27 Pages «<1112131415>»
George1 Build Options
George1
#241 Posted : 08 June 2014 03:12:47
Martyn Ingram wrote:
BigGrin Lovely work there George well done ThumpUp Rgd Martyn
Hi Martyn. BigGrin
Your kind comments very much appreciated. Cool Cool
George
Building HMS SOTS
George1
#242 Posted : 12 June 2014 06:06:02
Issue 14 came today re 2nd Deck.BigGrin Instructions re launch already done previously.
First pic removing waste section of backboard as per instructions.
Second pic gluing down 2nd Deck.
Third pic cannon chambers painted black as per instructions.
Note in pic one rib frame broken second from stern. Had broken prior and glued OK, but got caught in jumper while fitting 2nd Deck. Now re-glued OK. Will reinforce once I know where other fittings above 2nd Deck go. BigGrin
George
Building HMS SOTS
bb1949
#243 Posted : 12 June 2014 07:46:18
BigGrin Hey looking good. How did you stabilize this. I can see brackets either end but curious about how you did the centre. I was thinking about cutting a chunk out of my big jig and simply slotting the whale in there. Looking at what you did makes me think again. Any way well done with the progress.Cool LOL
George1
#244 Posted : 12 June 2014 09:58:01
Hi Brex. BigGrin
Thanks for compliments appreciated. Cool Cool
Re your query. If you check back on my "Dead Whale" pic you'll see where I left recess slots for the brackets where any infills otherwise would have covered. That so I could use bracketed base board as long as possible. BigGrin
Now that you have full infill you won't get any warping or twisting of keel so one way you could do it if recessing into infills now a little difficult is to just remove the two/three centre angle brackets and rely on the end brackets which are clear of infills to hold upright for you. With the infills it sits pretty good anyway.BigGrin
Shortly I will make up clamp set up re Andy's URL before planking starts on bottom. Then bracketed base board no good anymore. Eventually when more top decking after planking I'll either purchase a cradle as UK distributor has or make something up to hold stable. BigGrin
George
Building HMS SOTS
#245 Posted : 12 June 2014 10:04:03
George1
#246 Posted : 12 June 2014 10:21:17
stevie_o wrote:
Nice work George, coming along nowBigGrin Those ribs glue back on good as new so nothing to worry about there.
Hi Steve.BigGrin
Thanks for looking in and your kind comments. Appreciated greatly. Cool Cool
Yes, re the broken rib. Have glued on again and when dry will give another coat of glue over the break. Maybe reinforce later if room to do. BigGrin
George
Building HMS SOTS
jonny7england
#247 Posted : 12 June 2014 10:41:01
Hi George..Great work mate!! The rib that was broken is exactly the same as mine, same rib same place!! With mine, I noticed that there were no gun ports in that area, so I carefully removed 2mm of decking either side of the broken rib and slipped in two pieces of scrap wood (from the dye frame that the rib came from with that issue)down either side of the break, clamped them until the glue dried over night, and when it came to the planking, ensure that that rib had a double dose of glue between plank and rib all the way up..it is now solid!! Sorry for the long tip on how to get around the problem but it worked for me!!
Smile ThumpUp
George1
#248 Posted : 12 June 2014 10:51:41
Smile ThumpUp
Hi Jonny BigGrin
Thanks first for the compliment. It is as always greatly appreciated. Cool Cool
And thank you for the tip regarding the rib break and how to fix permanently. I wasn't sure what may have gone there re parts, but you've cleared that problem up for me so again greatly appreciated. Cool Cool
I'll get on to it and still have all the dye frames in a pile as I did consider some might come in use sometime. BigGrin
George
Building HMS SOTS
bb1949
#249 Posted : 12 June 2014 14:00:36
Hi George, You are right, the reference to Moby Dick may raise some ire so I'll refrain from the word whale. It (the not to be mentioned sea mammal of large proportions) sits nicely on the dock with the bow and stern restrained. Stability is fine and much more than I expected.
Sorry to hear of the broken rib though. By the sound of it J7E's suggestion will do the job. Lucky there was no gun port! Blink
Great work by the way.
Brex.
bb1949
#250 Posted : 12 June 2014 14:02:10
Looks like there is a censor at work as I did type the title Moby 'D' right so not sure how this became DancerConfused
George1
#251 Posted : 12 June 2014 15:58:42
Hi Brex. BigGrin
Yes most forums open to public have automatic exchange words for any words someone might consider offensive. Even for those like you used which was acceptable really in your usage. Same word of course can be used in an offensive manner. They usually have a full list of words right or wrong. BigGrin
George
Building HMS SOTS
George1
#252 Posted : 13 June 2014 08:39:04
Made repair recommended by Jonny7England (Thanks Jonny Cool ) on broken off rib frame. Reinforced and reinforcing should not interfere with any fittings. No cannon port this rib frame. BigGrin
George
Building HMS SOTS
#253 Posted : 13 June 2014 09:10:59
jonny7england
#254 Posted : 13 June 2014 11:32:43
Beautiful repair job there George!! My rib broke right at deck level hence I had to cut away 2mm of the deck either side before adding the bracing...A big well done mate!!
Wink ThumpUp
bb1949
#255 Posted : 13 June 2014 11:36:49
Yes I agree. Good to see how to do the repair. Thanks again George.
Brex
George1
#256 Posted : 13 June 2014 14:49:13
stevie_o wrote:
Nice repair GeorgeBigGrin
Hi Steve. BigGrin
Thanks for kind compliment. Cool Cool
Jonny's cure really helped. BigGrin
George
Building HMS SOTS
George1
#257 Posted : 13 June 2014 14:51:24
Wink ThumpUp
Hi Jonny. BigGrin
It's really the results of your imput. Cool Cool
Appreciate the help. Cool Cool
George
Building HMS SOTS
George1
#258 Posted : 13 June 2014 14:53:04
Brex
Hi Brex BigGrin
Hopefully it won't happen again for either of us. BigGrin
Handy to know though if it did. BigGrin
George
Building HMS SOTS
#259 Posted : 13 June 2014 22:41:36
Very well done George, think you are doing a great job on your build and the rib repair is top notch.....Cool Cool .. The thing I find with all these little mishaps is that your learn how to deal with them and it increases your experience in how to avoid them in future build....Cool Cool .. Keep up the great work.... Cool Cool
George1
#260 Posted : 14 June 2014 02:53:20
Hi Alan. BigGrin
Thanks for the kind comments they are as always greatly appreciated. Cool Cool
You are right regarding experiences as we build. They certainly do help overall. The help coming from more experienced builders including yourself is invaluable to us Newbies. Cool Cool
George
Building HMS SOTS
This page was generated in 0.292 seconds.
