15 Pages <1234>»
steve's build Options
Steve279021
#21 Posted : 29 June 2014 23:59:11
Stage 6 now complete. As I had done the front wing skids earlier this was only the rear wing support. I have not glued it in yet as someone on here advised to wait until later on in the build but they are glued together.
Dodge charger build complete
#22 Posted : 30 June 2014 11:34:51
Coming together well Steve, nice work.
Steve279021
#23 Posted : 30 June 2014 21:51:26
Started stage 7 now. This stage concentrates on the engine. Got the cam cover logos glued on then the cam covers loosely screwed on to the engine. Also glued on the air chamber end. I noticed after taking this pic that there was some'fogging'on top of the badging from the instant adhesive. I was able to remove this with a sharp knife. It only really showed up on the flash anyway
Steve279021
#24 Posted : 30 June 2014 22:10:19
#25 Posted : 30 June 2014 22:38:17
Looking good Steve, a little late I think but using a toothpick to apply the instant adhesive as in the official build diary will make sure that you don't get any overspill.. It's always a rule of thumb that when using superglue to make sure you have clean grease free hands/fingers etc as any "sweat" from your fingers will then activate and draw the fumes from the glue and fog.
Now, rather than use a blade to remove the fogging you can use some future floor polish lightly over the fogging and this will hide the fogging, it won't remove it but it saves damaging your parts.
Spencer
Steve279021
#26 Posted : 30 June 2014 22:43:16
Thanks, I'll give it a go. But to be fair it is not that bad really. The flash from the camera makes it look worse then it is.
#27 Posted : 30 June 2014 22:46:47
As long as your happy with it Steve, that's all that matters BigGrin
Spencer
Steve279021
#28 Posted : 01 July 2014 08:00:59
When I came to gluing the air chamber end to the plenum I did do it by putting a bit of glue onto a plastic sheet and then using a tooth pick which I found much better. All part of the learning process I suppose. After all this is my first model!
#29 Posted : 01 July 2014 19:27:49
Well your doing a good Job Steve and plenty more parts to glue in later stages to get your teeth into BigGrin
Spencer
Diddy1_98
#30 Posted : 01 July 2014 20:59:51
Looking good Steve.
I'm starting to think I should have done my Marlboro decals at the time of building rather than leaving them until a later date!
Dave
Steve279021
#31 Posted : 01 July 2014 21:09:24
It's only the rear wing I'm putting the marlboro decals on early. Just thought the wing would be harder once assembled.
Steve279021
#32 Posted : 03 July 2014 10:54:17
Stage 7 now complete. The 2 alternator halves were glued together and test fitted to the engine with the belt and the 2 parts glued to the plenum. That's pack 2 finished now. Waiting for pack 3.
Steve279021
#33 Posted : 17 July 2014 18:07:03
Pack 3 here now so time to get on it again. Not that this pack will take long!
#34 Posted : 17 July 2014 19:10:20
You will be amazed at how quick a month goes by BigGrin
Spencer
#35 Posted : 17 July 2014 22:57:12
Coming along nicely Steve, looking good..... Cool Cool
Steve279021
#36 Posted : 21 July 2014 08:40:02
Stage 8 done.
Steve279021
#37 Posted : 23 July 2014 18:15:06
Stage 9 done now. The large parts which are the left radiator housing parts are not used at this stage so have not been opened.
Steve279021
#38 Posted : 24 July 2014 07:54:31
That's stage 10 and pack 3 finished now. Awaiting pack 4. At least that pack will have a bit more to do!
Steve279021
#39 Posted : 14 August 2014 19:14:30
Pack 4 here now, stages 11-14. Comes with a free cutting mat.
Steve279021
#40 Posted : 17 August 2014 19:38:38
Stage 11 done now. Same as stage 8 really
15 Pages <1234>»
This page was generated in 0.364 seconds.
