3 Pages <123>
A Tribute to HMS Illustrious - Some Information required please. Options
#21 Posted : 19 May 2014 08:11:35
Kit looks good Steve I quite fancy this one at some point with the WEM etch it should be stunning and your intent to light will just raise it another lever.
With all the excellent builds the ModelSpace members have built over the years I recon we could win some serous awards at a model showBigGrin
#22 Posted : 19 May 2014 12:06:15
Thanks Jase, I am after a subtle effect with the lights, so I may play with the voltage a little to tone the brightness down if needed - the 12v leds work fine from 5v upward so I will use a variable transformer to see what looks best. A long way off yet thoughBigGrin
The wem etch is still on order as its out of stock but will be on its way as soon as it comes in, cant do a lot without it really.
BTW, you are right about the talent on this forum, you only need to have a browse through the finished builds and there is enough material there to clear up at a model show!
#23 Posted : 19 May 2014 13:30:28
maybe modelspace should put a team togetherCool
#24 Posted : 25 May 2014 14:22:18
#25 Posted : 26 May 2014 13:04:33
The place I got my fibre strand from recommends using a hot knife to cut it, is this nessessary? and if so is this simply heating a scalpel blade?
I know its easy to cut but was wondering if the above method was any better for the light etc, producing a smoother end.
#26 Posted : 26 May 2014 14:00:08
Hi Steve,BigGrin
Glad to see your research and build ideas are coming together nicely.
Cool Cool Cool Cool Cool
Still amazes me how much knowledge is available on this BRILL forum.
Am waiting patiently for this to start, as It`s gonna be a cracker.
If your still after acetate, I bought some on Ebay recently.
A4 in size and very thin, for glass in the control tower of the Lanc build.
Keep the updates and info coming, makes interesting reading.
Happy building
#27 Posted : 26 May 2014 21:08:03
Thank you Del, I am itching to start this one but the WEM etch is still out of stock and will be coming as soon as its back inAngry So, have to wait a while as you know there's not much you can do without the etch as I have no idea how much of the kit will be replaced.
#28 Posted : 26 May 2014 21:54:36
Hi Stevie.
I've never heard of using a hot knife to cut the fibre before, I've always used a safety razor blade in the past without too much bother, you might need a firm surface to cut against though, a cutting mat might be too soft, cracking the fibre but I haven't tried it on one of them myself. As far as the heat goes though, if you bring the cut end of the fibre up close to a candle flame (but not in it!!)BigGrin The heat will cause the tip of the fibre to seal itself into a type of lens which will actually increase the light output. With care, that method will also allow you to feed the fibre through the deck for example, heat the tip and then pull it back down level with the deck where it will form the lens in the deck itself. (Practise with scrap fibre and plasticard is highly recommended!Blink )
Best of Luck!
Robin
#29 Posted : 26 May 2014 22:07:36
Brilliant Robin, that's what I wanted to hearBigGrin I guess they say to use a hot blade for the same reason as you suggested, I prefer your way though. BTW, what is a safety razor blade - I thought safety razors were the ones that you cant get at the blades?
#30 Posted : 26 May 2014 22:44:32
Lol razor blades are safety razors, they got their name as marketing to get people to by razor blades rather than using a cut throwt Modern razors are just a small strip sharpens with wire brushes
#31 Posted : 26 May 2014 23:07:17
Ha! nice one Jase!BigGrin
Here you go Stevie, modern razors are called safety razors because as you said, you can't get at the blades but the blades they hold (apart from the modern disposables) are very thin double sided and razor sharp (naturally!BigGrin )
A 'Safety Razor BLADE' on the other hand is much thicker and only single edged with a blunt strip to use as a handle on the other edge, hence the 'Safety' aspect.
I use these either as they are or else contained in a metal retractable housing which gives greater control, either as a cutter or as a scraper.
(This is what I use to trim off the flash and perform 'surgery' on the polythene figures in the dioramas, cuts through polythene plastic like the proverbial knife through butter!)Cool
You should be able to get them through a chemist although I bought a box of 100 from a travelling supplier, years ago and I'm still not half way through them!
Brilliant little tools!Cool
Robin
#32 Posted : 26 May 2014 23:10:40
AhhBigGrin Thanks both,
I was getting confused between safety razor and "disposable" razors, I know what you mean now, the old fashioned razor blades!
I was trying to imagine how you cut fibre with a disposableLaugh
#33 Posted : 05 June 2014 09:03:23
Have you seen this 1/96 RC version..
1-96 HMS Illustrious.jpg (399kb) downloaded 33 time(s).
#34 Posted : 05 June 2014 13:00:31
That has to be about 6' long!
Good news is my etch arrived todayBigGrin I'm very happy with it too, never seen an A4 sized sheet before, 3 sheets in total so I can begin my build after a lot more reading of course, there is a very detailed 12 page book with it.
I have dabbled in etch before, 1/35 scale mainly but this is going to be a whole new experience for me.
Any tips welcome on here please, mainly would I be better off cleaning and priming the sheets as they are now in one piece or cutting them down to smaller sections as needed?
#35 Posted : 06 June 2014 14:17:35
Very nearly ready to get going with this. I had some bits and bobs arrive recently and am now fully kitted up (well nearly)
I plan to do some light, very subtle weathering on Lusty, nothing major. It will be hard for me knowing when to stop as it's very easy to get carried away with rust and grime etc.
The pics below show 3 different states I can aim for, The first very clean, the second with lots of rust on the anchor, grime and salt and the 3rd is a kind of in between, it's the last pic that I will be aiming for, slight rust, grime and a few salt streaks too.
There was a time years ago when I would make up the washes and effects but as I've got older I have also got lazierBigGrin
The AK interactive effects are fab, I have a few already like rust streaks, oil etc but I saw that there is now a range of naval effects so I thought Id give them a go.
They are sold in 2 packs of 3 but I thought Id just get one to try out first so got the grime streaks for light grey ships, I will also be getting the salt streaks too as this can also be used on the flight deck.
They do seem expensive but so much easier when it's all done for you and they last foreverBigGrin Here's the one that just arrived -
Any more suggestions welcome, especially on the previous post (etch cleaning etc)
#36 Posted : 06 June 2014 15:17:30
This PE link might be of interest to you and others.
http://www.scalemodelgui...to-etched-parts-models/
As for cleaning, I tend to use isopropyl alcohol
#37 Posted : 06 June 2014 19:24:23
#38 Posted : 06 June 2014 19:45:40
Etch looks great i have used WEM etch a lot over the years and the only word of caution i have is that they tend tone at the larger end of the scale scale LOL LOL
The AK wash is great you may also want to consider their sea salt for ships wash and wash for grey decks. Also if you want a real master class on how to apply it
see this its brilliant
http://www.scalemodelsho...tml?utm_source=googleps
really looking forward to you starting on this, hop my Etch advice is helpful
Jade
#39 Posted : 07 June 2014 10:48:20
Thanks Jase, I have ordered the AK salt and deck wash too. Looking at your etch advice I think I will wash and prime the whole sheet first then, really thought it would just crack off when the etch was bent though?
#40 Posted : 07 June 2014 13:35:46
Short answer is yes it could. Personally i would not clean and prime until you need too, its amazing how much oils from fingers and work surfaces etch can pick up and you will be coming back to the same etch fret many times over the build.
I find it easier to clean prime and sometimes paint items like railings, ladders on the fret if there is no or little manipulation of the part needed. But for anything that needs more complex curves or folds better to form it first in my view. If the etch is part of a bigger assembly that is all one colour then i tend to prime and paint as part of the assembly.
I am guessing that much of your etch on this project can be painted with the main assembly as its largely all one colour.
Only other tip from me is spend plenty of time comparing your kit and etch instructions. mark up where you are using etch on the build instructions and you decide where you are pre painting and mark up on the etch instruction.
Final thing... Have you stated yetDrool Drool Drool Drool Drool Drool Drool Flapper
Guest (10)
3 Pages <123>
This page was generated in 0.320 seconds.
