I can`t stand the copper-plating of my Victory any more!! :) So the lady will get some rest. Seems that there isn`t much interest in the AKAGI among the builders as there are few diaries and most of them uncomplete (even the official build). So let`s give it a try!DaDokta attached the following image(s): Greetings, Walter
Good luck and certainly no tiling to contend with..
I will be following, good luck “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
This should be good, I'm following this one Steve
 Best of luck on her Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks like you are off to a good start, good luck with the build....  .. This one does interest me but am likely to wait until the SOTS is finished before taking this one on..... Regards Alan
I did a little sanding on the bow and stern formers:DaDokta attached the following image(s): Greetings, Walter
 Hi DaDokta I think you may find the stern block is mounted a little low at the position you have it placed. The reason i say this is the ply deck will almost be flush with the tabs and the stern block is lined up with this deck so the etch deck plate fits correctly on the model. Another suggestion would be to plank the hull first before the fitting of the bow and stern blocks as it makes lining them up easyer. She is certainly coming on a treat regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy! The blocks are not glued yet, i just put them on the model for the pictures - also this was only the first stage of sanding - many more will come. Of course I will do the planking first and then fit the blocks. Thanky for the heads-up! Greetings, Walter
Coming along very nicely, looking good.... Regards Alan
I started the planking of the hull:DaDokta attached the following image(s): Greetings, Walter
 Hi DaDokta Nice start on the planking. Just one word of advice take the planks at the top up one more from where they are now as this gives you extra wood to play with when fitting the decks and it can easily be sanded back to the deck height regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, the upper planks are sanded back already after test fitting the bow deck. Cheers, DaDokta Greetings, Walter
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
I am going to follow your build with interest - This is my next purchase after I have completed the Yamato Good Luck Mate You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Hi guys - a little progress on the hull:DaDokta attached the following image(s): Greetings, Walter
Hi DaDokta, looking good, she's coming along very nicely..... Regards Alan
A well deserved beer though
Hi DaDokta enjoying looking at your excellent build. what kind of pins are you useing to hold the plank`s on and where do you get them please? COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks for your comments! @tigerace Those are actually the brass pins, which came with the Victory build. I´m using them over and over again. But they are nothing special - you can get them in every model shop for a few cents. For example: ModelShopAs i am from Austria this is a german shop - but as i said you can get them anywhere. When using those nails you would need a device to put them into the wood (i don`t know the english word - nail setter?) I hope that helps! Greetings, Walter
Walter A very nice build you have the go here. This looks a very involved model but sure the end result will be spectacular. Happy modelling Tony Happy Modelling
Guest (7)
