21 Pages «<34567>»
John Passmore Options
John Passmore
#81 Posted : 25 June 2014 11:30:29
John Passmore wrote:
George1 wrote:
HI John. BigGrin
All looking really good mate. Cool Cool
As you say decking comes next with assembly parts as well. Decking should be easier with your infills giving you a profile to follow. BigGrin
Re the stern fitting of issue 15. There is still an assembly fitting with issue 16 to go in between end of 2nd deck and the assembled issue 15. So even more timber at the stern. BigGrin
Also good with that issue 15 assembly once glued after issue 16 goes in between, the whole piece can be turned upside down for bottom planking later because it will rest on assembly 15 and the bow piece without any rib frames coming into contact with surface.BigGrin
Keep up the great work. Cool Cool
George
PS Have sent you PM with list of planking available Float A Boat.BigGrin
Hi George
Thanks for the kind words, are you referring to deck planking or hull planking?
JohnP
G,day George
I've been discussing deck planking with Rhonda at Float-a-Boat and have decided to go with 1x4mm Basswood for trialing on the middle deck as per Mike Gandale's build which I admire greatley. I am as yet undecided on the method of caulking. I've ordered some 0.5mm black rigging twine and have got some thin black card sheet with which to cut 0.4mm strips from, a task which I think may be a bit beyond me, but I'll give it a go because Alan's deck looks terrific. I will also trial beveling and filling the joint with a B Pencil. All three methods can be trialled on the middle deck as most of it is unseen, and the preferred method will be used on the upper decks when the time comes.
JohnP
George1
#82 Posted : 26 June 2014 02:27:51
Hi John. BigGrin
There is another way some have used re caulking decking and that is to mix your pva with black paint and automatically look black between the deck planking. You can still use thin cardboard to keep planks just a smidgin apart for effect. I don't know how effective it would be but thought I'd pass it on to you as a possible method. BigGrin
George.
Building HMS SOTS
John Passmore
#83 Posted : 26 June 2014 04:38:26
George1 wrote:
Hi John. BigGrin
George.
G'day George
Yo! That gives me a 4th option which I shall trial on the second deck.BigGrin BigGrinCool . Thanks mate.
JohnP
jock
#84 Posted : 26 June 2014 04:54:37
Scale wise most of the methods produce over size chalking. I prefer to use a 4B or 5B pencil to run along the edge, when completed leaves a thin grayish black line
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
#85 Posted : 26 June 2014 07:10:15
BigGrin Hi All
You are correct that using thread or thin card will give an overscale effect to our models but its a catch 22 situation and its whatever your happy with.
I generally just use a pencil rubbed along the edges to get the effect needed, also if you have a look at Steve's and my own builds of the Santisima Trinidad you will see that using natural Danish oil actually darkens the edges of the planks and gives the impression of caulking.
bb1949
#86 Posted : 26 June 2014 09:35:01
Hi John, An interesting and enjoyable discussion on the caulking. A good range of ideas. I found marking the edges of the carpenters pencil effective although tedious. I found that a narrow rut in the carbon allowed the edge of plank to track although I sometimes wondered if a softer carbon would be more appropriate ie 2B as a opposed to HB etc.
I also liked Alan's suggestion about the caulking and the use of Danish Oil to highlight the caulk look.
As an experiment I used a permanent black market pen as an alternate applicator but found it less easier to control and its absorption into the grain gave a 'ratty' look.
On a more personal note I did reorder issue 8 because I was disappointed with my efforts with the skiff. This has since arrived and I am now in the process of doing it properly.
John Passmore
#87 Posted : 27 June 2014 13:49:15
Hi Jock, Andy and Brex
Thanks to all for the good advice. I will trial all methods for caulking, seems that the soft pencil may be the most effective as well as the simplest to useBigGrin Cool
I've ordered the planking but there is a delay in delivery - and as we all know W.A. stands for Wait Awhile - not West AustraliaLOL LOL
Regards to all
JohnP
John Passmore
#88 Posted : 25 July 2014 07:45:04
Hi All
Progress, July 2014 in pics below;
Hull planking was easier than I anticipated, but I found tapering them was a bit worrisome. BigGrin
I've done a bit of trial deck planking on the second deck - with a number of different caulking techniques. The black paper looks a bit too "heavy" and is difficult to control when installing. It's shown in the pic below the mast hole. The B pencil method whilst simple to apply, looks a bit scrappy (the section above the mast hole in the pic.) The 0.5mm black thread method is all at the stern end of the deck and looks a lot neater, but is very fiddly. I will do the tree nailing with a B pencil.Cool Cool
I had some bother with the first garboard planks - I didn't cut the bending grooves deep enough and so had to come up with a clamping solution, hence the little screw with washers until the glue cures.BigGrin BigGrin
Accidentally broke the top off rib 13 port flush with the deck, Blushing Crying, but luckily it broke quite cleanly in an almost perfect slot and keyway configuration so filled the slot up with glue and poked it back in - making sure it's at right angles. The hull planks on one side and dummy cannon support on the other will further reinforce it.
Now the dry dock is redundant I've made a temporary cradle using the previously installed fixing studs. The wing nuts make quick and easy to remove and refit.Cool Cool
JohnP
John Passmore attached the following image(s):
Whizgig
#89 Posted : 25 July 2014 08:07:44
wow looking fantastic John very neat work well done.BigGrin
#90 Posted : 25 July 2014 11:59:21
Well done John, looking good Cool
#91 Posted : 25 July 2014 12:06:42
George1
#92 Posted : 26 July 2014 04:13:58
Hi John. BigGrin
All looking very good mate.Cool Cool
See your decking with the black twine looks good. Cool Cool
Great work mate. Cool Cool
Looks like repair job on 13. If you check my thread I had to do repair on one rib as well. It turned out good as new. Just ensure clearance for next deck beam and deck when you brace it. BigGrin
George
Building HMS SOTS
#93 Posted : 26 July 2014 09:58:28
Nice work there John, love the build cradle.... Think you will find the tapering will become a lot easier as you progress into the build, the more you do the easier it will become... Decking looks really good and although using twine as with black card is a fiddly process, I think the results are well worth the effort. The deck you are working on will not be seen so use it as a practice session to perfect your technique and also to help you decide on how it is going to be finished in terms of colour/staining etc. Remember with the planking, let the strakes lie the way the want to and not force any into place, any gaps that appear can be filled with tapered pieces..... Cool Cool .. Look forward to seeing more...
Whizgig
#94 Posted : 26 July 2014 11:29:42
Wow amazing work john looking very niceBigGrin
John Passmore
#95 Posted : 27 July 2014 04:24:31
Hi Whizgig
Thanks for looking in and complimentary comment...BigGrin
(What's your proper name then?)Confused Confused BigGrin
JohnP
John Passmore
#96 Posted : 27 July 2014 04:28:03
Hi Mr T
Thanks for looking in and the complimentary comment. It's much appreciated coming from an expert...BigGrin
JohnP
John Passmore
#97 Posted : 27 July 2014 04:30:55
stevie_o wrote:
Neat work JohnBigGrin
Hi Steve
Thanks for looking in and the complimentary comment...BigGrin
JohnP
Whizgig
#98 Posted : 27 July 2014 04:35:13
Hi Whizgig
JohnP
I John its Eugene
John Passmore
#99 Posted : 27 July 2014 04:49:50
George1 wrote:
Hi John. BigGrin
George
Hi George
Thanks for looking in and the complimentary comment..BigGrin
I've repaired rib 13 in the 2nd of the photos. I saw your great repair job earlier but as my piece had snapped off almost flush with deck level, the use of bracings were not an option. I'm hoping that hull planking one side and dummy cannon support on the other will be sufficient reinforcement...Cool
The are a few errors in my trial deck planking, but rectification is not necessary as it's all covered in. Hope you find the pics useful when you start deck planking. I followed Mr Gandales' excellent tutorial from page 16 of his thread...BigGrin BigGrin Cool
The deck planking is Basswood, sourced from Float-a-Boat at about $8.50/pack. 1m lengths. Great stuff to work with - much easier than Bamboo! BigGrin BigGrin
JohnP
JohnP
John Passmore
#100 Posted : 27 July 2014 05:28:13
Hi Alan
Thanks for looking in and complimentary comments - much appreciated..BigGrin
Glad you like my rudimentary cradle - wouldn't pass muster at a cabinet makers' convention but serves purpose in this instance! LOL
You would have noticed several errors in my trial deck planking sequence, but I've not bothered to rectify as I know it will all be enclosed later. I've been considering the finish colour/staining and leaning towards NO stain colour and just a very light sanding to leave the bare boards. In my younger years I was a merchant seaman and one of my first ships was the old Stirling Castle (25,000 tons of oceanic splendour) built by Harland & Wolff Belfast - no air conditioning , no heating but beautiful lines. She had all Teak decks, including the well deck which was completely covered. The planks, (from memory) were about 8 inches wide and caulked (about a 1/4 to 3/8 inches thick) with a black tarry substance. These decks used to be scrubbed regularly by the deck crew with big stiff bristled brooms and big square stones using sea water pumped up through hoses. Then the decks were just left to dry and bleach in the sun. I'm sure that the old sailing ships' decks would have been treated in the same manner and looked very similar...BigGrin
I made a little jig to assist in cutting/shaping the hull planking. Works well. picture below.
21 Pages «<34567>»
This page was generated in 2.379 seconds.
