27 Pages «<910111213>»
George1 Build Options
George1
#201 Posted : 25 May 2014 03:46:10
Nice looking work George, very well done.... Think you will now find the hull feels very solid plus the added advantage of doing the infills is you can now see clearly how the hull profile will look..... Cool Cool .. Keep the pics coming....
Hi Alan BigGrin
Thanks for your kind comments they are always appreciated.Cool Cool
Yes The whole keel now feels very solid and rigid too. It's certainly not going to go out of shape as planking starts. And as you say the hull profile easy now to see.BigGrin
George
Building HMS SOTS
George1
#202 Posted : 25 May 2014 03:58:31
bb1949 wrote:
Wow! You have moved on! Well done! I intend to do the infills as well over the next two weeks. Bow is done and I will work to the stern, alternating each side just in case I twist the keel. I think that shouldn't happen given the deck is in place but it is still humid over here and there is always that chance.Crying Unsure
Did you have any issue with glue line. I find it can be an effort to get an even finish between the softer balsa and the rigid glue. I use PVA what do you use.
Brex
Hi Brex.BigGrin
Re moving on quick. Don't forget I'm retired so have a lot more time on my hands than you do as a working guy. BigGrin
Re the glue lines between balsa. I used PVA, Yes the lines are harder between the balsa, however if you judge the waste profile re the rib frames and go much lighter on glue outside that profile it helps to overcome that problem. So long as the balsa inside of the rib profile is glued there shouldn't be a problem. Fit the pieces of balsa tightly and even if no glue on top surface they still sand off blending to one piece overall. Plus the balsa is going to be covered with planking so providing the sanded profile is correct it's not going to be seen anyway,BigGrin
Hope that's of some help. BigGrin
George
Building HMS SOTS
jonny7england
#203 Posted : 25 May 2014 12:30:22
A very nice job with the infills George..Well done mate!!! Wink ThumpUp
George1
#204 Posted : 25 May 2014 12:41:53
Hi Jonny. BigGrin
Thank you for kind comments. They are as always greatly appreciated and give one a boost of confidence. Cool Cool
Thanks for looking in. BigGrin
George
Building HMS SOTS
bb1949
#205 Posted : 25 May 2014 13:49:22
Hey George thanks for the tip on the PVA which I am using.Tonight I did as you suggested and kept the contact area below where I need to shape the infill. I am shaping the first section past the bow at the moment and it is easier to work.
Are you able to get to Canning (Perth) ThumpUp during the week. If so I can send the book on planking to you.
Brex.
PS My wife reckons I'm near past retiring age so I might as well keep going especially now that I have added the Spitfire to my builds.
John Passmore
#206 Posted : 25 May 2014 15:44:33
G'day George
Just been looking at your balsa infills and it's looking great.
Which method did you use to immobilise the ship?
JohnP
George1
#207 Posted : 26 May 2014 02:32:38
Brex.
Hi Brex. BigGrin
Pleased I was able to help re balsa gluing. Cool
Re book. Unfortunately I've got problems with vehicle at the moment other than very short runs so can't get there and public transport a no go.Crying However thanks heaps for the offer it is greatly appreciated. Cool Cool
Yes. The "Spitfire" was one model of great interest to me. If I had won the contest re Tomick I would have chosen that. BigGrin
George
Building HMS SOTS
George1
#208 Posted : 26 May 2014 02:37:31
John Passmore wrote:
G'day George
JohnP
Hi John.
I just used clamps on rib frames to hold one side then used finished side on bottom braced by heavy weight against frames. This only till I build clamp for planking, painting. BigGrin
George
Building HMS SOTS
bb1949
#209 Posted : 26 May 2014 12:02:57
Brex.
Hi Brex. BigGrin
George
Ok sorry to learn about the car. I do get to Perth on the odd occasion so I will let you know and go from there.
George1
#210 Posted : 27 May 2014 15:18:57
Thar' she blows! BigGrin
Hull full infill. I'm glad it's done other than maybe some more sanding stern when next rib frame comes and angle known. BigGrin
At the risk of being called a heretic it looks like a dead whale upside down now. Laugh
George
Building HMS SOTS
#211 Posted : 27 May 2014 15:53:10
Hi George, BigGrin
The balsa infills look really good, but I`m hoping that in the last pic you put up there is an optical illusion.
Looking from the stern as this pic is, the second rib looks out of line on the left hand side.
You can check this by placing a short straight edge across three/four ribs, it looks like the second rib is inset from the others.
I`m hoping that it`s an illusion, but if I`m right the issue can be corrected, so don`t hit the panic button.
I had the same issue on my build and produced a "know how" on how to correct it.
If it`s wrong, it needs correcting now before you proceed further.
Hope I`m wrong.
AdamHall
#212 Posted : 27 May 2014 15:56:07
That is a cracking piece of work there George.
The fruits of your labour are well rewarded. ThumpUp
BZ.
Adam
George1
#213 Posted : 27 May 2014 16:00:14
delboy271155 wrote:
Hi George, BigGrin
Hope I`m wrong.
Hi Derek.
Looked at your concern and is only photo. Rib is straight on. Also just a little more light one side than other.BigGrin
Thanks for looking in and for bringing it to my attention. It's appreciated. Cool Cool
George
Building HMS SOTS
George1
#214 Posted : 27 May 2014 16:03:52
BZ.
Adam
Hi Adam BigGrin
Thanks for the compliment appreciated.Cool Cool
George
Building HMS SOTS
#215 Posted : 27 May 2014 16:04:46
George1 wrote:
delboy271155 wrote:
Hi George, BigGrin
Hope I`m wrong.
Hi Derek.
Looked at your concern and is only photo angle rib is straight on. just more light one side than other. BigGrin
George
Hi George, Cool
So glad I was wrong. BigGrin
Keep up the good work and keep the pics coming.
George1
#216 Posted : 27 May 2014 16:12:33
delboy271155 wrote:
George1 wrote:
delboy271155 wrote:
Hi George, BigGrin
Hope I`m wrong.
Hi Derek.
George
Hi George, Cool
Hi Derek.BigGrin
I'm glad too. Had me worried. BigGrin
Thanks again.BigGrin
George
Building HMS SOTS
George1
#217 Posted : 29 May 2014 09:11:48
Issue 12 today now put together.BigGrin
Beams for 2nd deck looked a bit flimsy so put a balsa support every second beam.BigGrin
If any ribs look a little off it's only photo. Hard to hold camera steady without a tripod.BigGrin
George
Building HMS SOTS
#218 Posted : 29 May 2014 14:43:26
BigGrin Looking spot on George ThumpUp good job on the balsa infill's rgd Martyn
bb1949
#219 Posted : 30 May 2014 00:12:35
Hi George. Another accolade! BigGrin I must add how much more I am enjoying Friday mornings because I get to check your progress. A big thanks on that too. Great job by the way.
George1
#220 Posted : 30 May 2014 02:50:24
Hi Martyn. BigGrin
Thanks for looking in.Cool Cool
Your comments very much appreciated. Cool Cool
George
Building HMS SOTS
This page was generated in 0.233 seconds.
