6 Pages «<3456>
Panart Section Deck Between Gun Bays 1:23 Options
#81 Posted : 30 April 2014 19:36:48
BigGrin Lovely work Andy stunning build BigGrin Rgd Martyn
#82 Posted : 30 April 2014 19:44:28
BigGrin Hi Martyn
Thanks for looking in and your comments always appreciated
#83 Posted : 30 April 2014 19:50:27
BigGrin Hi All
I have now put together one of the gun carriages and gave it a coat of undercoat then a base coat of matt black, these are only the wooden parts apart from the wheel retainers and the central block where brass rod has been used. There is more in the way off metal fittings to be added yet and I may finish off with a coat of semi-gloss black to give a more pitch type look.
More soon
#84 Posted : 26 May 2014 19:20:49
BigGrin Hi All
I havent forgot this build but its more of a side build than a current one. I have been making up the central table and benches plus the storage racks. Finaly I added the cross beam. More soon
#85 Posted : 26 May 2014 22:08:34
Looking good Andy....Cool
#86 Posted : 26 May 2014 22:13:54
BigGrin Hi Alen
der Gohfelder
#87 Posted : 26 May 2014 22:37:23
Hi Andy!
A very nice work you made, well done!
Regards, Bernd
#88 Posted : 27 May 2014 03:27:04
BigGrin Hi Bearnd
#89 Posted : 14 June 2014 18:23:51
BigGrin Hi All
Some more progress on the deck the shelve's, benches and table have been fitted and the rear main formers cut away as the six pillars have been fitted that make the edge part redundant . Also the decking has been run up to the edge. More soon
#90 Posted : 14 June 2014 21:24:25
Hi Andy
Just a great build you have thank you for posting,you can imagine that you are in side your build.
Regards Trev.
#91 Posted : 14 June 2014 21:29:45
der Gohfelder
#92 Posted : 14 June 2014 21:41:59
Hi Andy!
A very nice work, I really like it! Can you post a pic with a ruler to see the dimensions?
Regards, Bernd
#93 Posted : 15 June 2014 15:16:53
BigGrin Hi Trev
Thanks for looking in and your comments there is still loads more detail to add and I think the best way to do this build is to work outwards from the inside And your right about it drawing you in to it.
#94 Posted : 15 June 2014 15:17:51
BigGrin Hi Steve
#95 Posted : 15 June 2014 15:23:27
BigGrin Hi Bernd
Thanks for you comments and looking in ,as asked for here are a couple of pic's with a ruler .As its hard to see the size is aprox 255 mm square or 10 inches square in old imperial. So not too big but still a nice size.
#96 Posted : 15 June 2014 16:13:16
Hi Andy, BigGrin
Good to see the start of the detail. Cool
Was it difficult to install the table and benches?, as it looks like you don`t have much room to play with.
Looking forward to the next installment.
der Gohfelder
#97 Posted : 15 June 2014 17:39:47
arpurchase wrote:
BigGrin Hi Bernd
Hi Andy!
Thank you very much for the new pics! Well, I think it´s a very good size! Not too big for a good presentation, not too small to make a lot of details!
Best regards, Bernd
#98 Posted : 15 June 2014 18:39:23
BigGrin Hi Derek
The main deck is around 10 inches square the height in between the formers is around 3 and a half inches so quite manageable and I have big hands. I just think that its easyer to work from the centre outwards in this build. The table is held in place at the hull end by a brass pin the other end by a rope and hook so quite easy to fit and thanks for looking in and your comments.
#99 Posted : 15 June 2014 18:44:56
BigGrin Hi Bernd
Glad to be of service and your right its the perfect size really. Thanks for looking in
#100 Posted : 16 June 2014 21:17:51
BigGrin Hi All
A little bit more done, the cannon ball racks have been added and the eyebolts to the deck for lashing the cannon. More soon.
6 Pages «<3456>
