162 Pages «<127128129130131>»
der Gohfelder
#2561 Posted : 07 June 2014 22:03:51
Hi Alan!
Like allways - a great job you made!!! ThumpUp ThumpUp ThumpUp
Regards from Denmark, Bernd
#2562 Posted : 07 June 2014 22:34:17
BigGrin Looking goodCool
#2563 Posted : 07 June 2014 22:57:39
Its taken me quite some time to read your build log, some fantastic work, she is look rather special.
#2564 Posted : 07 June 2014 23:11:06
DJS wrote:
More cracking work Alan, as always a joy to read and see it come together.
Dave
Thanks Dave, appreciate the kind comments..... Cool Cool .. This is a cracking kit to put together and would give it nothing but a 100% recommendation to any potential purchaser... a total joy to build....Cool Cool
#2565 Posted : 07 June 2014 23:12:01
der Gohfelder wrote:
Hi Alan!
Thanks for looking in and commenting Bernd, always appreciated from you.... Cool Cool
#2566 Posted : 07 June 2014 23:12:30
Thanks Andy.
#2567 Posted : 07 June 2014 23:15:15
Thanks for those very kind words Dave, appreciated most sincerely.... Your kind comments make this even more worthwhile.. It was my intention to make the build log as detailed as possible but never in my wildest dreams did I ever think it would grow to the size it is..... Wonder how much more before the final entry is made... time will tell.... Cool Cool .. Thanks again...
#2568 Posted : 08 June 2014 07:04:52
BigGrin Lovely job Alan looking better by the day super work ThumpUp Rgd Martyn
#2569 Posted : 08 June 2014 09:51:49
Thanks Martyn, appreciate you looking in as always.... Cool Cool She is now getting quite weighty with all the bling and there is a lot more to add yet.... Cool Cool
John Passmore
#2570 Posted : 08 June 2014 15:36:01
Hi Alan
She really is looking stunning, I love it!BigGrin
Quick question or 2. I've been looking at your installation of deck 2 (post #261) - are there no pins in that deck as in lower deck? If not, why do the deck support beams need additional support underneath?Confused
Is there a gap between deck 2 and the dummy cannon supports? If there is a gap is it covered up?
I'm putting little wooden block bracings (4mm thick) behind the dummy cannon supports at each rib joint as I'm concerned the glue may not be strong enough by itself once drilling the holes for the cannons commences.
JohnP
#2571 Posted : 08 June 2014 22:40:09
John Passmore wrote:
Hi Alan
JohnP
Thank you John I am happy you like the build and thanks for taking the time to look in..... As for your questions I'll answer as best I can..
It is not necessary to add additional supports under the deck beams but many builders put them in purely as a belts and braces measure... Something dropping onto the deck or maybe a little heavy handedness on the deck itself and the deck supports could crack or snap.. applying the additional supports would help to prevent any accidents of this nature....
There is a gap between the top of the lower dummy gun supports and the second deck.. Don't be concerned about this as when the hull is planked and the gun ports cut out the gap will not be seen... As for the adding of additional bracing pieces behind the dummy gun supports, this is a good idea. The rigors of drilling into these later in the build would prove problematic should the supports give way... the bracing pieces you are putting in will not be seen so go for it....
Hope this answers your questions and should you have any others then please ask away, am here to assist should you need it....
Thanks again..
John Passmore
#2572 Posted : 09 June 2014 01:40:41
Hi Alan
Thank you for your prompt and positive response to my queries (post#2638).
Your advice is very much appreciated and sets my mind at rest.
Kind regards
JohnP
#2573 Posted : 10 June 2014 00:04:19
Hi Alan
Kind regards
JohnP
You are welcome John, anytime..... will be here to assist you if needed....
#2574 Posted : 10 June 2014 08:28:56
Hi Alan,
Great work, good tip about the measurements before fitting the bling bit's.
That will help for those not yet at this stage.
Trev.
Hans
#2575 Posted : 10 June 2014 13:30:06
Way to go Alan, brilliant build and looking better by the day.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#2576 Posted : 10 June 2014 19:03:10
tf64 wrote:
Hi Alan,
Trev.
Thanks Trev, if the tip helps others behind me avoid a potential pitfall then I'm happy.... Cool Cool Thanks again for looking in and commenting...
#2577 Posted : 10 June 2014 19:04:19
Thanks for looking in and for the very nice comments Hans, great to hear from you.....Cool Cool
#2578 Posted : 10 June 2014 20:24:26
#2579 Posted : 10 June 2014 21:14:38
stevie_o wrote:
Simply Beautiful AlanCool
Thanks Stevie, really appreciated.... Will be working on more bling tomorrow but probably towards the weekend before there is an update... Cool Cool
Thanks again and regards
George1
#2580 Posted : 13 June 2014 05:20:42
Hi Alan. BigGrin
It's always a pleasure looking in on your build and seeing what is yet to come for us Newbies. If we can get anywhere near your quality we will be doing exceptionally well. Cool Cool
Great too to pick up your tips as you progress. It will certainly help us avoid the pitfalls. Cool Cool
George
Building HMS SOTS
Guest (5)
This page was generated in 0.339 seconds.
