19 Pages 123>»
Gibbo's DelPrado Victory Build Options
Gibbo
#1 Posted : 04 June 2014 02:17:13
As a kid i used to build plastic kit Airfix model aeroplanes, and come November put bangers in them and chuck 'em out of the top window of the house, all good fun, then in my early teens built an Airfix kit of the Victory and again in my early twenties which my kids duly wrecked a few years after that so i haven't done any modelling for years(they're a lot older now), then i saw this advertised and thought i'll have a crack at that, so i started building and put together the ribs, decks and gunports then forgot about it for what must be nigh on ten years, so this was the stage i was at when i started building again.
#2 Posted : 04 June 2014 11:36:16
hi and welcome.if you re-size your pics to 800x600 or 600x 400 they will show on the page, good luck.BigGrin
#3 Posted : 04 June 2014 12:38:31
Hi Gibbo.
Good to see you up and running!BigGrin
That brings back memories, a nice and clean start there (and an interesting choice of dry dock alignment!!Blink ) I didn't use the plywood hull sections on mine and planked the entire hull, using the plywood panels as templates for the gun ports. I then found that the single planking layer just didn't look thick enough through the port so I then added another layer on the inside which improved it no end. If you haven't got there yet I'd recommend planking the inside of the plywood panels and then cutting out the ports, (it'll be much easier than my 'retrospective' planking was, it was a nightmare getting in there once the decks were on!!Crying )
Looking good!
Robin
#4 Posted : 04 June 2014 14:17:00
Gibbo
#5 Posted : 04 June 2014 14:58:52
Hi karl
Is that resizing the pixels or the percentage in the resize box ?
Thanks
Paul
#6 Posted : 04 June 2014 18:19:22
pixels matey.BigGrin
Gibbo
#7 Posted : 04 June 2014 18:51:45
OK, hopefully this comes out as a picture instead of a file, some of the gunports supplied were a funny shape, narrow at the front and wider at the back so i had to pack it out a little bit with a cocktail stick until the glue dried, the instructions were a bit hazy on this, ie: glue them into the slots, after they came out twice igot the dremmel out and had to re-cut the slots make them deeper and change the angle of some but finally got there.
Gibbo attached the following image(s):
Gibbo
#8 Posted : 04 June 2014 19:04:07
Thanks Karl, worked a treat
#9 Posted : 04 June 2014 19:08:57
Congrat's on your first medal Gibbo Cool
Gibbo
#10 Posted : 04 June 2014 19:14:27
Hull nearly fully planked, as you can see thre is a slight twist on the bow section, not surprising as its been sitting on a window sill through winter and summer above a radiator for the last ten years
Gibbo
#11 Posted : 04 June 2014 19:14:48
Gibbo
#12 Posted : 04 June 2014 19:18:22
Hull fully planked filled and sanded.
Gibbo
#13 Posted : 04 June 2014 19:23:09
Gun ports cut out and and hull veneered, quickly playing catch-up on some of the pictures i've taken.
Gibbo
#14 Posted : 04 June 2014 19:28:07
Hull primed ready for some paint
Gibbo
#15 Posted : 04 June 2014 19:36:51
Hull painted, going to copper plate from the waterline down courtesy of Plymouth57's build of this particular model, this is where i am at the moment, just started working on the galleries at the stern.
Gibbo
#16 Posted : 04 June 2014 19:37:50
Thanks Mr T.
#17 Posted : 04 June 2014 20:18:10
Cor! Doesn't she look different in white!Blink
Coming along really well, I'm surprised I didn't have any warping actually, she spent a few years up in the attic where it regularly topped the 100F in the summer!BigGrin
Robin
#18 Posted : 04 June 2014 20:38:31
Gibbo
#19 Posted : 04 June 2014 21:19:44
stevie_o wrote:
Fantastic work Gibbo, youve certainly done a fair bit in one eveningLOL BigGrin LOL
Seriously though, very nice work.
Thanks Steve should have the masts on,rigging done, sails up and drinking rum on the high seas by morningBigGrin
Gibbo
#20 Posted : 08 June 2014 03:26:53
This is the original stern metal backplate that came with this kit, the instructions said just stick it on it doesn't need painting, i think it was an afterthought as the kit was being produced
19 Pages 123>»
This page was generated in 0.452 seconds.
