Joined: 19/06/2014 Posts: 79 Points: 219 Location: Doncaster
Does anyone know which dampers to upgrade to, as one of the stock dampers keeps popping open when installing spring.
prefer aluminium dampers to standard plastic.
Joined: 05/04/2013 Posts: 540 Points: 1,630 Location: England
I have no problems with the supplied shocks but if you want to upgrade it should not be too difficult to find a 1:8 buggy shock kit which will fit nicely. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
was looking at integy dampers, still undecided which set.
using kyosho 1/8 inferno gt2 ve race spec dampers
Nice! I think the hummer chassis is based on the inferno. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
