Adhesives Confusion Options
Captain Plummet
#1 Posted : 17 July 2014 15:22:52
In Pack 01 on page 23 of the instruction book it listed three types of adhesive that were required to make the model, with an explanation of what each did. I duly went off and bought some of each.
But when I come to make the model I find that the instructions don't seem to specify which sort of adhesive to use in which stage. For example, I'm currently assembling the rear wing, and the term that seems to be used all the time is just 'apply plastic adhesive to'. How confusing is that?
Would it not be more helpful if the terms 'apply ABS glue to', 'apply polystyrene glue to' or 'apply superglue to' were used instead as appropriate?
It's not just me being especially dumb, is it?
(And incidentally, when fixing the main rear wing onto the end-plates, should the black paint not be removed from the end-plates where the wing is fixed to them? The instructions don't say that it should, but surely if it isn't removed one is gluing to a painted surface...)
#2 Posted : 17 July 2014 15:39:30
See post #15 regarding adhesives
http://forum.model-space...spx?g=posts&t=11244
Captain Plummet
#3 Posted : 17 July 2014 15:49:23
Thanks for the swift reply.
I can certainly empathise with Benny...
(Apologies for not spotting that thread. Blushing )
So 'plastic glue' = 'polystyrene cement', basically then?
And my end-plate paint removal query?
#4 Posted : 17 July 2014 17:52:20
Hi Captain BigGrin
There are no instructions to remove the paint due to the high risk of damaging the area outside of where the wing sections will be glued and as long as the correct adhesive is used and care when assembling, you will not have any problems.
As with any model making, plan ahead, read ahead and test before glueing. BigGrin
Spencer
Captain Plummet
#5 Posted : 17 July 2014 23:06:06
Warthog wrote:
Hi Captain BigGrin
Spencer
Thanks Spencer
Yeah... it was the reading ahead bit that led me to ask the question [about scraping paint off] really.
In the end I went ahead and assembled before I saw your reply, but I did in fact scrape some paint off between the two large locating pins. It seemed safe enough to me as long as I didn't make the scrape wider than the width of those pins. Worked perfick. BigGrin
Cheers,
Rob
#6 Posted : 17 July 2014 23:25:41
Your more than welcome Rob BigGrin Everyone who builds models do things differently and I don't think there is one "off the shelf" plastic kit I've done where I have followed the instructions to the book LOL
Enjoy your MP4/4, it really is a stunning piece of kit
Spencer
This page was generated in 0.087 seconds.
