15 Pages 123>»
steve's build Options
Steve279021
#1 Posted : 04 June 2014 16:18:16
I am a month behind most people as I ordered later but that gives me the benefit of learning from others as they go.
Dodge charger build complete
Steve279021
#2 Posted : 04 June 2014 16:26:52
Stage 1 is complete. I am leaving stage 2 until i get pack 2 as I will assemble the front wing after I have glued on the end plate skids. Stage 3 which is mainly the disc and caliper I have done but will post a pic after I have done the wing.
DJS
#3 Posted : 04 June 2014 18:17:53
Nice to see another build in progress.
Dave
#4 Posted : 04 June 2014 18:51:37
Good start and congrat's on your first medal Cool
Steve279021
#5 Posted : 20 June 2014 07:56:07
Pack 2 has arrived now so am finally able to complete stage 2 by attaching the wing skids.
Steve279021
#6 Posted : 20 June 2014 21:53:43
Stage 2 now completed. With the addition of stage 6 skids.
Steve279021
#7 Posted : 20 June 2014 21:55:22
Stage 3 completed ages ago
Steve279021
#8 Posted : 20 June 2014 21:57:06
Now got this lot to contend with. Pack 2, stages 4-7.
#9 Posted : 20 June 2014 22:23:08
Ah I bet your looking forward to it really LOL great start btw and look forward to seeing you progress.
Spencer
Steve279021
#10 Posted : 20 June 2014 22:35:25
It doesn't look too bad. Not to sure about the rear wing, looks a bit tricky
#11 Posted : 20 June 2014 22:43:53
It's a lot less complicated than the MP4/23 rear wing and as long as you take your time and allow the adhesive to cure before trying to finish it in one go then you will have no problems BigGrin
Spencer
Steve279021
#12 Posted : 20 June 2014 23:32:50
What would you recommend for the wing assembly. Abs plastic weld or poly cement?
#13 Posted : 20 June 2014 23:58:06
Me personally, I would use and am using ABS plastic weld (MEK) but this question has been asked of me more than once and I'll keep giving the same answer Flapper
Spencer
Steve279021
#14 Posted : 22 June 2014 19:18:05
Started on stage 4 today
got clutch and engine rear done
Steve279021
#15 Posted : 23 June 2014 20:03:56
Stage 4 completed. Time to crack on with stage 5 now
Steve279021
#16 Posted : 25 June 2014 22:53:03
Done the marlboro decals on the rear wing before assembling . Not come out too bad but not happy with the top of the 'L', the top corner folded under a bit and couldn't retrieve it
Steve279021
#17 Posted : 26 June 2014 23:23:23
Tonight's progress
#18 Posted : 26 June 2014 23:25:30
Coming along nicely Steve Cool
Spencer
Steve279021
#19 Posted : 27 June 2014 11:01:33
Thanks Spencer. For anyone following some advise would be to glue the main wing to the end plate on its own and when that's dry glue on the lower flap after and then glue the little silver joint on afterwards. This way you can make sure the ends where they glue to the end plate will be level if that makes sense.
Steve279021
#20 Posted : 29 June 2014 09:58:27
Stage 5 is now complete. Rear wing not as difficult as I thought.
15 Pages 123>»
This page was generated in 0.190 seconds.
