Differential Movement Options
""J""
#1 Posted : 18 August 2014 00:20:58
Rank: Amateur level 2
Hello,
I have just finished the differential on my RB7, but I'm a little concerned about the movement it has on one of the output shafts.
One side is tight against the gears but the other has a few mm of movement. Also you can feel the gears as you turn the shaft properly. Its smooth but you can feel them.
I've never built one or had a differential before so I just wanted to ask on here about it. It might just be normal lol
Here's a bad quality video showing the movement.
#2 Posted : 18 August 2014 08:45:43
Movement on both sides should be about the same, though as its unused it will feel a little tight. Have you disassembled?
""J""
#3 Posted : 18 August 2014 22:08:33
Yes I took it apart and cleaned out the grease then reassembled, but its exactly the same.
Have you watched the video ? Does it look ok ?
This page was generated in 0.087 seconds.
