162 Pages «<130131132133134>»
#2621 Posted : 22 June 2014 22:30:40
jonny7england wrote:
She's a real beauty Alan...You must be over the moon with her mate...
Love ThumpUp
Thanks for the wonderful comment Jonny and yes, I am really happy with how she is progressing... really starting to apply the detail to her now and when finished I think I can be proud of her.... Cool Cool .. Hope it all works out....
Thanks again and regards
#2622 Posted : 22 June 2014 22:31:27
stevie_o wrote:
Beautiful work AlanBigGrin
Thanks Stevie, appreciated.... Cool Cool
#2623 Posted : 22 June 2014 22:32:11
tf64 wrote:
Hi Alan,
Top work from a top builder good idea with the pins it just gives it a better fix great stuff Alan.
Trev
#2624 Posted : 22 June 2014 22:35:18
tf64 wrote:
Hi Alan,
Trev
Thanks for the fab comments Trev, always appreciated.... Cool Cool .. Wouldn't class myself as a top builder though, don't have enough modelling experience for that accolade.... just simply trying to do the best I can and so far all seams to have worked out very well..... Cool Cool .. Thanks again....
George1
#2625 Posted : 24 June 2014 02:52:49
Hi Alan. BigGrin
As I've said before it's always a great pleasure looking in on your progress.Cool Cool
Great too that you post pics regularly so we can follow your build as it progresses and enables us to pick up very valuable tips on the way. Cool Cool
Love what you've done to date. Cool Cool
George
Building HMS SOTS
#2626 Posted : 25 June 2014 06:42:08
BigGrin Lovely work as always Alan coming along a treat rgd Martyn
#2627 Posted : 26 June 2014 23:22:30
George1 wrote:
Hi Alan. BigGrin
George
Thanks George for looking in and commenting.... Will continue to post plenty of pics until the build is complete..... If they help you and others then it will be all worthwhile.....Cool Cool
#2628 Posted : 26 June 2014 23:23:31
Thanks Martyn, appreciated....Cool Cool
#2629 Posted : 29 June 2014 14:59:42
Issue 95 completed today.... Nothing new on this one, simply the adding of Seahorse decorations down the port side, layering the chainwale platforms and fitting into position... Again the platforms are held simply by pins, to be securely fitted later.... Cool Cool
#2630 Posted : 29 June 2014 16:29:44
BigGrinLooking goodCool
#2631 Posted : 29 June 2014 17:05:35
#2632 Posted : 29 June 2014 22:10:31
Thanks Andy....
#2633 Posted : 29 June 2014 22:12:24
stevie_o wrote:
Beautiful ship Alan, really looking goodBigGrin
Thanks Stevie, am please you like it... Cool Cool .. Back to second planking layer on the Titanic which is taking longer than I thought it would.....Huh Huh Blushing Crying
KobusBeukes
#2634 Posted : 30 June 2014 21:46:25
Hi Alan
Haven't looked in for a while, wow your progress is fantastic! Love
Kobus
Current Build
HMS Sovereign of the Seas - First Build
#2635 Posted : 01 July 2014 00:13:28
KobusBeukes wrote:
Hi Alan
Thanks Kobus for those kind words, appreciated.... Cool Cool .. Great to hear from you again and hope to see you back on your build soon....
#2636 Posted : 05 July 2014 20:47:53
Hi all, issue 96 completed today. Started by cleaning out the holes in the deadeyes using a 1mm drill in a pin vice... sanded the deadeyes smooth then gave them 2 coats of walnut stain... Cool . Cut the brass wire and chain into lengths as per the mag instructions and blackened using blacken-it solution, degreasing the pieces first of course... Found with the chains I had to leave them in the solution overnight, on removal there was a dusty film that was simply removed using a fairly stiff paint brush... When happy moved onto making up 12 deadeyes as per the mag instructions... Cool Cool.. Next step was to make up the strip that attaches to the front edge of the chainwale platform and this piece also had to be layered with walnut, a fiddly process but worked out very well... Using a blob of superglue gel in each slot I then fitted the deadeyes into position followed by gluing the front strip in place...Cool Cool The front edge of the platform was then given 2 coats of gold paint and the whole piece was coated with 2 coats of satin varnish before finally gluing in place on the hull.....Cool Cool . All in all a time consuming process but am very happy with the end results.... Cool Cool .. Happy building all....
#2637 Posted : 05 July 2014 22:03:25
Hi Alan.
A really nice job on those chainwales, I can remember doing them on my Grimsby and Bounty, one of the more fiddly exercises, especially when going the whole hog and lining the edges too!Cool
The next main job on the Victory will be her channels when I get back to her - aw poo!
Keep it up M8, a superb looking girl taking shape beautifully!BigGrin
Robin
#2638 Posted : 05 July 2014 22:56:32
Plymouth57 wrote:
Hi Alan.
Robin
Thanks for looking in Robin.... I thought about going the whole hog and actually lining the edges too but then I thought with so much gold bling on this girl the painting of the edges wouldn't look out of place... am pleased I went with the paint option..... Cool Cool .. Thanks again and look forward to seeing you back on your Vic too....Cool Cool
der Gohfelder
#2639 Posted : 05 July 2014 23:04:31
Hi Alan!
Like always - a very nice work, I like it!ThumpUp
Regards, Bernd
#2640 Posted : 05 July 2014 23:11:56
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Thanks as always for looking in and commenting Bernd, always appreciated..
Guest (5)
This page was generated in 0.644 seconds.
