1/24 Monogram Packard Diecast kit Options
kpnuts
#1 Posted : 18 August 2014 20:33:48
Hi all here is my next project. I won it off ebay, never don a diecast kit before
How do I go about cleaning the corrosion and flash off it and do I need to prepare the metal in anyway before I spray it.
#2 Posted : 18 August 2014 21:00:27
Looking forward to this one KP! A very unusual kit but very nice too Cool
Spencer
#3 Posted : 18 August 2014 21:13:36
Kp
This is something different.
Looking forward to seeing how you get along with this one.
It looks a ( and no criticism intended) very dated kit and I would think something very special. Never knew Revell produced anything like this.
Bet you will be able to get a lovely paint finish on this.
Lots of luck with your build.
Happy modelling
kpnuts
#4 Posted : 18 August 2014 21:25:12
Yes I think it's been stored somewhere damp as there is a lot of corrosion on the metal parts.
kpnuts
#5 Posted : 21 August 2014 20:53:38
Hi all well I've started cleaning the bodywork, getting rid of the flash and checking the fit, I think I have a lot of work where that is concerned its a terrible fit
anyway I sprayed the engine black as per the instructions.
then I thought I would do some research as I want to do a good job of it and discovered the engine has no black in it, it's silver and green
so thats where I am now, looking to find what I can use for the ht leads from the spark plugs.
kpnuts
#6 Posted : 22 August 2014 21:03:55
Well I've done some weathering on the engine, I am aiming to make this as realistic as i can (so dont expect too much)
I thought I would start the weathering the engine before I put all the other bits on as it wont be so easy to get at once they are on.
kpnuts
#7 Posted : 24 August 2014 19:00:26
Hi all well here is tonight's episode
I've made a start on the base too it's going to be a garage
kpnuts
#8 Posted : 25 August 2014 18:34:02
Hi all here is tonights episode.
I drilled out the distributor so I could put the HT leads in.
then I made the HT leads out of thin solder wire.
Then I cut them to length and squished the ends to make the tabs to connect them to the spark plugs.
Then I noticed from the ref photos I have that there are rivets and badges on the starter motor and solinoid so I added them.
still loads of detail to add to the engine bay, got an idea for making the jubilie clips for the radiator hoses and I am going to attempt to make the fuel pump and assossiated pipes as they are only vaugley moulded into the firewall.
kpnuts
#9 Posted : 27 August 2014 21:20:59
Hi all here is tonight's installment, done nothing to the car but got a fair amount done on the garage lift.
#10 Posted : 27 August 2014 21:37:19
KP
Coming along a treat.
Think the garage display is a very good idea and what you have made so far looks excellant.
Happy modelling
kpnuts
#11 Posted : 30 August 2014 19:39:03
Thanks Tony. Well I've got the under coat and the first top coat on the Packard now.
#12 Posted : 30 August 2014 20:03:54
Very nice finish on you paint work!!
#13 Posted : 30 August 2014 20:46:48
KP
That really is a beautiful finish you have on that paintwork.
The raw metal kit did look a little worse for wear so not sure how much cleaning up you had to do but either way a well smooth finish to your paint coats.
Very well done.
Happy modelling
kpnuts
#14 Posted : 30 August 2014 20:47:50
The finish is not that great actually the grill is going to need a lot of work, I was hoping the corrosion would not show with a coat of paint but it does. The trouble is its such a detailed area sanding the corrosion out without sanding detail out is going to be a real nightmare.
kpnuts
#15 Posted : 31 August 2014 18:41:22
Here is todays progress on the Packard
#16 Posted : 31 August 2014 19:05:53
KP
Looks good to me from the pictures you have posted.
Not much further to go now before you end up with a cracker of a build.
Happy modelling
kpnuts
#17 Posted : 31 August 2014 20:44:20
Thanks Tony I have managed to sort the bodywork out.
#18 Posted : 31 August 2014 21:28:41
kpnuts
#19 Posted : 01 September 2014 20:37:32
Here is todays bit on the packard. the fuel pump and filter are not included with the kit so I decided to have a go at making them.
and I had a go at making the seats look like old cracked leather(quite unsuccessfully) any suggestions ?
kpnuts
#20 Posted : 03 September 2014 20:58:06
Hi all here is todays hard graft.
This page was generated in 0.439 seconds.
