Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
bb1949 wrote:Hi George. Another accolade!  I must add how much more I am enjoying Friday mornings because I get to check your progress. A big thanks on that too. Great job by the way. Hi Brex. Appreciate your comments thanks. It's getting there kit by kit. Regards George Building HMS SOTS
Hi George, Looks great ! Have enjoyed reading through your progress, especially with the infills. Current Build : HMS SOTS
Hi Kym. Thanks for your comments. Yes the infills are good regarding later planking. Quite a lot of work to do on hull regarding gluing and later sanding of the balsa, but I'd say is worth it. You can also see the planking profile a lot easier too when done Regards George Building HMS SOTS
Lovely work on the infills George, you can now see clearly the shape the old girl will have and think you will agree the hull is now very sturdy...  .. Very well done... Regards Alan
Gandale wrote:Lovely work on the infills George, you can now see clearly the shape the old girl will have and think you will agree the hull is now very sturdy...  .. Very well done... Regards Alan Hi Alan. Thanks for the kind comments they are as always greatly appreciated. Yes, as you told me earlier in the piece the hull with full infill certainly gives the hull strength and sturdiness. I thank you for giving me the enthusiasm in your earlier posts to do it.  A really big benefit also is there can be no warping or twisting with the keel while waiting on planking or while planking. Regards George Building HMS SOTS
 Rank: Pro     Groups: Registered
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi George I've just been looking at your infill work and you've done a great job there I am currently doing infill work and it's all done except the bit right at the stern. I found things a bit awkward between frames 21 and 22 with the transition from convex to concave form. I like the idea of the balsa supports under alternate deck beams, I will copy that! Regards JohnP
John Passmore wrote:Hi George I've just been looking at your infill work and you've done a great job there I am currently doing infill work and it's all done except the bit right at the stern. I found things a bit awkward between frames 21 and 22 with the transition from convex to concave form. I like the idea of the balsa supports under alternate deck beams, I will copy that! Regards JohnP Hi John Thanks for looking in and your kind comments. Yes the infills are a little tricky right at the stern with the change in shape of curvature. We still have another high rib frame to come yet so you might find you'll need even more sanding at the stern once the angle past it can be followed. The deck beams looked pretty flimsy to me just attached by a couple of mm on the ends for a start. That's why the balsa supports every second beam. I might add an odd extra support if I find the joins go to a beam without a support, but won't know till that 2nd decking comes in another two kit's time, I think? Regards George Building HMS SOTS
Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
So hard to not start my own one, only I want to finish a few of my other ships, before I start on her.
I am also doing HMB Endeavour, HMS Victory & HMS Hood as well.
skyfire wrote:So hard to not start my own one, only I want to finish a few of my other ships, before I start on her.
I am also doing HMB Endeavour, HMS Victory & HMS Hood as well. Hi Skyfire . Thanks for looking in. One good thing about not starting yet on the SOTS is you'll pick up heaps of tips and find out any problems we run into as queries on the forum. It will help to make your build when you do start a little less confusing here and there. Regards George Building HMS SOTS
Joined: 03/06/2014 Posts: 14 Points: 42 Location: australia
G'day George. Your build is coming along nicely. Planking can't be far away now. completed builds; Brig Perseverance, H.M.S. Bounty and San Marcos(almost)
mathewp wrote:G'day George. Your build is coming along nicely. Planking can't be far away now. Hi Mathew. Welcome to the forum. I haven't seen your name before so I'm taking it you're a Newbie like me, in particular regards SOTS.  Planking still a little way off yet. Next issue is (14) and 2nd deck so I'm looking forward to that. Also Looking forward to seeing your build when you start on it and as it progresses. Regards George Building HMS SOTS
Hi Brex. If you look in Friday morning to see how I went on issue 13, I'm sorry there's nothing to show as I have already done what the issue instructs some time back re the launch. Only new items are; I've metal primed the oars, anchor and bucket that came in issue 13, but no other instructions other than only to put away till another time.( I couldn't fully paint anyway as colours are some of the four that's yet to arrive). At least the 2nd deck comes with issue 14 so as you can imagine I'm looking forwards to that at least. Regards George Building HMS SOTS
Done some work on the launch anchor (tiny), finished, Oars as far as can go brown shafts only without ivory paint till it comes, will paint ends black where held by rower. Bucket metal primed waiting for to dry.   Regards George Building HMS SOTS
Joined: 27/02/2014 Posts: 149 Points: 456 Location: Forest Lake QLD
Hi George, I did get a look in late Friday, very late Friday. I must say when I picked up my copy on Thursday I thought 'poor George' what is he going to do now but I knew you would find a way.  I am making progress with the balsa infills but not complete yet. Will add photo to post shortly though  as a progress report.
 Looking good George Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nicely done George, some lovely paint work being displayed there... Very well done.... Regards Alan
 Lovely work there George well done  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
bb1949 wrote:Hi George, I did get a look in late Friday, very late Friday. I must say when I picked up my copy on Thursday I thought 'poor George' what is he going to do now but I knew you would find a way.  I am making progress with the balsa infills but not complete yet. Will add photo to post shortly though  as a progress report. Hi Brex. I had a look on your thread and commented. Looks good mate. Can't wait for 2nd deck next. Regards George Building HMS SOTS
arpurchase wrote: Looking good George Hi Andy. Thanks for looking in and your kind comments. Regards George Building HMS SOTS
Gandale wrote:Nicely done George, some lovely paint work being displayed there... Very well done.... Regards Alan Hi Alan. Thanks for the kind comments appreciated greatly. Regards George. Building HMS SOTS
