13 Pages «<45678>»
Jack.Aubrey's Soleil Royal Options
jack.aubrey
#101 Posted : 25 June 2014 09:21:53
Saturday April 21st, 2012
I spent these days emptying the inside of the boat, more in detail only the visible area, not the complete shell. This tasks may seem complex but in the reality it was quite simple, thanks also to the soft wood used for the boat skeleton.
To remove the wood I used the Proxxon minidrill with the tool shown here below :
and the following for the final cleanup :
Then I fixed the false frames, obtained from strips of mahogany veneer, and the bottom, from chestnut veneer. The result can be seen in the next images.
Cheers, Jack.Aubrey
jack.aubrey
#102 Posted : 25 June 2014 09:24:44
Thursday April 26th, 2012
I continue to post images of the work done for the ship boats . . here I introduce you the large boat with more details applied that some time ago. I don't think it is worth to comment the images.
There are still many details to finish. such as the rudder, oars, etc. and after some painting in selected areas. Then some reels of rope, a couple of buckets or casks and the boat should be considered complete.
jack.aubrey
#103 Posted : 25 June 2014 09:26:33
Monday April 30th, 2012
Hare some really "visible" news about one of the ship boat . . these news required some time to be achieved mainly due to the long time intervals waiting for the paint to dry. I added the rudder, the tiller and also some false pintles and gudgeons.
I have then mounted the oarlocks and now I'm trying to build the oars . . I'm using for them some components taken directly from the kitchen . . Cheers, Jack.
jack.aubrey
#104 Posted : 26 June 2014 12:47:01
Thuesday May 3rd, 2012
Here are the new elements I prepared in these last days: the oars for the first boat and a kind of boarding ladder that is positioned in number of two in the front side of the forecastle. Regarding this last element the instructions where for me unsatisfactory so I decided to use a different method.
Boarding ladders: here below are shown the instructions suppplied. As i said this method, given the small size of these elements, makes things very difficult to achieve the goal to have all of them equal and correcly positioned. I used an alternate way that I show here.
Full Size:
http://i46.servimg.com/u/f46/12/86/14/83/090-re10.jpg
First of all I made a special strip of wood made by the union of two different strips (4 x 1 and 2 x 2) glued together. Later I prepared a small table of veneer (mahogany), then I cut 10 steps (obtained previously) and I fixed them on the veneer all at the same distance. The day after, by using the table saw I cut a couple of ladders of the right width (8mm) and the boarding ladders were ready to be fixed in the proper place . . another way to use the table saw and another experience: I surely will use the same method when I will have to build the "true" boarding ladders on the two sides of the ship.
Oars: the raw materials are toothpicks, some strips of beechywood (0,5mm depth) properly shaped and paper. The oars are painted with the same colours of its boat. The total number of these oars should be 10 but I didn't build all of them: I made only four . . too much work . .
Cheers, Jack.Aubrey.
jack.aubrey
#105 Posted : 26 June 2014 12:50:51
Wednesday, May 9, 2012
I photographed the rudder pintles and gudgeons I scratch build long time ago. A big job that I mentioned a few posts ago. The rudder is not stained plywood but true solid mahogany.
See you next time, Jack.Aubrey.
jack.aubrey
#106 Posted : 26 June 2014 12:52:49
Thursday May 10, 2012
Tired of chasing the construction of the boats, I took a couple of "sabbatical" days and I enjoyed it to mount some superstructures in the bow and stern area. I had already prepared them long time ago. . in short, a slight deviation from the usual routine of last recent times.
Attached are some pictures of the superstructures under discussion. Unfortunately, the red color is not very "photogenic", as I have explained a bit of posts back.
Kind regards, Jack.
Gibbo
#107 Posted : 26 June 2014 17:46:11
Looking really nice Jack
jack.aubrey
#108 Posted : 27 June 2014 09:40:53
Wednesday, May 16, 2012
Two photographs to show the "big" boat practically finished. Probably when I'll have finished the little, too, I'll build a couple of buckets that I will place on the bottom.
I promised not to publish images of the "small" boat, until it was over, as in fact it would be a duplication of the construction process almost like the "great" boat, but I remembered that I missed an important step regarding the emptying process of the internal side of the hull, when the same was being detached from the building slip.
So I go further now to fill the gap showing the "small" with the third planking terminated with the interior emptied and ready for next steps.
Kind regards, Jack.Aubrey.
jack.aubrey
#109 Posted : 27 June 2014 09:43:06
Sunday, May 20, 2012
This is the "small" ship boat, largely completed. It is not really 100% finished because some small details (rudder, oars, coils of rope and dry) are missing, but the more, that is the hull as a whole, is finished. I must admit this boat came better than the "big" one and I think the best method would be to build a prototype, to make the necessary experience and then, enforced with this knowledge, build the final models. Obviously the time of their completion lengthens but the result improves.
Kind regards, Jack.
jack.aubrey
#110 Posted : 27 June 2014 09:45:00
Many thanks, Gibbo, your appreciations are welcome. Jack.
jack.aubrey
#111 Posted : 28 June 2014 10:20:51
Thursday, May 24, 2012 - Starting the installation of the guns
Now the time has come that I can no longer postpone the installation of the twelve guns on the upper gun deck. For this occasion, because there are no jobs that make dust or mess, I temporarily transferred the site at my house so that I can use all the useful moments to complete this activity that I remember often being long and tedious.
This morning I started with the positioning of the various pieces that will be placed on the upper deck: I drilled holes for fixing "pazienze" and "cavigliere" around the mainmast, I similarly prepared the holes for the joints for the structure to support the ship boats, and finally the holes to "nail down" the carriages of the guns, when it's time to fix them permanently.
And now this deck, as of now empty, is "magically" filling up. .
From a very early consideration there are three aspects to keep in mind:
1) in the images are visible five guns per side, the sixth is almost hidden under the half-deck above. This trolley and its cannon can not be fixed by a metal pin as it is not possible to bore the necessary hole. In addition, the fitting of the same is virtually impossible, unless contortions and acrobatics think out of my reach (and patience). If we consider that when you apply the gangways these two guns will be almost invisible, I think I will just paste them on the deck using the glue which I think is the most suitable for this type of bonding: two-component epoxy glue. It take long time to dry, but on the other hand are as strong as, and perhaps more of Attack and less sensitive to sharp blows that cause the release of Attack.
2) Similarly, the pair of cannons on the right are partially covered by the forecastle, but here the work is easier: first can be fixed with the pin and also the fitting is possible, at least for the exposed side.
3) The structure for the housing of ship boats, positioned as instructed by De Agostini, is a place that hinders the operations of the second pair of cannons on the right. And so I'm gaining seriously consider the idea of moving it to about 10/12 mm to the left. The problem is that I have no idea from the instructions in my possession, if the area would go to be  occupied partially, that is marked in the black box below, you will have to accommodate other superstructures. The plans Sergal would seem an area free, apart from the ladders to access the decks. .
Cheers, Jack.Aubrey
jack.aubrey
#112 Posted : 28 June 2014 10:22:47
Saturday, May 26, 2012
Today I returned to work with the guns. I'm at a stage of the assembly of the guns that I define "intermediate", there is still a lot of work to do but the more critical activities and requiring precision can be considered concluded.
In practice, all trucks have been fixed to the deck below by means of a brass pin that runs through the base of the truck and slips into a hole in the deck. The whole thing is secured with four drops of Attack Gel under each wheel and also the pin is glued to both the truck and the deck. . the pin head can be seen in the images in high resolution.
Sincerely, Jack.Aubrey.
jack.aubrey
#113 Posted : 28 June 2014 10:24:27
Monday, May 28, 2012
New progresses with the guns assembly on the deck . .
See you next message . . Jack.
jack.aubrey
#114 Posted : 28 June 2014 19:02:21
Tuesday, May 29, 2012
Yet another small step forward. .
In my opinion the curls of rope made ​​in this way, although technically sound, are still lower in fact of realism as to how I made on the Santisima Trinidad's cross section . . only problem that it took an incredible amount of time, while this method was faster . .
03 Santisima Trinidad/P1070589.jpg
Gibbo
#115 Posted : 29 June 2014 02:23:02
Looking good Jack
jack.aubrey
#116 Posted : 29 June 2014 09:34:53
Tuesday, May 29, 2012, afternoon. . finished.
During the early afternoon, taken by a fit for modeling, I threw in the assembly of gun barrels. Operation seemingly simple and fast if it were not for the preparation of the recoil rope: the two ends of the rope are linked to an eyebolt, at an equal distance for all the guns since they are all positioned not ready for firing, the eyebolts are then inserted in a pre-drilled hole in the internal side of the handrail (?) and secured with a drop of cyano.
The gun barrels are also glued to the gun trucks with a couple of drops of Attack Gel.
I am considering whether to apply a strip of carborundum black sandpaper over the two pins on the side of the gun barrels, where they are cradled in the truck, but I don't know if it's worth or not. This because these details will most probably remain invisible when I'll mount above the gangways (?). But the fact of knowing that they are there. . . even if you do not see them, it must probably mean something to a modeller.
Finally, to be able to say 100% finished, I have to apply a coat of black paint in the thickness of the gunports of these twelve guns, an operation that normally would have to be done right before, but I forgot it !!
At this point I'm very happy because this was a job that was blocking other works on the hull, and that took me a long period of  time to complete.
jack.aubrey
#117 Posted : 29 June 2014 09:37:45
Friday, June 1st, 2012 - Gangways
This afternoon I installed the two gangways that were ready for a while and I could not fit in place before the installation of the guns on the upper deck.
I obviously had to perform a minimal adaptation and then I proceeded to glue these two pieces exactly on top of the guns that I just finished to setup. To fix these two new objects I used vinyl glue, being careful to avoid any "accidentally touch" to the guns below.
A few days ago I wrote that fixing the gun barrels to their truck "is a matter of seconds" by using the cyan-acrylate glue.
Never such a sentence was more wrong !!. . while I didn't touch at all the guns with anything, to fix the gangways I had to plant three "practically invisible brass nails" per side and this revealed the main "weak point" of the cyan-acrylate glue: the 15/20 hammering (with a very light hammer) that I had to give it to plant the brass nail were enough to detach almost all of the barrels of the guns from their carriages . .
Nothing irrecoverable, luckily. I can repeat this bonding in each case, may be with additional difficulties vs the past but I think this experience should be highlighted to make clear to those who 100% believe in this glue that it is not always the best solution, even if using the gel form. Now, thanks to this experience, when the right time comes I will use the two-component epoxy glue: it is much longer to dry than the cyan-acrylate but the seal and especially the resistance to impacts, at least to fix the gun barrels, should be totally different and much more better.
My mind goes to the installation of all the metal sculptures on the stern. . Cyan-acrylate or two-component epoxy? And after years what happens? I have experience of models I made ​​many years ago that every time I wipe them, I have to bond some pieces of metal that comes off: pieces bonded with the cyan-Acrylate . .
Comments?
All the best, by Jack.
jack.aubrey
#118 Posted : 29 June 2014 14:51:53
Sunday, June 3, 2012 - Gangways
As I wrote earlier I installed the gangways above the guns; they were ready some time ago. I set them in place with a particularly sophisticated bonding so that we can safely say that they are proof of "catastrophic events".
The guns you see in these images are placed as if they were fixed, in the reality they are only positioned due to the well-known incident, I put them in place for photographic needs only.
I'm considering putting some columns below the gangways, I'll see what to do later, probably after having repaired again the barrels of the guns.
I connected the two "mini" wales of the forecastle and stern area so that now they seem as one single piece. .
Finally, I apologize for the mess in this picture, but I shot the photos in the lab and unfortunately there is a bit of mess on the working  table. . .
jack.aubrey
#119 Posted : 29 June 2014 14:54:20
Wednesday, June 6, 2012
These days I applied myself to build all the stairways and ladders available on the Soleil Royal. I experienced also a variation in the construction of the ladders that allowed me to build them, let's say, in "mass production". In addition I designed and implemented a totally personal way to build the four "low" ladders connecting the gangways to forecastle and quarterdeck. I really like this solution, more realistic. At the moment I do not have pictures, but you'll see them in due time.
Now I am left with essentially three jobs before embarking on a major new enterprise: re-glue guns, fix some new elements around the mainmast, paste all the stairways and ladders that I painted for the occasion in blue.
After this point, more or less a matter of few hours, I will devote myself to the building of the poop.
It's a while I think what to do at this point and I came to conclusion that it is better for me to concentrate in the building of infrastructures and galleries of the poop, maybe finishing it completely, but surely coming to a point at least which I will no longer need to heavily manipulate the hull to perform the work. The objective is to leave the finish of the gunwale at that point, when you can work without tipping too the hull thus avoiding possible breakage.
Today I have collected all the material for the components of the poop and I studied very carefully all the instructions for its construction. I must become confident with the whole process, because I have in mind a set of possible variations that intrigue me very much. Finally, to take help from other modelers, I downloaded all the images of the poop of the modelers who have already built it . . a small advantage to stay a little back and let others go ahead to open the track . . images that will be very useful to keep in mind the point of arrival!
See you soon, Jack.
jack.aubrey
#120 Posted : 30 June 2014 09:03:52
Monday, June 11, 2012
In these past days I focused myself on the study, the material collection and the initial operations planning for the tasks related to the building of the complex poop of this ship, more in detail I studied how to prepare and mount the three galleries.
The material provided by De Agostini for these tasks is quite dissimilar in quality: some pieces are of good quality, while others are less if not worse. . it is a constant problem in these partworks: often between an issue and the next the quality of a similar piece is totally different. In this case there are only two possibilities: 1) to request De Agostini to re-ship the whole issue (losing roughly three weeks) or 2) rebuilding the wrong/bad piece with a better material. In my case, however, the quality is not as important because all the "bad" pieces will later be hidden.
Once mounted the floor of the lower and middle galleries I had to adapt them to the shape of the hull so that they fit perfectly in their final position . . evaluate it, change eventually a bit and try again. . until the piece is OK.
Then I proceeded to plank the top of the floor with strips similar to those used for the decks, I remember that decks on this model are in beechwood.
To fix the floor I used the vinyl glue but, for safety, I also put in place four pins of metal.
This gallery should be aligned with the fourth wale (from the bottom) and, thanks to the inexistent drawings and to the instructions where you were not told to take a particular care, I discovered that, to maintain the ideal sheer of the wale, the floor appears to be in a higher position of a few millimeters than it should be. . . The picture below shows this gap. Obviously at this point the remaining two galleries will also be located higher with possible implications not currently quantifiable. However I was expecting similar situations. In due time I will see how to manage the problem.
Finally, a personal interpretation of the positioning of the ladder to access the "higher" deck (I do not know how to call it exactly): in that position, I thought to locate a door. But now I can't put in front of the door a staircase. . (again, some drawings of the model would certainly have helped).
So I thought to correct the error by moving the ladder back and here explained the need of this small platform added now and protruding.
I imagine the reactions of the "purists", in this case being them totally right, but these  situations are recurrent with these partworks . . linked with other amenities such as instructions sometimes lacking of clarity and the chronic absence of drawings.
About drawings: if I can imagine and understand why drawings are not published for these kind of kits, from another point of view it would be enough some sketches, of proper size, showing particulars or even prospective views similar to the one in the Soleil Royal model plans from Panart (Mantua) and more precisely the table No. 4. Such views cannot be used as plans themselves, then would meet the needs of the publisher, but they would be incredibly useful to the modelers . .
After these amazing discussion on materials and plans, I greet you and wish you a good day. Jack.Aubrey
Guest (5)
13 Pages «<45678>»
This page was generated in 0.347 seconds.
