13 Pages «<23456>»
Hachette's 1:16 Tiger Tank Options
#61 Posted : 20 May 2013 20:48:11
Hi Daran,
Firstly, there`s some stunning work there and secondly I think huge is an understatementDrool Drool Drool .
Just how big does the finished item end up, think you may need a bigger work table for the final assemblyLOL LOL LOL .
#62 Posted : 20 May 2013 20:58:24
delboy271155 wrote:
Hi Daran,
Hi Derek, thanks for looking in. Your right about the work bench, and I think I need to re think my display options!!!LOL LOL LOL
#63 Posted : 20 May 2013 22:52:51
Turret basket under way.
SennaMentalMe
#64 Posted : 20 May 2013 23:14:19
Looking great Daran, certainly making headway on this build and that Schumo barrel was well worth the effort!! CoolThumpUp
Will you be adding any 1:16 crew to this my friend? Drool
P.S. - Could you update your question in the Formula One quiz please - there's a good chap!?
Kev BigGrin
#65 Posted : 20 May 2013 23:34:55
Hi KevBigGrin and thanks for looking in. Yes the barrel has certainly made all the difference to the look of the turret!BigGrin BigGrin
#66 Posted : 28 May 2013 21:13:14
I have assembled the lower hull so I can get an Idea for painting.The complete Engine bay and lower front hull up to the sponsons is red oxide, then elfenbein from there up in the fighting compartment. The instructions are way off, telling you to paint the interior hull the same as the outer!! WRONG!!LOL LOL These pics also give you an idea of the size, my cutting mat is 28cm X 43cm.
#67 Posted : 28 May 2013 23:07:34
BigGrin Hi Nem
Very Nice work there as for the painting instructions try the Fargestal a pic with some references to gunze colours with some random arrows pointing in the models directionLOL , no paint list at all in the instructionsConfused at least hatchet gave you a colour to paint even though it was wrongCrying
SennaMentalMe
#68 Posted : 28 May 2013 23:30:01
Great work as always Daran and very interesting to read the discussion on colour! Keep the updates coming mate. CoolThumpUp
Kev BigGrin
NMBROOK
#69 Posted : 28 May 2013 23:39:22
Hi Kev
I have just had a read through you diary and I have to say outstanding work.I find it surprising though that Hachete went to so much expense, tooling up for that lovely cast metal turret and then ruin it by supplying that awful barrel.
Kind Regards Nigel
#70 Posted : 29 May 2013 10:19:15
Really starting to come together and so refreshing to see somebody get the interior paint correct!! Cool
J
Wilfy the Sea Dog
#71 Posted : 30 May 2013 02:32:21
Nemesis wrote:
Hi Wilfy, thanks for looking in and your comments!BigGrin BigGrin
For the breech block I did this:-
1. Cut some plasticard to block off the three sides of the inner breech. I made them taller than the breech to make them easier to stick in place, and its easy to trim them level.Make sure they are a perfect fit so there are no gaps. Once dry, trim them to the level of the top of the breech.
2. Now cut a small piece to make the curve in the top of the breech block. If you warm it and form it round a brush handle its easier to fit. Its trial and error on this, so make it to long and then trim it till it looks similar to mine. Once your happy with the shape, glue it in place.
3. Cut another piece the same as the back of the breech block and close in the front. Again make sure its a perfect fit. dont worry about the shape as yet, its easier to do last.
4. The front of the loading breech is all one piece. Cut a square just big enough that it over hangs the front and top, and butts up tight with no gaps against the main breech. Once you happy with the fit glue one side only to the middle of the curve, and then using a cylinder the same bore, insert it so that it pushes the card into the keyhole shape. When dry using a thick needle, apply the glue to the other side, you should be able to pull the card away enough to get the glue in. Than use the cylinder again to form the card to the keyhole shape.
5. Leave it to dry for a while and then trim the card to the shape of the Breech. Now you can shape the curve in the block. Cut out most of it with side cutters leaving a 'V' and then carefully finish the rest with a scalpel and fine round file.
Voila!! The five step breech block!!LOL LOL BigGrin
I hope that helps you, but if you get stuck let me know, and if you really get fed up and want to post it to me I will happily build it for you.BigGrin BigGrin BigGrin
DaranBigGrin
Hi Nem,
Sorry for very late thank you! Your post is a real help & what you have done looks fantastic.
Still following your build but time has been against me!
Looks great!
Wilfy
#72 Posted : 02 June 2013 18:27:39
Suspension is all done, and I am glad you cant see it when the wheels are on because it is soooooo wrong it is beyond belief!!!LOL LOL BigGrin Have also started weathering the wheels and hull sides, as its easier to do with the wheels off.BigGrin
#73 Posted : 02 June 2013 18:56:40
BigGrin Hi Nem
the weathering looks great and I see what you mean about the suspension, spring loaded instead of torsion bar as on the real thing. If the plastic kit makers can provide the correct suspension in plastic parts why did they make this hodge podge up the mind boggles
#74 Posted : 02 June 2013 19:00:55
Hi Andy and thanks for your comments. If you look closely you will also see that the suspension swing arms are also ALL pointing the same way instead of forwards on one side and backwards on the other!!!! Terrible really considering that, like you said, they can get it right on plastic kits and in a smaller scale!! Well it cant be seen when the wheels are on which is a bonus!!!LOL LOL BigGrin BigGrin
SennaMentalMe
#75 Posted : 02 June 2013 20:45:15
The weathering is very cool Daran, very realistic staining and I see what you mean about the suspension lash up!! Just as well it can't be seen as you say and I'll bet that's not the last of Hachettes' mistakes on this model? Blink Huh
Never mind mate, if anyone can make 'a silk purse out of a sow's ear' it's you sir!! Well done on a great job so far and I'll be watching with interest!! CoolThumpUp
Kev BigGrin
#76 Posted : 02 June 2013 20:46:56
Some loverly weathering ThumpUp
as for the suspension its beyond words isn't it I can only imagine they have done that for cost reduction reasonsConfused
snapdragon
#77 Posted : 14 June 2013 21:59:01
I did start this when it was released but after a few weeks I stopped the build as I started to have grave doubts about the quality and accuracy of the build.
Other Hachette partworks have been fabulous such as the Lancaster, Hood, Bismarck....
This one seemed to me to have been designed by a child and to me, Knowing the vehicle very well there was so much wrong with it. I couldn't justify spending my money and then spending much more just trying to make the thing look correct.
I will stick to Trumpeter's 1/16 Tiger II. It is a superb kit just OOB never mind adding all the extra decaling, cabling and piping and much less expensive.
Trumpeter's next 1/16 is going to be the SU100 I believe. No Idea when it is going to be released (hoping for christmas LOL)
I am also hoping that Trumpeter will do a full interior Tiger I as the new Hobbyboss one is just an enhanced RC kit with no interior.Crying As Hobbyboss is Trumpeter under a different name maybe this is an interim release to test the water for a full interior Tiger I.
The Tiger II was meant to be a limited edition with a choice of Tiger II Porsche or Tiger II Henschel turrets. It has been so successful that it has been added permanently to their cataloge at a kit but with a choice of turrets in one box.
Once can only hope that Trumpy will do a Tiger I full interior. They have plenty of examples to study.
James
#78 Posted : 20 July 2014 18:44:46
I have assembled the lower hull so I can get an Idea for painting. The complete Engine bay and lower front hull up to the sponsons is red oxide, then elfenbein from there up in the fighting compartment.
Suspension is all done, and I am glad you cant see it when the wheels are on because it is soooooo wrong it is beyond belief!!! :lol!:  :lol!:  :D  Have also started weathering the wheels and hull sides, as its easier to do with the wheels off. :D
#79 Posted : 20 July 2014 23:52:34
Looking good Nem, nice weathering touches Cool
AL
#80 Posted : 10 August 2014 18:48:58
All the wheels are now sanded, fitted and rims painted in steel. BigGrin BigGrin BigGrin
13 Pages «<23456>»
This page was generated in 0.254 seconds.
