162 Pages «<129130131132133>»
#2601 Posted : 19 June 2014 22:22:43
John Passmore wrote:
Hello Alan
Thanks for the info re the deck planking. It's very informative and means I can start shopping around looking for materials, which in some cases are hard to get in Oz. (I'm even having trouble sourcing burnishing/blackening fluid!)
Kind regards
JohnP
Hi John, hope you are able to find a supplier for the materials you are looking for....
#2602 Posted : 19 June 2014 22:33:05
Work continues with issue 94 but here is what I have decided to do with the chainwales... I have never been a lover of painting anything sapele colour and with the chainwales that is no different..... I started by cleaning up the edges and with a fine file and ensured I had a good fit to the hull... Cool Cool .. With care, I drilled 0.6mm holes in the edge of the piece, cut the heads off some pins and superglued them in place, wanting to ensure a secure fit to the hull.... When happy, decided to use some spare walnut strips I have left over from the hull planking and covered both sides of the chainwales, filing out the notches and drilling out the 2 holes... fine sanded when finished and gave the piece 2 coats of satin varnish.... Finally painted the two end edges with two coats of gold.... Cool Cool .. Am very pleased with how it has turned out so will get to work on the other two chainwales tomorrow and over the weekend.... Chainwale has not yet been glued in position, simply held there by the pins, will be glued later in the build...... Cool Cool .. Happy building all...
der Gohfelder
#2603 Posted : 19 June 2014 22:55:01
Hi Alan!
A very nice work and a good idea to use the pins! ThumpUp
Regards, Bernd
#2604 Posted : 19 June 2014 23:08:46
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Thanks for looking in and commenting Bernd.....Cool Cool
#2605 Posted : 19 June 2014 23:20:30
BigGrin Looking goodCool
#2606 Posted : 20 June 2014 01:13:40
Thanks Andy
Gibbo
#2607 Posted : 20 June 2014 01:55:20
Your ship is looking fantastic, i'm looking forward to starting mine and i'm keeping a very close eye on yours, reading and re-reading your build.
#2608 Posted : 20 June 2014 19:13:43
Thanks Gibbo, appreciate the kind comments and you taking the time to look in.... It pleases me to know you are enjoying the build and hope this diary will give you some ideas when you start your own.... Hope to see a build diary from you so we can track your progress....Cool Cool
Thanks again
#2609 Posted : 21 June 2014 22:33:25
Finished layering the two remaining chainwale platforms with walnut, stained, varnished and finally fitted to the hull.... These are only held in place with the pins I inserted into the platform edges, intention is to glue them in place when I have the chainwales in place, I think it will make the process of fitting the chainwales easier....Cool Cool Happy building all.... Cool Cool
der Gohfelder
#2610 Posted : 21 June 2014 23:03:15
Hi Alan!
A good decision, I´m sure there are some wooden strips to be fixed at the outside of the platforms!
Regards, Bernd
#2611 Posted : 21 June 2014 23:08:33
Hi Alan!
Regards, Bernd
You are spot on Bernd, there are wooden strips to be fitted to the front edge yet and this was one of the reasons why I decided not to glue them in place yet but to fit the chainwales including the front strips... easier off the ship.... Cool Cool .. Thanks for looking in and commenting....
#2612 Posted : 22 June 2014 09:18:21
#2613 Posted : 22 June 2014 10:35:02
Thanks Andy
#2614 Posted : 22 June 2014 10:50:20
As ever, neat work Alan Cool
#2615 Posted : 22 June 2014 11:00:39
Thanks for the kind comment Mr T, appreciated.. Cool Cool
#2616 Posted : 22 June 2014 11:07:48
Just gets better and betterLove Love
jonny7england
#2617 Posted : 22 June 2014 11:54:04
She's a real beauty Alan...You must be over the moon with her mate...
Love ThumpUp
#2618 Posted : 22 June 2014 12:10:15
#2619 Posted : 22 June 2014 14:14:00
Hi Alan,
Top work from a top builder good idea with the pins it just gives it a better fix great stuff Alan.
Trev
#2620 Posted : 22 June 2014 22:27:17
Thank you very much Jase. Considering you are a modeller that applies so much care, attention and detail to your builds then your comment makes my efforts so worth while...... Cool Cool .. Thanks again....
This page was generated in 0.357 seconds.
