stevie_o wrote:Looking good Andy, coming on very nicely! Steve Thanks Steve
Beautiful work Andy, she really does look a dream...  .. Very well done... Regards Alan
Hi Andy the sunlight does do all the detail justice  great build Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Stunning work, especially the outdoor shot, looks perfect even in daylight. Steve
Fantastic work Andy  she looks fabulous. Kind Regards Nigel
Gandale wrote:Beautiful work Andy, she really does look a dream...  .. Very well done... Regards Alan Thanks a lot Alan
MWG wrote:Hi Andy the sunlight does do all the detail justice  great build Kind regards Mike Thanks Mike, we live in a very old house with small leaded windows and 2ft thick walls and the light's terrible, particularly for photography. So an outside shot is essential to show anything off to it's best. Still there's so much dust in old houses the wife doesn't notice the sawdust
stevie_o wrote:Stunning work, especially the outdoor shot, looks perfect even in daylight. Steve Thanks Steve
NMBROOK wrote:Fantastic work Andy  she looks fabulous. Kind Regards Nigel Thanks Nigel, can't hold a candle up to yours, but I'm pleased with the results so far.
 Nice clean work Andy  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote: Nice clean work Andy  Rgd Martyn Thanks very much, Martyn
 Hi Andy your pic,s seam to have gone awol probably just a silly mistake somewhere but im sure you would like everyone too view your endeviours regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Andy your pic,s seam to have gone awol probably just a silly mistake somewhere but im sure you would like everyone too view your endeviours regards Andy  Everything seems OK at my end
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
If it helps...I can still see them....so would imagine you may need to clear your cache Andy....it used to happen to a mate of mine back when I was running a gaming clan website. Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
I have returned to the SOTS after working on a couple of other model projects and some other stuff which I won't bore you with. So here is an update on my progress, although I'm now a long way behind some other builders. My first problem was the cannon ports as I had used the 5mm wide strip and this protrudes 3mm inside, this is only a problem on the 10 ports on the lower deck. What I decided to do was remove the linings completely and cut them down to 2mm then primed and sprayed them to match the outside. I then pre painted the bulwark lining strips, fitted them and trimmed out the ports before the port linings were refitted to the holes. Meanwhile I planked the deck with 3mm tanganyika in a 3 butt shift pattern. This and the size of planks was chosen to match the decking plans in Endsor's The Restoration Warship. The caulking was added with felt pen, except on the butt ends where I used a 6B pencil to avoid seepage. The treenails were done using a 0.1mm drawing pen. Next the two gratings were fitted, these are made from 2 Caldercraft 39mm gratings joined in the centre. These have 1.5mm holes, whilst this is still a little large they do still give some visibility and sense of the depth beneath which I feel is lost with anything smaller. I surrounded them with mitered 3mm walnut and hid the joint, which was still slightly visible, with a 2mm strip. I have now started on the next 2 decks.
Hi Dominic, Thanks for your nice comments. The answer to your query is neither is correct by the instructions as the gratings officially have no cross members. So in fact you are correct. Mine is there partly because I joined 2 smaller gratings together.
Hi Andy, great to see you back on the SOTS build....  .. Lovely work, hope to see the next episode fairly soon.... Regards Alan
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Andy, Welcome back, build looking excellent. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
