rear wing Options
Steve279021
#1 Posted : 27 May 2014 23:18:19
How are people finding the rear wing. Someone mentioned it was a bit tricky so was wandering what everyone else thinks. I have not received pack 2 yet so don't know myself.
Dodge charger build complete
only1ianuk
#2 Posted : 28 May 2014 10:17:57
Personally I found it pretty simple. Much easier than the MP4-23. I did steal someones idea of using a right angle to get it all straight which helps.
Steve279021
#3 Posted : 28 May 2014 11:39:09
how did you go about gluing it. not sure about using the ema liquid as you have to hold the pieces in place and let it run into the join and was just worried that the black paint on the end plate would desolve as seems to happen when using the ema.
only1ianuk
#4 Posted : 28 May 2014 12:13:16
I used a cocktail stick to apply a little bit to both contact areas. On the end plate I joined the dots with a thin line and its holding so far.
Steve279021
#5 Posted : 28 May 2014 12:18:31
was this using the ema liquid?
only1ianuk
#6 Posted : 28 May 2014 22:27:14
I may be wrong and I'm sure someone will correct me if it but I used this!
Its held firm for me but as I say not 100% its right.
#7 Posted : 28 May 2014 22:47:06
If it's done the job then who is to say it's wrong Ian BigGrin
Spencer
#8 Posted : 28 May 2014 22:49:12
Anyone who has done the 4/23 rear wing will find this much easier! LOL
Spencer
Steve279021
#9 Posted : 29 May 2014 09:34:54
ok, thanks. pack 2 will be arriving hopefully in a couple of weeks so will keep this in mind, cheers.
mattsr
#10 Posted : 09 September 2015 16:54:00
Spencer
I am just assembling my rear wing and I certainly agree!! BigGrin
I use this glue for most of my assemblies, it's not runny and the needle dispenser makes it very easy to apply in small amounts, avoiding the dreaded overrun:-
http://gshypocement.com/
I've already suffered a glue attack on the nose cone, which required a replacement part, so I'm not taking any more chances!!
This page was generated in 0.246 seconds.
