Dual Monitors Options
Allan
#1 Posted : 16 August 2010 08:51:42
Can anyone tell me how to set up 2 monitors on one computer i am using WIN XP with a radeon graphics card which has 2 outputs for monitors??????
Allan
#2 Posted : 16 August 2010 09:02:54
go to your graphics control centre,you set them up there,if you hav'nt got the control centre, download the lastest drivers from their site (sapphire,radion.)that will give you the software to connect two monitors.
Allan
#3 Posted : 16 August 2010 09:20:52
Thanks for that i will give it a tryBigGrin BigGrin BigGrin BigGrin BigGrin
#4 Posted : 16 August 2010 10:00:18
Best bet for driver is hereAmd game catalyst. You have option once installed to clone screen or extend screen. Just play around with it til you find the right settings.. BigGrin BigGrin BigGrin
secretreeve
#5 Posted : 17 August 2010 09:19:25
as said, use the latest drivers to do it and go into the display menu in control panel.
welcome to the multiscreen world tho. i have 3 running and can stream to the tv all at same time hehehe
piot007
#6 Posted : 17 August 2010 09:40:56
Dont mess with the position of your monitors once they are on your desk. Just drag and drop the main screen to which ever side you want. Then extend to this screen or click this is my main screen.
I had probs with this as my main screen is on the right side of the left one, which is my extended desktop screen.
Do this by right clicking on desktop and choose the personalise option. this should take you to the right page, it also has resolution settings on this page as a clue.
Finally you should restart your pc then just check that nvidia/ati control panel has picked it up.
I think what im trying to say is, do it via Windows XP first. NOT the flakey graphics drivers.
Good luck
secretreeve
#7 Posted : 17 August 2010 10:00:14
this is all assuming its not 2 crt monitors of course haha.
i remember double screening 2 of them and wow i got a head ache.
anyhooos if your running each via seperate cards you may find it a little easier. you didnt give much system congif info so we are mostly guessing at your setup being a standard one
