John Passmore wrote:Hello Alan
Thanks for the info re the deck planking. It's very informative and means I can start shopping around looking for materials, which in some cases are hard to get in Oz. (I'm even having trouble sourcing burnishing/blackening fluid!)
Kind regards JohnP Hi John, hope you are able to find a supplier for the materials you are looking for.... Regards Alan
Work continues with issue 94 but here is what I have decided to do with the chainwales... I have never been a lover of painting anything sapele colour and with the chainwales that is no different..... I started by cleaning up the edges and with a fine file and ensured I had a good fit to the hull...  .. With care, I drilled 0.6mm holes in the edge of the piece, cut the heads off some pins and superglued them in place, wanting to ensure a secure fit to the hull.... When happy, decided to use some spare walnut strips I have left over from the hull planking and covered both sides of the chainwales, filing out the notches and drilling out the 2 holes... fine sanded when finished and gave the piece 2 coats of satin varnish.... Finally painted the two end edges with two coats of gold....  .. Am very pleased with how it has turned out so will get to work on the other two chainwales tomorrow and over the weekend.... Chainwale has not yet been glued in position, simply held there by the pins, will be glued later in the build......  .. Happy building all... Regards Alan Gandale attached the following image(s):
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Alan! A very nice work and a good idea to use the pins! Regards, Bernd
der Gohfelder wrote:Hi Alan! A very nice work and a good idea to use the pins! Regards, Bernd Thanks for looking in and commenting Bernd..... Regards Alan
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Looking good Thanks Andy Regards Alan
Your ship is looking fantastic, i'm looking forward to starting mine and i'm keeping a very close eye on yours, reading and re-reading your build. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Gibbo wrote:Your ship is looking fantastic, i'm looking forward to starting mine and i'm keeping a very close eye on yours, reading and re-reading your build. Thanks Gibbo, appreciate the kind comments and you taking the time to look in.... It pleases me to know you are enjoying the build and hope this diary will give you some ideas when you start your own.... Hope to see a build diary from you so we can track your progress.... Thanks again Regards Alan
Finished layering the two remaining chainwale platforms with walnut, stained, varnished and finally fitted to the hull.... These are only held in place with the pins I inserted into the platform edges, intention is to glue them in place when I have the chainwales in place, I think it will make the process of fitting the chainwales easier....  Happy building all.... Regards Alan Gandale attached the following image(s):
Gandale wrote:.... These are only held in place with the pins I inserted into the platform edges, intention is to glue them in place when I have the chainwales in place, I think it will make the process of fitting the chainwales easier....
Hi Alan! A good decision, I´m sure there are some wooden strips to be fixed at the outside of the platforms! Regards, Bernd
der Gohfelder wrote:Gandale wrote:.... These are only held in place with the pins I inserted into the platform edges, intention is to glue them in place when I have the chainwales in place, I think it will make the process of fitting the chainwales easier....
Hi Alan! A good decision, I´m sure there are some wooden strips to be fixed at the outside of the platforms! Regards, Bernd You are spot on Bernd, there are wooden strips to be fitted to the front edge yet and this was one of the reasons why I decided not to glue them in place yet but to fit the chainwales including the front strips... easier off the ship....  .. Thanks for looking in and commenting.... Regards Alan
As ever, neat work Alan
Tomick wrote:As ever, neat work Alan Thanks for the kind comment Mr T, appreciated.. Regards Alan
Just gets better and better Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
She's a real beauty Alan...You must be over the moon with her mate...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Beautiful work Alan Steve
Hi Alan, Top work from a top builder good idea with the pins it just gives it a better fix great stuff Alan. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
jase wrote:Just gets better and better Jase Thank you very much Jase. Considering you are a modeller that applies so much care, attention and detail to your builds then your comment makes my efforts so worth while......  .. Thanks again.... Regards Alan
