duff nails Options
secretreeve
#1 Posted : 13 August 2010 19:57:20
anyone else have the issue of nails with no....stab no them? got a small bag of them in issue 17 and half of them are completely usefull.
is there anymore bags on nails earlier in series or more to come?
Jack Sparrow
#2 Posted : 13 August 2010 20:02:57
Just had a look at mine and they seem ok, but also bought enough for Pearl and Vic as the ones from Pearl were more like shovels than nailsFlapper BigGrin so I bought LOADS just in case!!!BigGrin Cool BigGrin
doremi495
#3 Posted : 13 August 2010 20:28:43
You get a big bag of nails with Issue 20
Dave H
Current builds :- Hachette 1/16 Tiger Tank
H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
secretreeve
#4 Posted : 13 August 2010 20:53:41
20 huh? big bag you say?
good good glad to hear it. because i've had to ash tray about 15 or so nails that are dead ended. no point on them at all. so hopefully there will be pleanty of extra nails in the bag.
axle396
#5 Posted : 13 August 2010 21:15:33
Hi Guys,
I wouldn't be too quick to bin your blunt nails as they do have their uses. Whilst sharp nails are much easier to position and hammer in, they also have a tendency to split wood as the sharp point causes the wood fibre to part. Blunt nails on the other hand tear through wood fibre and are much less likely to split the wood. This is more especially so of tight grained hardwoods. Pre driiling holes where possible is also a good idea. I intend to do this with the deck panels to make sure the nails go exactly where I want them to.
Jimmy L.
current builds : Lancaster 1/32 (Hachette)
Revell USS Kearsarge
Titanic Lifeboat
I started off with nothing and I've still got most of it left.
secretreeve
#6 Posted : 13 August 2010 21:56:50
damn, considering the amount of wood work i do i should have known this!
im building a wardrobe from raw materials, big beggar of a beast too, 10 draws 2 wardrobes top double shelf storage area and an area for a big 27" crt tv. mirrored doors and so forth, got all the framework built but no its costly to panel it atm.
so point is i should have known bout usage of duff nails...thanks for reminding us all though axle, defo appreciate it
benny
#7 Posted : 13 August 2010 23:31:07
just received my latest issues..the victory is decked and nailed without and probs every nail went in without a hitch,so glad the build is now looking like a build
cheers benny
piot007
#8 Posted : 15 August 2010 05:56:20
axle396 wrote:
Hi Guys,
Good advice there. Thanks.
CMB
#9 Posted : 15 August 2010 14:22:40
Me also.
40% of the pins supplied were unusable.Cursing
piot007
#10 Posted : 15 August 2010 14:54:24
Could we file them into to useful ones then? Or would that be a bad idea. Flapper
jonny7england
#11 Posted : 15 August 2010 16:57:44
I was just putting the lower deck on today and found that a number of nails had their sharp ends missing...I should imagine that it was down to their mass production...but don't throw them away as they can be used in various stages of this build, such as, if you need to strengthen or re-enforce a particular join...I always drill a small hole in both parts and insert the duff nail in both parts and put together with super glue makes one heck of a strong join...BigGrin
piot007
#12 Posted : 16 August 2010 08:26:43
That is a better idea. You can drill in the centre of the rib alot more accuratley than blindly or follow marks left on the rib. Then super glue of you choice.
Im doin thatBigGrin BigGrin
This page was generated in 0.113 seconds.
