issue 81 transom decoration Options
jethro
#1 Posted : 07 June 2014 17:35:26
hi gang
just painting the 8 decorations that fit to the transam these are four left and four right as a mirror image and Ive found that I have 3 left and five right being that PA41 has been duplicated and PA37 is missing
im going to get in touch with admin to see if they will send a replacement .I thought Id mention it so you can check yours before you start assembly
best regards jethro
#2 Posted : 07 June 2014 19:11:13
jethro wrote:
hi gang
best regards jethro
Hi Jethro, BigGrin BigGrin
I have just taken my parts for issue 81 out of storage. Opened them up and OMG, they are small parts.
I have then, very carefully checked out the parts in accordance with the official build and it still took me 10 minutes to sort them out.
So, if you have checked it out fully, you then need to contact CS.
They will replace your faulty issue and then you can carry on as usual.
CS will not send out odd parts, but a complete issue, so your problem should be resolved. Cool Cool Cool Cool
#3 Posted : 07 June 2014 23:21:04
well done derek,correct,phone cs on mon morn,should send the pack again.
jethro
#4 Posted : 09 June 2014 08:20:38
thanks guys
Ill give them a ring
This page was generated in 0.148 seconds.
