing the difference in length. Also notice, the old one is narrower, I can only think that I did the originals from a plan view and was fooled by the projecting hammock crane platform above it.
In the detail above you can see a couple of ring hooks in use at the aft end of the channel, so they were fitted next, I also have other drawings that show additional rings on all the channels so I have added them too, even if they don't get used they will look good Cool
Finally, a couple of coats of Admiralty black paint. On the deadeys themselves, I have used ebony wood stain as its a bit thinner and, although I have already positioned the deadeyes, will allow me to rotate them easier.
Now I just have to construct the rest, and I'll be back to where I was last week LOL
#232 Posted : 08 November 2014 09:36:03
Lovely work Alan, a real credit to you.....Cool Cool
Hans
#233 Posted : 10 November 2014 11:50:50
Excellent job there Alan, most interesting tutorial. Well done. Looks great.
Rgds, Hans
#234 Posted : 10 November 2014 13:16:54
Hi Alam.
great job. nice touch with the extra ring bolts.
IasnCool Cool BigGrin
sparks
#235 Posted : 10 November 2014 19:33:47
Thanks Alan, Hans and Ian for your comments, much appreciated.
sparks
#236 Posted : 16 November 2014 22:45:46
Hi all,
Another progress report on the channels, continuing on the starboard side with the main channel. As stated earlier, this had to be made longer than the original one I did years back, and I have used 5mm and 3mm walnut deadeyes, as with the fore channel.
As with all the channels, I have salvaged the brass front edging profile and adapted it to suite the new lengths.
A feature on the main channels are the brackets for the lower main studding sail
(or stunsail) boom.
The picture above shows the boom in stowed position. When in use, it was lifted from the rear "rest" bracket and swung out on the front "hinge" bracket, 90 degrees to the hull, to form the lower spar for the main stunsail. Below is another detail drawing.
I had previously made these brackets (for my first set of channels), from copper strips bent to shape, and again have manages to salvage them for use on the new versions.
Next the ring bolts were fitted. They are made from 0.7 X 10mm brass eyelets cut down in length. On my first set, I only used the eyelets, but this time around I have added 3mm brass rings to make them more realistic.
Having to make this second set has allowed me to improve on the originals.
Checking drawings and plans, it seems the deadeyes on the mizzen channels are slightly smaller than the largest (5mm) ones on the fore and main channels. Originally, I used 5mm for these too, as I could not find (or they were not made then) 4mm deadeyes, and I didn't want to drop as low as 3mm. This time however, I've located some 4mm ones, and used them for the new mizzen channels.
Finally (at last I hear you say Laugh )we come to the two small auxiliary channels that sit aft and above the main and mizzen channels. For these I have use 3mm and 2mm deadeyes.
Below is the finished starboard channel set.
I have also completed the port side channels and will return with another update when I have them fitted to the hull.
#237 Posted : 16 November 2014 22:53:52
Lovely work Alan....
#238 Posted : 16 November 2014 23:53:16
sparks
#239 Posted : 20 November 2014 22:32:50
Thanks Alan and Steve for your comments.
Much appreciated.
sparks
#240 Posted : 09 December 2014 22:07:06
Hi all,
Due to family and other commitments, I doubt that I will be doing much on the build over the festive season, so just a short note to wish you all
A VERY MERRY CHRISTMAS AND A HAPPY NEW YEAR
Thanks for all your comments and encouragement over the past year.
Kind regards
Guest (9)
12 Pages «<101112
This page was generated in 0.203 seconds.
