27 Pages «<1718192021>»
George1 Build Options
George1
#361 Posted : 18 July 2014 02:39:11
bb1949 wrote:
BigGrin Good to see your progress report George. A mighty effort I'd say.
Brex.
Hi Brex. BigGrin
Thanks mate it's appreciated. Cool Cool
My biggest hold up is nails. Not enough of them in the packs. This explained re your thread. Crying Angry
George
Building HMS SOTS
Whizgig
#362 Posted : 18 July 2014 03:02:54
Wow you are doing an amazing job with this model George well done.BigGrin
#363 Posted : 18 July 2014 22:43:27
Hi George, if the hold up on your build is due to a shortage of pins have you not considered using something else... I have actually used small round headed map pins to hold planks in place in fact, these I used extensively for the 2nd planking layer as I didn't want to have pin holes on any of the 2nd layer planks..... Something for you to consider..... Cool Cool
George1
#364 Posted : 19 July 2014 03:51:11
Hi Whizgig. BigGrin
Thanks for kind words they are appreciated. Cool Cool
Once you get all your issues depending on how much time you put in you'll soon catch up. BigGrin
George
Building HMS SOTS
George1
#365 Posted : 19 July 2014 03:59:56
Hi Alan. BigGrin
I will purchase some of those map pins as the heads are big enough to enable pulling out with the pin fully pressed home. Not like the pins supplied which if pressed home are extremely hard to remove thus I've been bending them over to get a grip. BigGrin
Some of the problem might be over as my son came to the rescue with his Dremel Set that has a special 'any size drill bit will fit chuck' he purchased when needing for repairs re the helicopters he flies. We put in the smallest drill bit that was even too small for pins and it held firm and very straight. So here's hoping my future pin supplies will still have straight pins over.BigGrin
George
Building HMS SOTS
George1
#366 Posted : 20 July 2014 04:47:13
Thanks to Alan's help0 regarding using Map Pins I've been able to progress further with planking. Problem now is I've run out of Bamboo planks and the shorts from cut offs too short to use other than for wedges. BigGrin
These pics are where I am to date. I've gone ahead and filled in spaces at the stern. BigGrin
George
Building HMS SOTS
#367 Posted : 20 July 2014 08:50:29
BigGrin Hi George
Planking is coming on a treat and looking good, Its frustrating running out of wood but it gives you a time to reflect on what you have learned so far.
I know it has been mentioned before but this first planking is for strength and coverage only so how it looks is of minimal importance the hard part is getting the second set of planks looking right and that's another challenge you will face but im sure you will do fine
#368 Posted : 20 July 2014 09:49:26
Nice neat work there George, well done.... You could also use thumb tacs as shown in Jock's build..... Keep up the good work....Cool Cool
George1
#369 Posted : 20 July 2014 11:46:13
arpurchase wrote:
BigGrin Hi George
Hi Andy. BigGrin
Thanks for the kind words and encouragement. It is as always greatly appreciated. Cool Cool
I am learning to bevel planks in places where they tend to overlap than sit even as well as using the thumb plane easier now.BigGrin
George
Building HMS SOTS
George1
#370 Posted : 20 July 2014 11:50:00
Hi Alan. BigGrin
Thanks for looking in and your kind comments. As always greatly appreciated. Cool Cool
Thanks for another tip re the thumb tacks. They probably would last longer too than the map pins which lose an odd head here and there when fully driven home. BigGrin Cool
George
Building HMS SOTS
jonny7england
#371 Posted : 20 July 2014 12:36:23
Very nice work there George...Coming along brilliantly mate!! ThumpUp
John Passmore
#372 Posted : 20 July 2014 14:26:41
G'day George
Your planking is looking really good and is way ahead of mine. Well done mate. I've got the first 4 rows plus the first tapered plank row in as I've been fiddling around experimenting with deck planking on the second deck whilst waiting for the mini planer, which finally arrived this week.BigGrin
I have followed Alan Gandales' planking sequence and have used 3 different methods for the caulking - black (thick) paper, B pencil and 0.5mm black rigging twine. Must say, I couldn't get on with the paper as it is difficult to control. Pencil method looks a bit scrappy too so it seems I'll go with the twine method for the exposed decks as it doesn't look too bad.BigGrin I'll post some pics in a few days.
JohnP
#373 Posted : 20 July 2014 15:00:54
Whizgig
#374 Posted : 20 July 2014 15:22:24
George1 wrote:
Hi Whizgig. BigGrin
George
Thanks mateBigGrin
George1
#375 Posted : 21 July 2014 02:25:03
Hi Jonny. BigGrin
Thanks for looking in and your very kind comments. I take them as encouragement and they are as always greatly appreciated. Cool Cool
I just wish I had more Bamboo planks. Might have to purchase a pack to fill in waiting on issues. BigGrin
George.
Building HMS SOTS
George1
#376 Posted : 21 July 2014 02:30:48
John Passmore wrote:
G'day George
JohnP
Hi John. BigGrin
Thanks for compliments they are appreciated. Cool Cool
Yes you will find the thumb plane an enormous help in tapering planks. I'm starting to get the hang of using it now. BigGrin
I will very much like to see your pics of deck planking when you have them. It will give me an idea of what looks best as well and save me time experimenting. Cool BigGrin
George
Building HMS SOTS
George1
#377 Posted : 21 July 2014 02:33:12
stevie_o wrote:
Lovely planking GeorgeBigGrin
Hi Steve. BigGrin
Thanks for looking in and your kind compliments. As always greatly appreciated. Cool Cool
I'm slowly getting there re the planking. BigGrin
George
Building HMS SOTS
George1
#378 Posted : 21 July 2014 02:38:19
Whizgig wrote:
George1 wrote:
Hi Whizgig. BigGrin
George
Thanks mateBigGrin
Hi Whizgig. BigGrin
You're very welcome mate. Being a Newbie myself I know what it's like first coming into the forum and the build that lays ahead of you. However with the very experienced guys always there and only too willing to help with any problems you might face it does make it a lot easier. BigGrin
George
Building HMS SOTS
#379 Posted : 21 July 2014 12:04:01
BigGrin Coming along well George lovely workThumpUp Rgd Martyn
George1
#380 Posted : 22 July 2014 04:00:25
Hi Martyn. BigGrin
Thanks for looking in and your kind comments. As always they are very much appreciated. Cool Cool
More planks in a couple of days so I can get moving again. BigGrin
George
Building HMS SOTS
Guest (7)
This page was generated in 0.250 seconds.
