21 Pages «<23456>»
John Passmore Options
MichaelKan
#61 Posted : 08 June 2014 16:09:25
Rank: Amateur Level 1
Hi John,
Beautiful work.
Michael
John Passmore
#62 Posted : 10 June 2014 11:21:08
MichaelKan wrote:
Hi John,
Beautiful work.
Michael
Hi Michael
Thanks for looking in and the nice comment.
JohnP
bb1949
#63 Posted : 11 June 2014 11:57:51
I think you have done very well. Top work. Brex
John Passmore
#64 Posted : 20 June 2014 04:34:14
Hi Brex
Thanks for looking in and kind words. Another progress report is on the way.BigGrin
JohnP
John Passmore
#65 Posted : 20 June 2014 04:47:12
Hi Everyone.
Here's progress report #2 June 2014
Lower deck installed. Had a bit of bother aligning Rib 13 starboard side with the deck slot. The rib was warped forward slightly (approx 5deg) so I made a ram with a piece of dowel against the base of frame 2 and carefully slid the other end down rib 13 until it was perpendicular. The rest of the deck then installed easily. Rib 13 is still slightly off and will probably give me a bit more heartburn for the second deck.Glare
Here's the pics of the deck installed;
John Passmore attached the following image(s):
John Passmore
#66 Posted : 20 June 2014 05:06:44
Preparing to install second deck.
I've fitted additional supports under the deck beams. Started with scrap pieces of 5mm balsa but found too fiddly and they persisted in falling over. The dowels were much easier to prepare and instal.
I was a little concerned about the integrity of the false cannon supports once drilling holes for the cannon commenced, so I've added buttresses behind each rib for extra strength.
There was a gap between the deck and beam at frame 22 so I added an extra beam as a packer so the deck now has full bearing on the relevant beams.
Note the use of my trusty brick pavers to weigh it all down.BigGrin
Here are some pics;
John Passmore
#67 Posted : 20 June 2014 05:19:38
And finally here's the stern assembly completed (issue15).
I think it has been corrected where struts 45 meet the upper deck 42, as there was no need for the little packers per Mr T's build. All went together without a problem.
I've decided not to do balsa infills between frames 26 and 27 - there is so much wood in there it doesn't seem necessary.
That's all for now, bring on the planking!!!BigGrin BigGrin BigGrin
Regards to all
JohnP
George1
#68 Posted : 20 June 2014 05:49:23
HI John. BigGrin
All looking really good mate. Cool Cool
As you say decking comes next with assembly parts as well. Decking should be easier with your infills giving you a profile to follow. BigGrin
Re the stern fitting of issue 15. There is still an assembly fitting with issue 16 to go in between end of 2nd deck and the assembled issue 15. So even more timber at the stern. BigGrin
Also good with that issue 15 assembly once glued after issue 16 goes in between, the whole piece can be turned upside down for bottom planking later because it will rest on assembly 15 and the bow piece without any rib frames coming into contact with surface.BigGrin
Keep up the great work. Cool Cool
George
PS Have sent you PM with list of planking available Float A Boat.BigGrin
Building HMS SOTS
AdamHall
#69 Posted : 20 June 2014 07:05:05
Hi John,
Fabulous work. The deck supports are a benefit with the additional weight being applied when installing the second middle deck.
That said, there seems to be a common trait whereby there are some significant weighted objects being placed on the second deck. On my build I have only done a dry fit. For mine, whilst the join between the centre and aft deck sections are flush, between the fwd and centre sections I have a 2mm step. I need to apply a heavy object a the end of the fwd deck piece to achieve a decent join. This is despite the lower deck being flush. I will post pictures in my build log this evening (I'm currently at work and checking into the forum on my lunch break).
So, I'm not sure whether other members have used heavy weights because of similar issues.
Again, great progress with your build.
Adam
John Passmore
#70 Posted : 20 June 2014 08:16:38
George1 wrote:
HI John. BigGrin
George
Hi George
Thanks for the kind words, are you referring to deck planking or hull planking?
JohnP
John Passmore
#71 Posted : 20 June 2014 08:30:15
AdamHall wrote:
Hi John,
Adam
Hi Adam
Thank you for looking in and your kind comments.
The only reason I used heavy weights is because the centre deck sections were a bit woofy (slightly wavy) and I wanted to make sure everything was bearing 100% and nice and flat.
It seems your forward sections must be warped if there is a step (at rib 13 I assume?) and the lower deck is flush...I can't think of any other reason.Confused Confused.
Good idea to post some pics and lets have a look, maybe the experts will have a remedy.Cool
JohnP
George1
#72 Posted : 20 June 2014 08:39:35
John Passmore wrote:
George1 wrote:
HI John. BigGrin
George
Hi George
JohnP
Hi John. BigGrin
Re planking; The list I sent you PM is suitable for both because of different sizes re thickness and width re different woods. You'll find that when we actually get deck planking it is 5mm wide of Basswood/Lime so some builders like Gandale (Alan) have gone for 4mm as feels looks better when you consider 1/84 scale would make 5 mm decking 42 cm wide where 4 mm equals about 33 cm which is just over a foot wide and 3 mm equals 25 cm or 10 inches. So it's really up to the individual model builder what they go for. I will be going for the 4 mm as I liked the look of Alan's decking so will have to purchase. BigGrin
The list is also suitable for hull planking re sizes if you decide to go for different coloured timber than supplied re staining later or whether you intend to paint and it won't matter. BigGrin
Hope that's of some help. BigGrin
George
Building HMS SOTS
#73 Posted : 20 June 2014 10:27:34
the deck you are referring to has a slight slope either end,so some weight needs to be applied so that the deck sits on it's support beams.but be careful not to overdo the weights, or a saggy bottom occurs,Crying BigGrin
#74 Posted : 21 June 2014 22:43:13
Progressing really well John, she's really starting to take shape now and won't be long before you fit the first plank,,,, Cool Cool .. Keep posting, will be following with interest....
John Passmore
#75 Posted : 22 June 2014 05:44:27
Hi Karl
Yes you are right, and thank you for the timely advice. However, I would not use such heavy weights if not for the balsa infills which make the hull very strong and sturdy. I am very attached to the lady and would never treat her roughly!!! BigGrin BigGrin
Kind regards
JohnP
John Passmore
#76 Posted : 22 June 2014 05:58:16
Hi Alan
Thank you for visiting and your kind comment. Yes I'm very happy with progress of the ship so far but I'm not too happy with my effort with the ships' boat. I have painted it in accordance with Mr T's diary but as my planking is so lumpy the maroon has leached under the masking tape and into the ivory white. If I can't rectify it I'm considering tossing it in the bin and back ordering issue 7 to start again. Blushing Angry Blushing
JohnP
#77 Posted : 22 June 2014 09:14:51
BigGrin Hi John
Very nice work so far and looking good.
As for your problem with paint leaching under your masking tape, try this.
Paint the ivory white as per normal then use masking tape to mask off, note use a good masking tape like Tamiya's, yes I know its expensive but it works that's why you pay more for it Blink LOL.
Then after masking use some ivory white paint and paint the edge of the masking tape, this should seal the edge and prevent any leaching under it and give you that nice straight edge. After it is dry paint with the maroon paint, another tip here is to always paint away from the edge of the tape never brush down into the edge. Hope this helps
#78 Posted : 22 June 2014 11:05:08
Andy's advice should sort your problem, only thing I would add is to ensure you have pressed the tape down so you have good contact along the edge. I use a small aft pencil eraser for this. then seal it as Andy says.
John Passmore
#79 Posted : 22 June 2014 13:30:09
arpurchase wrote:
BigGrin Hi John
G'day Andy
Thanks for the great tips. I shall certainly follow your recommendations and let you know the result.
(I still reserve the right to chuck it in the bin if I'm not happy with it!!!). LOL BigGrin BigGrin
JohnP
John Passmore
#80 Posted : 22 June 2014 13:37:01
G'day Jase
Thanks for looking in and the useful tip. The main problem is, I think, the hull of the ships boat is not smooth enough. Knowing this, I sanded and filled it where possible but it's still a little bumpy. I'll certainly try your little trick with the eraser.BigGrin
JohnP
21 Pages «<23456>»
This page was generated in 0.281 seconds.
