Cross Head and Piston Rod Problem Options
crbc54
#1 Posted : 15 July 2014 14:22:51
Hi All, I have fitted the piston rods into the cylinder cover as instructed on page 34 of instructions. The problem is that they do not slide freely and there is a little resistance.I am worried that that when the rods are fitted they might not turn and lock up.Has anyone got advice on this.Also would a little WD 40 help? Many ThanksConfused
#2 Posted : 15 July 2014 17:11:48
The resistance can only come from the rods not being glued squarely into the crossheads.
If you can, remove them and re-set. Certainly a lubricant will help, but if you are painting your model, I would not apply it until the painting is complete, so as not to contaminate other areas with the lubricant.
crbc54
#3 Posted : 15 July 2014 17:54:02
Thanks for that Mr T.I will check the fitting to see if they are not square . As they have been set with epoxy for quite a long time I am not sure how I would get them out . I will try a little lubricant as I am not painting the model.Regards,Clive
experten
#4 Posted : 26 July 2014 06:24:30
Clive, to get them unstuck, disassemble what you can, and then soak the parts in acetone overnight. You'll have a "puddle of parts" in the morning, and the residue of the epoxy is quite easily cleaned up. Then, you have a fresh start!
Tired, Old, and Cranky!
crbc54
#5 Posted : 26 July 2014 17:27:38
Hi There Mark, Thanks for your very helpful reply.I feel much better now that I can Resolve this problem-brilliant.
Cheers,Clive
