What Gold paint or spray. Options
mark 2
#1 Posted : 20 July 2014 08:23:43
Hi Everyone.
I was just wondering what gold paint or spray is everyone using on the SOS.
Thanks and best regards to all.
#2 Posted : 20 July 2014 09:30:35
I used Tamiya TS-21
#3 Posted : 20 July 2014 09:42:39
Hi Mark, this link will show you the paint I used and close ups of how it looks on the build...
http://forum.model-space...sts&t=5013&p=94
mark 2
#4 Posted : 20 July 2014 09:49:50
Tomick wrote:
I used Tamiya TS-21
Hi Mr T.
Thanks so much for your reply.
Best regards.
mark 2
#5 Posted : 20 July 2014 09:56:33
Hi Alan.
Hope you are well.
Thanks for the link which your SOS is looking great.
I was thinking about applying some Tamiya gold leaf.
Do you think that it would look ok ?.
Thanks and best regards.
#6 Posted : 20 July 2014 10:01:33
Hi Alan.
Hope you are well.
Hi Mark, there is a fantastic amount of ornamentation on this build so applying gold leaf would probably work but think it would be a long process to cover everything needed... However, I would be tempted to order a back issue with some of the ornamentation in it and use that the test out whether it would work or not....
Hope this helps..
mark 2
#7 Posted : 20 July 2014 10:47:26
Hi Alan.
Hope you are well.
Hope this helps..
Hi Alan.
I have decided to go with the same acrylic paint as you.
I have found a link to the paint if anyone is interested http://www.ebay.co.uk/it...eName=ADME:L:OC:GB:3160
I hope you dont mind Alan.
Thanks again and best regards.
#8 Posted : 20 July 2014 10:52:55
Hi Alan.
Hope you are well.
Hope this helps..
Hi Alan.
Hi Mark, of course I don't mind. The sharing of tips and info is all part of this great forum so you go ahead....
A word on the paint, it's not the easiest paint to work with but stir thoroughly and for best results apply with a small fine brush in very thin layers to build up the metallic look... I found in some places I applied 4 thin coats.. When done, apply a clear coat gloss varnish for protection....
Any queries then get back to me..
mark 2
#9 Posted : 20 July 2014 15:35:32
Hi Alan.
Hope you are well.
Hope this helps..
Hi Alan.
Hi Alan.
Thanks for the words of advise and help.
Best regards.
riff-raff
#10 Posted : 21 July 2014 17:43:21
Just to jump in BigGrin I am using Tamyia X-12.
Mainly because my local model shop always has loads in and it covers both wood and metal parts very well.
Built:
This page was generated in 0.143 seconds.
