HarryAsh Options
HarryAsh
#1 Posted : 12 July 2014 21:30:12
Hi, I am new to the forum although I have been following it for some time. In stage 8 the left hub assembly was built and I ono this is a static display but the way this hub is made the wheels seem that they do not rotate.
If this is correct has anyone looked into altering the hubs and fitting bearings.
The bearing size required seems to be 9 by 4 by 2.4 x 2 and are available.
I do have a spare hub and may give it a go.
#2 Posted : 12 July 2014 21:54:31
First of all a big welcome to the forum HarryAsh BigGrin
There is no reason why the discs won't turn on the wheel hub etc and they are not designed to run free like a toy cars wheel so there might be some friction. (As you say it is a static model and not designed to be pushed around the floor) So, it may be possible that some adhesive may have gotten onto the Disc itself. Using the paper between the callipers etc gives you time to make adjustments before the glue sets and being able to turn the disc etc. Another word of caution is that if you do decide to modify the hubs and adding bearings (personally I'm not sure it's possible) then any parts that need replacing due to damage will have to be paid for.
So unless your sure the hubs where assembled correctly to start with (always worth checking) then it might be better to go down the route of getting replacement parts sent. Any defect parts may need to be returned of course.
I know it's difficult to show a picture of the disc not turning but if you could provide a picture of the parts you have assembled then hopefully we might be able to understand more what the problem may be.
Spencer
HarryAsh
#3 Posted : 12 July 2014 23:13:04
Thank you for your quick reply Spencer.
I have already worked out that on this model the disc rotates on the axle shaft.
I am just looking into the possibility of making the axle shaft rotate as it would on the real car.
Thank you again Mick.
#4 Posted : 13 July 2014 08:30:28
BigGrin Hi Harry
Welcome to the forum and enjoy your build
#5 Posted : 13 July 2014 11:31:48
#6 Posted : 13 July 2014 11:42:49
Welcome to ModelSpace Harry. Nice idea, hope you enjoy your stay with us Cool
Steve279021
#7 Posted : 14 July 2014 13:36:27
I am currently waiting for pack 3 but surely from looking at the build pictures it should not rotate. The 2 copper coloured parts are fixed which surely means that when you tighten the wheel nut, the wheel, disc and outer shaft should all pull together tight and not move. For the disc and wheel to rotate on the axle the wheel nut would have to be left loose meaning the wheel would wobble?
Dodge charger build complete
#8 Posted : 14 July 2014 19:58:20
It's the brake disc that rotates and the wheel clamps to the brake disc/hub as a normal car does. Both rotate together allowing the car to stop. The model is not designed to "freewheel" but does allow for rotation.
Spencer
HarryAsh
#9 Posted : 17 July 2014 19:38:50
I have done a scaled cross section drawing of the upright and bearings I was going to use. It came clear that I would have to modify the upright to fit the bearings (depth). This and the problems of running clearances etc I have decided to build as per instructions.
Thank You for your inputs and you may here from me again. Mick
#10 Posted : 17 July 2014 20:47:04
It was worth looking into Mick and hopefully we will hear from you again with some updates on your build BigGrin
Spencer
This page was generated in 0.432 seconds.
