Joined: 05/04/2013 Posts: 540 Points: 1,630 Location: England
Hi guys here is my build so far. I have skipped the initial parts and started building the body first. I decided to paint my model gloss yellow. Building and painting the body.Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
Nice work and congrat's on your first medal
Thanks. The paints I have used are Tamiya Grey Primer Tamiya TS-47 Chrome Yellow Tamiya TS Satin Black Now to work on the chassis :D Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
 Nice work Kenjara, the yellow reminds me of the old cadmium yellows Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Here is an update on my Hummer Build. The body is nearly finished. Most of the little details have been added. I have painted and added the main lights. Just the side lights left to go. (See attached photos) More info on my blog. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
kenjara wrote:Here is an update on my Hummer Build.
Looks superb Kenjara, lovely work...  .. Have just been onto your website and think you have an impressive and interesting collection of builds there.... Will drop in from time to time... well done.... Regards Alan
Thank you :) Here I have some photos of the completed Hummer body.     I need to get some better ones on a sunny day. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
Joined: 04/06/2010 Posts: 332 Points: 1,000 Location: Bannockburn
Hi Kenjara,
Looking very good - I'm almost at the same stage adding the lights to the body.
Did you do as suggested at the end of stage 52 and lacquer the body? I've just ordered some Humbrol gloss but still undecided if I should do it.
Graham
Yes I did, although I covered any stickers prior to spraying it. You will also need to cover the front headlights. This is not mentioned in the instructions but failure to do so will make them go foggy. Its fine to spray the paint onto painted clear plastic but spraying directly onto clear plastic will cause fogginess. I first learned this when accidentally varnishing a planes cockpit. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
kenjara wrote:Yes I did, although I covered any stickers prior to spraying it. You will also need to cover the front headlights. This is not mentioned in the instructions but failure to do so will make them go foggy. Its fine to spray the paint onto painted clear plastic but spraying directly onto clear plastic will cause fogginess. I first learned this when accidentally varnishing a planes cockpit. Thanks for the tip I would definitely have fallen into that one Graham
Last night I finished my Hummer! Now I just need to wait for a rain free evening to break it in. Attaching the piston  Attached the exhaust  The complete chassis  A peek inside  Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
Looks really good, you have done a fantastic job.
Hope you get a dry evening
Looks good, like the colour Al
Looks great - good luck with the first run Steve
Thanks guys! Got it up and running no troubles as you can see in my video. YouTube linkFinished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
Think you have done a fab job on your Hummer,,, very well done.... Regards Alan
Thanks Gandale! Had to amend the idle needle a little as it was way too high. I used the old hair dryer trick to get it up and running initially as it was so cold. The initial settings for the transmitter throttle were by default back to front. This meant when I tried to apply the brake it revved up initially which gave me a surprise. This was easily fixed by reversing the throttle using the switch on the top of the transmitter. Finished 3D Printer, RB7, Hummer, Skyrider drone & Combat tank collection http://www.model-space.com/gb/
Well done and congrat's on receiving your completed build medal.
Have fun
