19 Pages «<910111213>»
My Build Diary of the Santisima Trinidad Options
#201 Posted : 05 June 2014 23:53:36
BigGrin Hi Martyn
Thanks for looking in,hopefully il be able to build her with the minimum of paint if at all
George1
#202 Posted : 06 June 2014 06:04:18
Hi Andy BigGrin
Will be certainly watching your build with interest. Cool Cool
Looking tops so far. Cool Cool
George
Building HMS SOTS
#203 Posted : 06 June 2014 19:01:15
BigGrin Hi George
Thanks for looking in and your comments very much appreciated
#204 Posted : 06 June 2014 19:11:33
think this is on my wish list good and proper now
#205 Posted : 06 June 2014 19:35:53
BigGrin Hi Jase
#206 Posted : 06 June 2014 20:08:04
Hi Andy,
What a great build this is, love the second planking this looks a bit bigger than the Victory excellent build Andy
Trev.
#207 Posted : 06 June 2014 20:22:56
BigGrin Hi Trev
Thanks for looking in and your comments. The Trinny is not quite as long as the Vic but is a little taller, I think she may look bigger because of the four decks. She is an enjoyable build with the good hard woods included and has gone together without ant major problems.
#208 Posted : 08 June 2014 21:44:27
BigGrin Hi All
Finally the lower planking is doneBlink Drool LOL and as you can see if you use all your offcuts where possible there is a goodly amount of planks left over .
I have sanded back the white upper deck and will start on the lower deck tomorrow when the glue is fully cured.
I have followed the instruction's to do the secondary planking as it was done in a different way to my usual planking method and I must say it worked out fine although I will probably carry on with my usual planking method from now on. There is still some trimming to do around the false keel area at the bow and stern . That just about concludes this month ,more soon
#209 Posted : 08 June 2014 21:51:29
#210 Posted : 08 June 2014 22:24:44
Looking good Andy....
#211 Posted : 08 June 2014 22:31:34
very nice AndyBigGrin Cool
#212 Posted : 08 June 2014 23:01:37
BigGrin Hi Steve
Thanks for looking in and your comments. As for the hull finish im not sure yet the decks have been coated in Danish Oil so I wont be using that on the hull maybe a satin varnish or shellac we will have to see
#213 Posted : 08 June 2014 23:02:43
BigGrin Hi Alan
#214 Posted : 08 June 2014 23:04:14
BigGrin Hi Jase
Thanks for your comments
#215 Posted : 09 June 2014 21:51:38
BigGrin Hi All
The hull has now been sanded back and the edges trimmed back ready for the keel to be fitted.
#216 Posted : 09 June 2014 22:09:36
#217 Posted : 09 June 2014 22:46:59
Hi Andy,
This will look a bit special when finished Andy nice work again.
Trev.
#218 Posted : 09 June 2014 23:15:52
BigGrin Hi Steve
Thanks for your kind words and comments
#219 Posted : 09 June 2014 23:26:14
Looking good Cool
#220 Posted : 09 June 2014 23:27:04
BigGrin Hi Trev
Thanks for looking in and your comments there always appreciated. There's a little more to add to the upper hull before I can get some seal on the wood to bring out the grain and colour.
IF you have a look at Steve's build diary he shows the Triny in front of his Vic build which gives a good idea of the size of both
