19 Pages «<1112131415>»
My Build Diary of the Santisima Trinidad Options
#241 Posted : 30 June 2014 21:09:44
BigGrin Hi Mark
Thanks for your kind comments and looking in
#242 Posted : 12 July 2014 22:43:53
BigGrin Hi All
This month's parts include the keel sections which are made of thin hardwood outer surface with a lightply core and the instructions reccomend painting these parts.
As i am doing a minimum paint build i decided to replace these parts with 5 mm Walnut sheet , using the parts as templates they were cut out on my electric fret saw.
The fret saw if your lucky enough to have one will save you a lot of time but its still possible to cut these parts out the old fashioned way.
More soon
#243 Posted : 12 July 2014 22:51:57
Hi Andy, walnut sheeting looks far better than simply painted hardwood/ply parts.... great job in reproducing the replica parts.....
Looking good...
#244 Posted : 12 July 2014 23:02:18
BigGrin Hi Alan
Your right about the walnut looking better but of course its down to the individual and what finish is wanted on the build, thanks for looking in and your comments
#245 Posted : 12 July 2014 23:30:01
Looking good Andy ThumpUp
I am waiting to build up a few packs before I start on mine, it will give me a chance to get further along with my Yamato, Im already in the 4th month of the build.
In the meantime I have the portable work bench on order from CMB BigGrin
#246 Posted : 12 July 2014 23:36:15
#247 Posted : 13 July 2014 08:24:38
BigGrin Hi Dave
Its good that you decided to get the workbench as you now have a place to store your build safely
#248 Posted : 13 July 2014 08:29:11
BigGrin Hi Steve
The walnut adds a little extra to the build and should look good when its been varnished and thanks for looking in and your comments
#249 Posted : 13 July 2014 21:18:26
BigGrin Hi All
A little more done but still loads to do as yet.
Today i fitted the Walnut keel parts and then proceeded to fit the rubbing strakes between the decks , no real problems encountered here just make sure the strakes at the front and lower stern are well soaked before using your plank bender to get round the curves. The lower three stern stakes must be bent and twisted so be careful here.
More soon
#250 Posted : 13 July 2014 22:32:53
Looking good Andy, think it will look fab when varnished.....
#251 Posted : 13 July 2014 23:24:23
BigGrin Hi Alan
Thanks for looking in and your comments, there will be two different types of varnish/seal used on the hull hopefully the contrast between the two will look good.
petpole
#252 Posted : 14 July 2014 00:57:14
Looking a great build as usual Andy, be great varnished and natural.
Peter
BigGrin BigGrin BigGrin BigGrin
#253 Posted : 14 July 2014 07:58:19
BigGrin Lovely work there Andy BigGrin Rgd Martyn
#254 Posted : 14 July 2014 08:36:26
Hi Andy,
Love the planking, I can see many hours of work have passed but looking at the end result it has been well worth it, thank you for sharing.
Trev.
#255 Posted : 14 July 2014 20:55:08
BigGrin Hi Peter
Thanks for looking in and your comments, hopefully my plan for two different finishes on the hull will work out
#256 Posted : 14 July 2014 20:55:57
BigGrin Hi Martyn
#257 Posted : 14 July 2014 20:58:38
BigGrin Hi Trev
Thanks for looking in and your comments, As you know planking brings its own rewards when the finished hull looks as you wished it too [ or close to itLOL ]
George1
#258 Posted : 19 July 2014 04:22:15
Hi Andy. BigGrin
Fantastic looking planking as well as rest of build looking very professional and also overall a nice clean job.Cool Cool
Would have looked in more but us Newbies being involved only with SOTS and Victory mainly I've been following those builds. BigGrin
Great job mate. Cool Cool
George
Building HMS SOTS
#259 Posted : 19 July 2014 10:14:19
BigGrin Hi George
Thanks for looking in and your kind comments, i must say this ship is a little gem with the hardwoods provided and dont worry too much about looking in, your at a busy stage with the 1st planking and the learning curve can be high
#260 Posted : 20 July 2014 19:57:27
BigGrin Hi All
More progress on the triny, all the rubbing strips are now compleat on both sides of the hull some tidying up and sanding still needed here also the upper stern hardwood strip has been added above the cannon ports.
Still in the stern area the transom former has been glued in place and more hard wood strip used to fill in the stern bulwark.
At the bow the two latrines have been added after lining with bass strip wood and roofed with hard wood strip along with the two doors and handles.
Finally the holes for the catheads have been made and the catheads made up ready for glueing in position as they are just free floating for now.
More soon.
This page was generated in 0.215 seconds.
