13 Pages «<678910>»
Jack.Aubrey's Soleil Royal Options
#141 Posted : 05 July 2014 22:50:57
Jack
It's been a while since I last looked in on this one.
Absolutely brilliant is all I can say. I really love that blue dye you have used and with the gold adornments on top it looks brilliant.
jack.aubrey
#142 Posted : 06 July 2014 14:58:17
Gibbo, Alan, Tony,
many thanks for your comments, I've greatly appreciated them. I'll continue to keep posted this WIP in the future.
Regards, Jack.
jack.aubrey
#143 Posted : 06 July 2014 15:01:07
August 25, 2012. . continuation. .
Some new details added on the decks: the pinrails of the mainmast. In the rush to fix these pieces I forgot to drill the pinrails before installation. Now I'll have to do it "freehand" on the pieces already fixed and will be more difficult to achieve the same spacing and alignment I would achieve before . .
Here are shown the WCs installed at prow . .
Finally an overview of the guns after I finally glued the barrels to the carriages, using epoxy glue. Initially these barrels were fixed with the cyan and had fallen off completely after few time. The seal of the epoxy is incredibly stronger than the cyan for this type of bonding.
To keep in mind for the future for when I will have to fix the remaining gun carriages to the decks. . with this glue it will no longer be necessary to use pins as reinforcements.
See you soon, Jack.
jack.aubrey
#144 Posted : 06 July 2014 15:02:32
A set of more focused photos of some details. . the first still on decorations
jack.aubrey
#145 Posted : 07 July 2014 12:38:35
Monday, September 3, 2012
In the few hours that I devoted to the model in these last days I continued to apply some of the decorations that were ready for installation and, above all, I have finished the "missing wood pieces" of the lower "bottle". I also decided to change its color, applying the stained blue strips, as you can see from the first and second picture when compared to the previous already posted some time ago.
The remaining images show the other decorations applied to the gunports of the upper deck and bow. Nothing to add apart I used the epoxy glue to fix them.
Kind regards, Jack.
jack.aubrey
#146 Posted : 07 July 2014 12:42:38
Wednesday, September 19, 2012
The last evolution of the stern.
Then yesterday I took the hull and I fixed rigidly on the work table upside down to start thinking seriously about the decorations that are under the lower gallery and those to be placed on the two lower smaller bottles.
I must now say that the decorations of the lower bottles do not fit very well on their surface and, by a careful examination and after various positioning tests, this is a quite big problem . . I'm still far from a clear idea of how to proceed . . I'm considering to rebuild totally them with mouldings like FIMO or Milliput . .
Kind regards, Jack.Aubrey.
jack.aubrey
#147 Posted : 08 July 2014 09:21:23
Tuesday, September 25, 2012 - Display Case
I temporarily abandoned the stern and his goddamn decorations and I got into the building of the display case basement. A kind of digression to the routine of the stern. .
In the picture 01 you can see the first part of the case, the pedestal, just finished, even if they miss the obvious finish (stain, velvet or cork on the surface of contact with the hull, etc.). This piece will be later mounted on the basis of the case, not yet ready.
The next two images show this piece without the hull above, visible in all its details. If you look at the images in high resolution you will notice how the two supports, with a thickness of 1 cm. have been shaped with a camber to follow the lines of the hull in the area where it will rest. The material used is beechwood.
To take the shape of the hull in the area where this would be resting on the pedestal I used a tool that is called "form tracer", illustrated below.
And before to work on the final beechwood table I made the prototype with an more ordinary poplar plywood 5 mm thick, much easier to work.
That's all for today, Jack.Aubrey
jack.aubrey
#148 Posted : 08 July 2014 09:25:07
Monday, October 1, 2012 - Display Case
In these days since my last post I continued the work on the display case. For the base I bought at the nearest woodstore the three elements that characterize it, namely:
1) - a beech table (thickness 18mm) cut with dimensions of 99 x 27 cm; the customized cutting service was provided by the woodstore staff;
2) - strips of wood (unidentified), length 240 cm, 3 cm x 0.5; it will be used for the outer frame of the base;
3) - 5 knobs of lathed wood for the "legs" of the base.
The pictures 01 and 02 show the upper part of the base, with the outer frame applied. As can be observed the frame delimits the perimeter of the base and, being higher than 1.2 cm. will serve to hold the plexiglass of the transparent element of the case.
The wood was then treated with a coat of wood filler. Once the paint dried I sanded everything with very fine steel wool and then I applied a couple of coats of wood oil, the same I usually use for the model. Between one coat and the other I had to wait a couple of days to allow the oil to deeply penetrate and dry.
In the next two images (03 and 04) I show the bottom of the base, which is also treated with a coat of wood filler. Here are visible the five knobs that have the function of "legs". I decided it was necessary a fifth knob placed in the centre to avoid a possible failure in the central area of the base under the weight of the parts above. Unfortunately for this knob I had to use a different color because the light ones were finished, but it is well hidden under the base and should not be visible.
Finally, the last image, even if these details are also visible in the first two (but in high resolution) where you see the threaded cylinders where I will fix the pedestal shown in the previous message. Anchor points are in number of four.
That's all for now, even though I have more pictures to show, but in the next episode. .
Cheers, Jack.
jack.aubrey
#149 Posted : 09 July 2014 09:27:53
Tuesday, October 2, 2012 - Display case . . continuation
The presentation of my work for the building of the display case base for my Soleil Royal continues here. In this new post I want to focus on a particular detail: the name of the model.
Usually a model is presented with somewhere a label that specifies the name and more. For my Soleil I used my computer and I tried a bit of presentations and I decided to adopt the label here below presented.
Having made my choice I passed to the practical realization and I designed the oval on an ordinary tablet of plywood, with a jig saw I proceeded to cut them and finishing with sandpaper and three coats of white acrylic paint as a primer.
A little trick that I have thought to work faster with acrylics: to have the paint drying in a couple of minutes, in order to avoid waiting for the complete "natural" drying, I use to heat the painted piece with the hair dryer . In this way I was able to apply three coats in less than 15 minutes against at least 6-8 hours of the normal procedure. In the picture 02 the resulting pieces, suitably sanded and ready for final processing.
I left the final processing to my wife who loves painting with acrylics with the so called "country" style. And here below the result of her work.
The pedestal in the center of the base is only positioned because I have to finish the screws and washers that will be used to secure it to the base. But this is a trivial detail. Until next time, Jack.
jack.aubrey
#150 Posted : 09 July 2014 09:30:27
Thursday, October 4, 2012
To complete the images of the above messages, here is the display case base with the model in place . .
Regarding possible display variants I decided to build a third boat, in place of the two proposed by the kit manufacturer, more precisely, I would like to build a longboat.
Then I decided to put only one of these three boats, perhaps the smallest, over the structure (this structure is a bit strange indeed, I've never seen a similar one on other models) that should host it amidships.
I'm going to show the other two boats not aboard but on the base of the case in a suitable position. This would allow a better overview of the details in place in the central area of the deck, certainly less crowded and to increase the visibility of these boats, presented separately. I spent a lot of time to build these boats and I would like to better appreciate them.
I did some simulations and the idea likes me very much . .
Greetings, Jack.
jack.aubrey
#151 Posted : 10 July 2014 13:06:58
Monday October 8, 2012
I've almost finished the building of the display case: now the only part missing is the plexiglass cover, but this can wait sometime. I have started and finished a couple of tasks that I left behind, such as the browning of all decorative elements.
In particular, I have devoted great attention to the figurehead and a couple of human figures that will be placed at the stern. In the photographs they seem worst as they appear in real life, but I'm not happy with the result: they seem to me a little vanishing, as if there were no reliefs enhancing the depth effect. Before installing them I'll wait to find some ideas to increase their realism.
Then I started the preliminaries for a new task: the installation of metal small columns that will be the basis of the gunwales all around the decks. As a logical consequence of having all the metal decorations properly gilded I can't leave the columns as they were originally delivered. . there would be an inconsistency so I took the decision to treat them too, although this would force me to spend much more time than usual.
I guess now you all understand why the model progresses so slowly. . and the remarkable qualities of patience I developed in this adventure, qualities that I didn't absolutely have before . .
After the application of two coats of primer I had two options: gold paint or another color. At the end, I opted to color them in red (but after having also evaluated the blue color). Maybe this choice will appear a little crazy to most of you but I think there's already enough gold on this model . .
Cheers, Jack.Aubrey.
jack.aubrey
#152 Posted : 10 July 2014 13:08:06
Below a possible idea of how to position and present the ship boats, externally to the model, on the display case basement. If we exclude the black base which of course is not needed, this presentation system would have two advantages: allow to display the boat with more viewpoints visible and the possibility of fixing the boat base to the basement with a simple double-sided tape. .
jack.aubrey
#153 Posted : 10 July 2014 13:10:04
Wednesday, October 11, 2012 - Third ship boat
As I wrote a few messages ago, I decided to build a third boat for my Soleil Royal. This boat that will be exposed on the basement of the case, as I decided for the larger of the two I built before, whose material was included in the kit.
I used a project already in my hands for some time and some work done in the past.
Here below some pictures of the longboat under construction and still unfinished.
01 disappeared thanks to DeAgostiniPassion.it
02 disappeared thanks to DeAgostiniPassion.it
03 disappeared thanks to DeAgostiniPassion.it
04 disappeared thanks to DeAgostiniPassion.it
Yesterday afternoon and Monday I prepared the gun port lids that will be installed of the lower and intermediate decks. For the solution that I had in mind the pre-cut material supplied by DeAgostini was not suitable, not so much for the pieces themselves as the lack of an adequate system of fixing to the hull. So I've built the lids from scratch using other material. For the moment I am still in the process, even though I already painted the inside in red. In the coming days I could show you how I imagine the necessary finishes that I have in mind: hinges, rings and ropes for their opening and closing . .
Sincerely, Jack.
jack.aubrey
#154 Posted : 10 July 2014 13:14:42
Saturday, October 13, 2012 - Gun port lids
As I have previously written, I changed all the necessary material for the gun-port lids because I wanted to implement a method of securing themselves to the hull that was very strong. In fact the pieces proposed in the kit, although correct from a formal point of view, do not provide any appropriate method to fix them on the hull.
So, as I wrote, I re-did from scratch everything. For the larger square, originally plywood with 2mm thickness, I did it again using plywood (1.5 mm) on which I glued strips of ​​chestnut veneer (0.5 mm), the same wood used for the second planking of the hull. I have prepared in this way bars of 15 x 10 cm and then I cut with the table saw piece to piece.
Regarding the second piece, the smaller square, I re-did it in a different form: instead of square I made it rectangular, so that it protrudes from a side of about 3mm from the larger square element. If you look at the picture below you will easily understand what it came out.
Then glueing the two pieces together using a template to ensure all result the same and, finally red acrylic paint of the inside.
Then it was the turn of the eyebolts. Those proposed by the kit are out of scale for me.
I opted for building from brass wire/thread. The ring has an inner diameter of 0.75 mm. Must be burnished prior to assembly.
I developed a prototype that I brought up to the final assembly stage, to see if it satisfied me. It is visible in the three images that follow. The eyebolts used have an internal diameter of 1.5 mm as I have used material already available to accelerate the process. The final version will use the smaller ones. I also have in mind further improvements.
For gluing the lid to the hull, as well as the half-barrel, I used two-components epoxy glue. I've seen that this glue provides a very strong bonding. For the lid would be enough the vinyl glue, but since I had already prepared the epoxy I used the latter. But I think the epoxy is much more tenacious, then I'll probably use this one for the future.
Once finished the prototype now I have to move to mass production for all the rest. The work to be done is a lot: about 200 eyebolts, three holes for door, assembly, ropes, etc.. For the moment, what I wanted was the prototype while for the rest there is time, since before there are more important things to do.
See you next time, Jack.Aubrey.
jack.aubrey
#155 Posted : 11 July 2014 09:38:34
Saturday October 20th, 2012
This week I did not too much . . I have almost finished the remaining ship boats.
The bulk of the work were the oars. . .
Cheers, Jack.
jack.aubrey
#156 Posted : 11 July 2014 09:42:23
Monday, November 12, 2012
I decided to work on the gunwales above the third deck battery (waist), an activity that involves the use of the metal columns that I had previously colored red.
Obviously I was prepared myself teorically to manage this step and I came to the conclusion that:
  1. I would have used the bi-component epoxy glue to bond the metal columns to the deck, and that
  2. I would have bent the rails 2 x 7 to follow the curve of the waist and the forecastle using the trick to prepare two strips 2 x 3,5 glued together, so as to form a 2 x 7, on a template obtained from the same contour of the deck.
For the second point it seems obvious to point out that once the whole composite was dried completely would have had the exact shape of one side of the waist and forecastle.
Due to the long drying time of the bi-component glue, I spent a day bonding all the columns on the waist while I spent the next day to apply the strip prepared in step 2, the columns are glued in turn to the top strip always with bi-component glue.
It was not a difficult job, the only real problem was caused by the same columns that, perhaps because of the molding process not very accurate, were not all exactly with the same height and then in some cases were too short and other too long.
With a lot of patience I leveled all the columns with the mini-drill, which was mounted on a grinding wheel suitable for metal.
Some adjustments to the bulwarks profile which lacked a few tenths in certain points and then I could proceed with the final bonding.
The third day was dedicated to finishing the job done and to complete some of the remaining two ship boats accessories (rudders, eye bolts, coils of rope, etc.), to install accessories today in order to have the boats "really" finished .
Below are some pictures of the work done.
jack.aubrey
#157 Posted : 12 July 2014 10:02:04
I take this opportunity to add more photos. .
jack.aubrey
#158 Posted : 12 July 2014 10:03:16
Saturday, December 1, 2012 (please look at the date, its important to understand this message) . .
I spent this last week to choose, collect, prepare and load into the car all what I'll need to "winter" in Tuscany, centre of Italy.
I just finished loading on my car almost everything; the remaining bargage for next morning, at the last useful moment.
Tomorrow,  at around 10:00, with the tide, sailed the anchors, I put the bow to south / south-east in "deep downwind close-hauled" to Parma, then south-west with "starboard tack" until La Spezia and then south to Pisa with "the wind in the sails". Go back upstream on Arno river with the favourable tide and I will arrive . .
The ship yard is now closed and will be reopened in 2013, most probably in May.
jack.aubrey
#159 Posted : 12 July 2014 10:03:53
Saturday, June 1, 2013 - Next reopening of the shipyard
Good morning, in the coming days, probably tomorrow, after six months of total lack of news due to my absence from home, I'll reopen the yard of the Soleil Royal. The yard will be managed in parallel with the shipyard of Twelve Apostles that for at least five/six months from now will be fluctuating.
I want to work hardly on this model in order to finish it, health permitting, by the end of the year 2013. Let's hope so. Tomorrow afternoon I'll start a planning session to take up the model in the right direction. I have to admit that in these six months I have forgotten many things regarding its construction.
Sincerely, Jack.Aubrey
jack.aubrey
#160 Posted : 12 July 2014 10:04:40
Thursday, June 20, 2013 - back to work
Today, after a few days when the hot weather was the absolute master, I finally started to work around my Soleil Royal. .
Date absolutely to remember: it was since November of last year that the show was over. I'll manage this shipyard concurrently with that of the Twelve Apostles where I'll probably have frequent downtime because of the monthly shipments.
The aim of this first activities is to install on the forecastle the red columns that long time ago I prepared. There are also some hardwood rings, that will serve as "open gunports" for the forecastle guns.
First I prepared the two (curved) handrails for the castle, which will then be applied over the red columns and the rings. I took the exact shape of the curve on both sides, in order to prepare the curved pieces. I glued together two strips 2.5 x 2mm and retained them over the previously obtained template. When the glue made its mission the two pieces were permanently curved and ready for use.
Then I started the preparation of the straight rack at prow: twelve columns spaced from each other by 91 mm. When drilled the holes to receive the columns I bonded the latter in place with epoxy glue. Now they are drying waiting for tomorrow, when they will be mounted in an "extra strong way".
I then started to prepare the material for the ladders that are located on the two sides of the hull: by the time I prepared only the basic element consisting of a compound strip 4 x 1 plus another 2 x 2.
Of course I have no images to show, virtually there is nothing interesting to show in the work done today.
That'a all for today, see you next time, Jack.Aubrey.
13 Pages «<678910>»
This page was generated in 0.375 seconds.
