27 Pages «<2021222324>»
George1 Build Options
George1
#421 Posted : 02 August 2014 03:49:08
John Passmore wrote:
Hi George
Your planking is looking really good and way ahead of mine, which is good because I can pick your brain.BigGrin
I have 8 bottom planks in (4 each side) and having a bit of trouble keeping the plank stuck flat at the very end of the keel. I pin nail it and clamp it flat against the keel for at least 24 hours after gluing, but when I remove the clamp, the plank gradually lifts up one edge. I know it's caused by the 90deg twist in the plank, so did you have the same problem?Confused Confused
I've tried soaking and steam ironing the plank as well as cutting lots of grooves in it. Can you advise how you overcame this problem?
The keel planking on your model looks terrific...BigGrin BigGrin
JohnP
Hi John. BigGrin
First thanks for your compliments they are appreciated mate. Cool Cool
Re your problem. First up I'd say by your description of what's happening re springy planks you need to re-check the glue you're using. After 24 hours and with clamps and still pops tells me it's not much chop. I use PVA ( Selley's Aquadhere, Quick set, Interior). With that PVA you don't need clamps if straight work edge to edge, but with what we have to do re modelling planks I certainly do clamp it.BigGrin
While you obviously put plenty of glue on where plank is going then onto stern just ensure a reasonable amount of glue goes on that stern piece so when you clamp the plank at the end it will force the twist flat and have plenty of glue to hold if you have right glue. Don't clamp too far in later when you get down to start of ribs or will make a depression if front of rib. While you can clamp in further re the first four/five planks I clamp in around 10 mm plus from end of stern once the ribs come into play. With the glue I've described I can unclamp in 8 hours without any lifting.BigGrin
I really hope that helps you John. I can't see any other reason than poor glue to cause the problem. You'll need better glue when you get lower as even more pressure as those ribs come into play.BigGrin
George
Building HMS SOTS
John Passmore
#422 Posted : 02 August 2014 05:25:28
Hi George
Yes I'm using Selleys Aquadhere Interior PVA (red top) but I've now got some Exterior (blue top) to see how that goesCool Maybe I should slap it on a bit thicker!...BigGrin
I'll post a pic on my thread.
JohnP
George1
#423 Posted : 02 August 2014 05:36:33
Hi George
JohnP
Hi John. BigGrin
Well if you're using same glue then as you say you might need to put on heavier. Just wipe away the run off after clamping the plank if putting a lot on causes such. Maybe the blue top exterior might be more powerful, I don't really know never having a problem re the red top.Confused
Just a small help if I may while you're doing the stern and that is when cutting off overhang later ensure you leave 2 mm overhang as stern post goes into that groove later so requires that 2 mm overhang. BigGrin
Will check your thread when you post pics. BigGrin
George
Building HMS SOTS
George1
#424 Posted : 04 August 2014 05:03:19
First results from blackening trial anodized material.BigGrin
Still bright parts where held in pliers for trial.Eyelet needs further work. Mellow
Method used because heat important was to hold with pliers and heat with cigarette lighter then while hot spray with isopropyl then rinse in water pat dry then heat up again and drop into burnisher.BigGrin
These results are only after ten minutes in burnisher. Leaving longer may improve. BigGrin
Will need to look at different heat method for 100% coverage without bright parts like cannon barrel supports need to look black overall. Eyelets OK so long as eyelet black rest hidden. Wire being steel blackens easily without problems. BigGrin
George
Building HMS SOTS
#425 Posted : 04 August 2014 19:12:35
Hi George, looks like success to me.... You like to try putting the piece into boiling water for a few minutes after cleaning. From the boiling water straight into the burnishing solution... I've done that a couple of times and been quite successful with it.... Cool Cool
George1
#426 Posted : 05 August 2014 02:08:46
Hi Alan. BigGrin
I will try your suggestion re the boiling water. It sounds the go to overcome the need for the pliers. Cool Cool
It was the cannon supports that I could see needed not to be held by pliers as it would leave bight parts not able to be hidden. In a way while I do understand some modellers would be happy with the brass look re the fittings it's a pity the fittings were anodized and not just plain metal as then burnishing would be a breeze. BigGrin
I have got a URL saved where the guy shows how to make the parts by using metal wire and flat strip. Apparently very handy for hook eyelets in the rigging. However I obviously hoped to do it with the fittings as supplied re the cannons. BigGrin
George.
Building HMS SOTS
#427 Posted : 07 August 2014 19:46:00
Hi Alan. BigGrin
George.
Hi George, I've just burnished some chains for the chainwales using Krick and the method I've already outlined, must say I'm happy with the results...
I would advise anybody to use the parts provided and not make any changes unless they are confident in their ability and knowledge... That said, I did make changes to my build and to some of the supplied parts but at the same time I was willing to take the risk and have a go.... Have to say now I'm pleased with how things have turned out so far.... Down to each individual builder to put their kit together the way they wish but I would advise caution....
Look forward to seeing more from your build....
George1
#428 Posted : 08 August 2014 02:48:40
Hi Alan. BigGrin
Thanks for looking in and your advice is always welcome and always noted. Cool Cool
I'm a little disappointed at the momentCrying as our issue 22 only had two cannons within and nothing else. No planking which I was really waiting on having checked out "Your Build" at the stage (Stern/Transom supports for planks I already made shaped and glued ready.)and "Tomick's Official Build" all ready to go as soon as issue in my hands. So it was quite a shock just to see two tiny cannons only with the mag especially as not required re the build for over 100 issues at least and expecting planking re official issues 21-25. Although rechecking Official Build does show 2 cannons issue 22.Blink BigGrin
OK, I've had my moan Laugh so will use up time now waiting on planks in next issue for burnishing the brass ware cannon fittings. BigGrin
George.
Building HMS SOTS
fredsmit
#429 Posted : 10 August 2014 04:32:23
Nice work George, especially your planking. I just hope I can get mine to that standard.
I had a look at Tomicks build diary last night, looks like a few future issues coming with only two cannons. Not too many I hope. I might get bored and actually read the magazine ;)
Current Builds:
Sovereign of the Seas
The Black Pearl
Amati Adventure Pirate Ship
George1
#430 Posted : 11 August 2014 03:27:52
Hi Fred. BigGrin
Thanks for looking in and your kind comment. It is appreciated. Cool Cool
Looking at what you have done so far I don't think you'll have any problems with the planking. Like some have said prior they found it much easier than planking the launch.BigGrin
As far as issues with cannons in them I don't intend to make the cannons up each time as then they have to be stored away which is a nuisance so other than the burnishing of the anodized fittings and then putting back in plastic packs the cannon carriers can stay in their flat packs till I'm ready. They are easy enough to put together so I'll do a number of them at one time. BigGrin
Roll on Thursday re issue 23 and more planks this time. Laugh
George
Building HMS SOTS
mark 2
#431 Posted : 11 August 2014 07:10:35
Hi George.
Your planking looks fantastic Love Cool .
Keep up the great work and i look forward to seeing more BigGrin .
Best regards.
John Passmore
#432 Posted : 11 August 2014 08:46:48
George
G'day George
That's useful info there mate - thanks very much for posting...BigGrin
I've got some isopropyl but having trouble sourcing burnishing fluid. Would you let me know where you obtained yours?...Looks like another trip to Perth for me....BigGrin
JohnP
jonny7england
#433 Posted : 11 August 2014 16:12:07
You've been doing a great job there George..Well done mate!! Wink ThumpUp
#434 Posted : 11 August 2014 17:00:02
Hi George, looking goodBigGrin
I did notice though that the test eyelet is a little crusty and corroded. I did have this happen to some of mine and found it was down to not washing the solution off straight after in cold water, then dry the parts.
The parts really only need to be in the solution for 30-60 secs, any blackening achieved after this time will only rub off anyway. The parts I blackened came out with a satin coat a little like gun bluing. BTW, I used a product called "Blacken-it" so I guess they may all have different properties.
George1
#435 Posted : 12 August 2014 02:22:27
mark 2 wrote:
Hi George.
Best regards.
Hi Mark. BigGrin
Thanks for looking in and your very kind comments. Greatly appreciated. Cool Cool
More once planks arrive. BigGrin
George
Building HMS SOTS
George1
#436 Posted : 12 August 2014 02:28:16
George
G'day George
JohnP
Hi John. BigGrin
If you look back in re the "Burnisher" query, you can get from most gun shops. I'm using one that says "Brass Blackener" on label but there are other types probably as good. My Son picked up for me. (Gun Shop In Midland, Great Eastern Highway)Don't know name but look in yellow pages and you should find. BigGrin
George.
Building HMS SOTS
George1
#437 Posted : 12 August 2014 02:30:39
Hi Jonny. BigGrin
Thanks for looking in and your kind comments. They are as always greatly appreciated. Cool Cool
I'm slowly getting there. BigGrin
George
Building HMS SOTS
George1
#438 Posted : 12 August 2014 02:39:05
Hi Steve. BigGrin
Really appreciate you looking in and your tip and comments on burnishing.
Cool Cool
I'm using a burnisher called "Brass Blackener" from a gun shop. I think they are all much the same by the sounds of it.BigGrin
Yes re the (Crusty Bits) I could see the little bits of anodizing falling off in the burnisher after treatment re the isopropyl especially while still hot. BigGrin
Just a matter of getting more proficient with the outcomes. BigGrin
George
Building HMS SOTS
John Passmore
#439 Posted : 16 August 2014 06:31:59
G'day George
Finally got hold of some blackeninig fluid from a gun shop in Maddington. Sure enough it's called Gun Blue but actually leaves a nice smooth satiny finish as described by Stevie-o, black or bluey tinge depending on how light shines on it...BigGrin
Got Issue 23 this week (not the missing Issue 21)...Huh The newsagent doesn't know how long before we see issue 21 so I'll just have to use issue 23 and rely on Mr T's narrative from issue 21, hope there will be enough planks if it transpires issue 21 is a permanent non-shower...Huh
JohnP
#440 Posted : 16 August 2014 09:55:34
G'day George
JohnP
Hi George/John,
Hope issue 21 shows up for you soon.. I can say however, that on completion of the first layer of planking I had a stack of bamboo planks left over, so even if 21 is a no show you should still have enough to complete the hull, providing of course you are not wastefull with the strips..... Hope this puts your mind at ease.... Cool Cool
This page was generated in 0.508 seconds.
