 Rank: Pro  Groups: Registered
Joined: 02/10/2013 Posts: 125 Points: 380 Location: brisbane (Australia)
Can any 1 tell me the scale size of the black pearl nothing apart from cm is indicated Supaheli
The figures supplied are around 40mm tall so that would say this build is based at around the 1/48 - 1/50 mark Steve
So now thats sorted I intend to use other wood rather than mdf (but will still keep it if needed else where) what is the most used wood for a ship of this scale (what ship modelers use) Im guessing 2 or 3 different types tho... any help on this will be appreciated Supaheli
Normally plywood for the frames, basswood for anything that needs carving or shaping and lime for planking. Walnut can also be used and this will give you a nice darkwood contrast where needed. I also intend to use Tanganyika for the decking instead of the cardboard Steve
So I take it that being 1/48-1/50 is really really big... bigger than the rb7 I dont think ill have the room for something this huge...as it is ill be struggling to find a spot for the rb7 Supaheli
You gave the impression in your first post that you were already aware of the dimensions of the kit, it was just the scale you were unsure of? Steve
Hi Supaheli I'm not building the Black Pearl myself, still working on the DeAg Victory. Being as the 'pearl' is a part-work, I would have thought that somewhere in the first few pages there would be a mention of the physical size of her. (With the 'Vic' part-work, issue #1 came with a supplement which gave a brief overview of the build including the scale and physical dimensions of the finished build.) As the Black pearl is only a galleon derived from a fantasy film and not a 'real' ship, I would say that giving it a 'correct' scale would be nigh on impossible - only a 'near enough' scale would have been implemented by the manufacturer of the part-work, again depending on the final physical size of the model. Happy building David
stevie_o wrote:You gave the impression in your first post that you were already aware of the dimensions of the kit, it was just the scale you were unsure of? Steve yes...why I ask is that ive seen other model ships that have a scale size and not by a dimension...and why I asked for a scale size is to ask you or others if white oak can be used seeing that the scale size is bigger than 1/25 Supaheli
daffy09 wrote:Hi Supaheli I'm not building the Black Pearl myself, still working on the DeAg Victory. Being as the 'pearl' is a part-work, I would have thought that somewhere in the first few pages there would be a mention of the physical size of her. (With the 'Vic' part-work, issue #1 came with a supplement which gave a brief overview of the build including the scale and physical dimensions of the finished build.) As the Black pearl is only a galleon derived from a fantasy film and not a 'real' ship, I would say that giving it a 'correct' scale would be nigh on impossible - only a 'near enough' scale would have been implemented by the manufacturer of the part-work, again depending on the final physical size of the model. Happy building David oh ok... seeing that this is my first ever ship build im trying to ask as many questions so I can to take the right path when the time comes to build it or to start to build it...im not trying to ask stupid questions either. If ship building was as easy as rc cars I wouldnt have any problems or ask for help Supaheli
Supaheli wrote:stevie_o wrote:You gave the impression in your first post that you were already aware of the dimensions of the kit, it was just the scale you were unsure of? Steve yes...why I ask is that ive seen other model ships that have a scale size and not by a dimension...and why I asked for a scale size is to ask you or others if white oak can be used seeing that the scale size is bigger than 1/25 OK, the size is stated on the website and on the cover of the mags too - it's 80cm in length total. The scale is approximate for the exact reason stated by Daffy, in that the ship is fictional so no real size to work from. However, as I mentioned the figures supplied are 40mm tall, so as far as these go the ship is based on the 1/48 to 1/50, so the scale is actually smaller than 1/25 not bigger. Steve
Lol...oops yea I just caught that 1 thanks for ya replys which is always taken into account and helpful Supaheli
Hi again Supaheli Not a stupid question, in fact nothing on here is a stupid question. We're all in this together friend and sometimes the 'stupid' questions can turn out out to be very interesting and intriguing ones and supply lots of answers to builders who may not have even thought of the question. Carry on asking Happy building David
