A Saturday very well spent Options
thomasmoult
#1 Posted : 07 August 2010 19:28:46
Finished my launch a while ago but have since always felt something wasn't quite right with it. At last I got myself together and took the plunge to 'refurbish' the areas I wasnt happy with. Firstly, I never did see eye-to-eye with those duckboard grates, so they were the first to go. I replaced them with a thin decking to match the main deck boards in the middle.
The anchor that came with it, I replaced with a scratch built new stock from small bits of mahogany and just used the actual anchor, building it in the same way as the big Victory anchor. However, this also went because I didn't think it was the right scale in relation to the boat. I have been following the discussions on here regarding the scratch-built grapples, so thought I'd have a go myself!
Next I attached a ring and some tread and did it up as best I could, then finally attached the grapple to the coil of 'rope' i had before (sneakily burying it in so it all looked like one piece.)
Please have a look at my photos; having trouble uploading them directly onto here.
http://img198.imageshack.us/g/imgp6559k.jpg/
Overall I am quite happy with it now; before I was ready to scrap it and find some means of acquiring the issues needed to re-build it.
Thought I'd put some pictures up if I can figure it out so everyone can see; thought it high time I contribute here instead of just reading it all!
Cheers,
Tom
#2 Posted : 07 August 2010 20:08:30
thomasmoult
#3 Posted : 08 August 2010 17:24:23
thanks for that magpie,
sorry about the size, have figured it all out now so no more huge pictures!
cheers,
tom
Jack Sparrow
#4 Posted : 08 August 2010 18:03:54
Excellent build, and nice finish!!BigGrin Cool Drool
willie
#5 Posted : 08 August 2010 18:26:46
grapple anchor only used for rockie or coral sea beds useles in sandy bottoms, hand grapples used for catching rigging when comeing alongside smaller than the anchore type so they could be thrown upwardes
daffy09
#6 Posted : 08 August 2010 18:50:06
Hi Tom.
Like the photos of your launch - you've done a good job there!
I see that you've opted for the natural finish rather than painting - option that I'm going for myself but I'm not sure what colour stains to use and there seems to be very little info about this because lots of builders are opting for the original colours.
Could you tell me what colours you are using - it would help me a lot, and judging from your pics, you seem to have found a good combination of stains/varnish.
Cheers and happy building
daffy 09 ( David)
thomasmoult
#7 Posted : 08 August 2010 19:13:56
Hi David,
Thank you very much! I'm finally pleased with the result.
The only parts that are stained are the ribs and the keel. I found a bottle of Colron, in 'Victorian Pine' which is the one I used here. The outside planking, and the internal deck boards are just varnished with matt.
Hope this helps,
Tom
daffy09
#8 Posted : 08 August 2010 21:47:03
Thanks Tom, that helped a lot.
I'd tested vaious shades of oak on the internal structure of the main build,(where it wouldn't show once the planking is on), but the results were less than satisfactory. I was looking for the rich dark wood colour which you achieved on your launch. Your idea will be very handy when it comes to the alternating light and dark shades on the main hull of the build.
Thanks again
David (daffy 09)
thomasmoult
#9 Posted : 08 August 2010 22:03:01
No worries David BigGrin
The hull was double planked; first with the supplied material, and then I went over it with some strips I have here, I *think* they are mahogany as they go quite dark when varnished.
The 'Victorian Pine' staining worked well for the internal ribs, however I think it has something to do with the type of wood the ribs are made from; I've used the stain on other wood (shelves etc) and it comes out very light. For some reason on the ribs for the launch it went much darker, maybe because it absorbs more or something? I did do several coats aswell.
Hope this helps!
Best wishes,
Tom
Spot
#10 Posted : 11 August 2010 14:23:23
Rank: Newbie
Ah! Double planked - that accounts for the darker colour but no stain. Anyone any advice on how to obtain that colour on the outside without double-planking pls?
ajbird74
#11 Posted : 14 August 2010 17:52:54
Tom
A great build -well done.
I'm about half way through my launch but come to standstill as I also do not like the supplied grating. the magazine has a grating with an edge which looks better but the supplied etch is just not right. Like your idea of planking instead so may have a go with this option soon.
Enjoy your build.
AJB
