Stage 56 help Options
ZING444
#1 Posted : 08 June 2014 02:13:24
I NEED HELP!! I AM INTO STAGE 56 OF THE D51 BUILD AND CANNOT UNDERSTAND THE INSTRUCTIONS REGARDING THE CAB.
AM I TO UNDERSTAND THAT "THE CAB" STAYS" ,ON PAGE 119 OF THE INSTRUCTIONS, IS TO FIT THE CAB TO THE MAIN ASSEMBLY AND THEN TO DISMANTLE IT FOR FURTHER FABRICATION?
OR, CAN I FIT OUT THE FLOOR - FINISH UP ON THE CAB AND WAIT FOR THE NEXT BUILD INSTRUCTIONS WHEN I PRESUME THE CAB WOULD BE ATTACHED TO THE MAIN ASSEMBLY FOR GOOD.
PLEASE ADVISE AND IF THE FORMER IS THE CASE HOW DOES ONE GLUE SO THAT THOSE PARTS THAT ARE TO COME OFF ARE FREE FROM ANY GLUE. THANKS FOR ANY HELP. DON AT ZINGBigGrin
#2 Posted : 08 June 2014 09:01:34
BigGrin hi Don
The part I think that is causing the confusion is the epoxy glue application to stays A and then later the cab being shown unattached.
If you have a look at Mr T's official build the process is explained in a better way than the instructions, essentially the cab is attached with epoxy to stays A at this point and when it is set the screws used to attach the stays A to the floor plate are removed/undone so as to be able to detach the two parts to enable access later
Hope this clears up your problem.
PS. The use of capitals in a forum is regarded as bad form as it denotes shouting, please could you refrain from using capitals in this way in the future,we are here to help if we can BigGrin LOL
