32 Pages «<89101112>»
tf64 Spitfire Build Options
mark 2
#181 Posted : 17 August 2014 20:15:32
Hi Trev BigGrin .
Thanks for the profesional way you have set it out. Fantastic.
Great looking build and coming on well.
Best regards.
#182 Posted : 18 August 2014 08:46:47
Hi Tony,
Thanks for looking in, all going well, but I am holding back on the cockpit until I see which way De-Ago have built it. Looking forward to seeing your Adler Diary.
Trev.
#183 Posted : 18 August 2014 08:52:44
Hi Mark,
Thank you for looking in and your comments good to hear from you.
Trev
ps: Have you seen all the reduced modelling kit's and paints in the old Allders store Croydon, have a look.
#184 Posted : 30 August 2014 22:01:21
UPDATE:SPITFIRE.STAGE 13.
Hi all,
Received today Pack 13 look's like I will be very busy this month, this is what we have, for some reason in my pack I have issue 48 from pack 12 ?
Pack 12
Issue 48.
1 Engine Side
2 Engine parts fret.
Pack 13
Issue 49.
1 fuselage Reinforcement fret.
2 Wooden Strips 2x5x300 mm.
Pack 13
Issue 50.
1 Frame 12
1 Frame 13
1 Frame 14
Pack 13
Issue 51.
1 Frame 15
2 Reinforcements
3 Reinforcements
That's all for pack 13 I will post as soon as I have built pack 13.
Trev.
#185 Posted : 30 August 2014 22:53:00
Look forward to seeing your progress with part 13 Trev....
#186 Posted : 02 September 2014 21:04:49
Hi Alan,
Thanks for looking,
Trev.
#187 Posted : 02 September 2014 22:10:12
UPDATE:ENGINE SIDES.
Very ease to assemble but in my build a tricky part towards the end.
After gluing one engine side to the back plate and squaring up and test fitting to the airframe all ok and leave to set for 24hr.
Try to Airframe.
Next I removed the engine front and side from fret also the centre hole, then I smooth and sanded all fret parts, test fitted the front frame with engine sides all ok, this is the bit were you only stick one side of the engine front but check for square, I choose not stick the engine front at this stage but preferred to wait.
Next was to dry fit engine formers 12/13/14/ with only one engine side glued it left me free to try/ place /and /adjust the remaining this became tricky to hold together, but clearly I could see that it was not square towards the front? (it all seemed squared to me) The only way I could see was to file a bit out of the side slots which I did, ( this is why I didn't glue it) the only problem now is you need 6 pairs of hands to glue it all at once, but it worked.
Can you see in this shot how the formers lean forward these are not glued at this stage.
This shot shows how I assembled it with out the engine front to me this means I can still adjust.
This shot shows the use of elastic bands to shape in the front section.
This shot shows the engine front in place and clamped to the Airframe.
That's it for now more soon,
Trev.
The next few shots show how I got on.
#188 Posted : 06 September 2014 19:51:20
UPDATE:ENGINE COMPARTMENT.
The last few pictures were the first stage assemble of the engine compartment, this stage I am assembling the upper reinforcements struts. This I found not bad to do as all the joints lined up and kept square, the only one I had to adjust was a front nose former but I am sure it was me as you will see in the pictures.
This picture show's the top struts, top struts (rear) reinforcements, and front nose reinforcements.
This picture show's the longer reinforcements/the shorter (rear) reinforcements.(this photo is a bit blurred sorry)
This picture show's the nose formers in line A/B/C just a point to look put for A former has a flat top.
The last two pictures are as far as I can go until I receive my next post.
All the pictures today are of the underside of the nose/engine compartment.
Thank you for looking.
Trev.
#189 Posted : 06 September 2014 20:07:29
Hi Trev, BigGrin BigGrin
Steady progress and to the usual high standard.Cool Cool
Looks like a lot of parts in a small space, did you have "any" problems with getting everything lined up to complete this part of the build and if so, any hints or tips to cure the issues.
This is surely a build diary to be followed by anyone wishing to start the SPITFIRE build.
WTG
Happy Building
dandare
#190 Posted : 06 September 2014 20:37:36
great work as usual Trev
loving it
Dan
#191 Posted : 06 September 2014 21:04:36
A nice clean build Trev Cool and it's starting to all come together now Drool
Spencer
#192 Posted : 06 September 2014 21:13:45
BigGrin Nice work TrevCool
#193 Posted : 06 September 2014 21:22:11
#194 Posted : 06 September 2014 22:39:41
Just catching up on this, guid is looking really good.
#195 Posted : 06 September 2014 23:06:16
Fab work Trev, looking to be a very solid build and a build set to a very high standard..... Cool Cool .. Very well done....
Ponty
#196 Posted : 07 September 2014 05:32:09
Build is fantasticLove
#197 Posted : 07 September 2014 10:38:59
Trev
Some nimble fingers being used on this area I can see.
You have managed a very clean finish to this area - looks a very good job indeed.
#198 Posted : 07 September 2014 11:56:18
Hi Derek,
Thank you for looking, Derek I must say that this kit just fall's together as you will find when you start yours.
The only problem I had was at the front end and that was small, the part was the small reinforcement strut which joins the front engine former and to be fair I think it was down to me, I did notice it before it set,but at the time I tried to move it but I could clearly see it would cause damage, I did dry fit this section and all seemed ok, so I can only think I must have moved it, so the only way was to file it back.
Trev.
#199 Posted : 07 September 2014 11:58:03
Hello Dan,
Thanks for looking in, great job on the Zero.
Trev.
#200 Posted : 07 September 2014 12:03:02
Hi Spencer,
Thanks for your time, and to look at what I am up to, as you say it is just starting to look a bit like a Spitfire, and that's the exciting bit when you stand back and look and think yes (that's worth while).
Trev.
This page was generated in 0.365 seconds.
