Martyn Ingram wrote: Looks like new Gibbo Bril work rgd Martyn thank you Martyn Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Your tiling looks great Gibbo
Jesus-Belzheim wrote:Your tiling looks great Gibbo Thank you very much Peter, it was worth the time putting into it, you're doing a lovely job on yours, is that the Victory tile pack you are using ? Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Joined: 19/05/2014 Posts: 13 Points: 19 Location: Greenville, Ky.
Hi Gibbo: You victory is looking great especially the copper tape. I haven't gotten that far yet but I will be covering mine with copper also. Where did you get the copper tape? Best regards. Keith
oldstampman wrote:Hi Gibbo: You victory is looking great especially the copper tape. I haven't gotten that far yet but I will be covering mine with copper also. Where did you get the copper tape? Best regards. Keith Hi Keith thank you for your comments, very much appreciated, here is the link to the ebay store that i used, they sell the copper tape in different widths, my DelPrado Victory is 1:100 scale, i dont know if the copper tape i used is to scale for that model, i believe the DeAgostini model is 1:84 scale, so if you want it to scale then it might be worth asking one of the guys on here how wide the tiles are in the Victory Tile pack, i look forward to seeing it. Cheers Paul www.ebay.co.uk/usr/rythe...k?_trksid=p2047675.l2559Have a look at peter's tiling on his Victory, i think he used the tile pack, he should be able to help you with the tile size http://forum.model-space...sts&t=4197&p=10
Hi Gibbo! Well done on the nameplate! I had similar problems with the yellow, inkjet yellow ink on its own isn't bright enough (or opaque enough) to cover a dark background, the printers rely on a white paper base to allow it to 'shine' through. I think I forgot to mention that I used the white background decal paper in the end! The black ink for the background behind the letters blended in perfectly with the Admiralty black once both had had a clear matt varnish over the top! Well done again! PS In 1:100 scale the copper plates would be 4mm deep so our tape is only about a mm or so oversized, not worth slicing it down anyway!  (actual size is 4ft long by 1'2" wide) Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
She is really starting to look the part Gibbo,great work so far
Plymouth57 wrote:Hi Gibbo! Well done on the nameplate! I had similar problems with the yellow, inkjet yellow ink on its own isn't bright enough (or opaque enough) to cover a dark background, the printers rely on a white paper base to allow it to 'shine' through. I think I forgot to mention that I used the white background decal paper in the end! The black ink for the background behind the letters blended in perfectly with the Admiralty black once both had had a clear matt varnish over the top! Well done again! PS In 1:100 scale the copper plates would be 4mm deep so our tape is only about a mm or so oversized, not worth slicing it down anyway!  (actual size is 4ft long by 1'2" wide) Robin Thanks Robin i'm really chuffed with it, still got to varnish it yet to seal it in. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
davetwin wrote:She is really starting to look the part Gibbo,great work so far thanks Davetwin i'm really enjoying adding and enhancing what i now know was not a great model to begin with. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Looking good Gibbo, very nice work on the nameplate... Regards Alan
This weekend i decided to re-do the grating on the lower deck, i had already done some of the grating on the upper deck during the week  Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Marked & cut out the sections ready to take the new 1.2mm grating from Cornwall Model Boats, taking a saw & drill to already laid decks is a scary thing, measure ten times - cut once.     Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Now that I do like Gibbo, beautiful work on those gratings... Cutting holes in a previously completed piece is always scary and your advice of measuring 10 times and cutting once is so very valuable to all newcomers....  .. Keep up the great work, will be following.... Regards Alan
I built the grating first and then built the frames around them, i found it a lot easier to stick the frames onto paper first, i marked two lines at 90 degrees to make sure they are square and when dry cut them out,and finally the new frames ready to go on.    File Attachment(s): Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Gandale wrote:Now that I do like Gibbo, beautiful work on those gratings... Cutting holes in a previously completed piece is always scary and your advice of measuring 10 times and cutting once is so very valuable to all newcomers....  .. Keep up the great work, will be following.... Regards Alan Thanks very much Alan, your comments are always much appreciated Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Nice work Gibbo, looking good Steve
stevie_o wrote:Nice work Gibbo, looking good Steve thanks Steve, those gratings are fiddly little beggars Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Gratings and hatches complete, waiting for ladders to arrive, next up the Rudder.   Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Blimey Gibbo, that brings back some frightening memories Glad to see you are going for the improvements on your Victory, the gratings look great, be aware though that there are a couple of divisions in the forecastle gratings. Well done again, nice to see another Del Prado in the mix. Regards Alan England expects that every man will do his duty.
