Stage 12 Brake Supports Options
crbc54
#1 Posted : 23 May 2014 18:35:25
Dear All,I have been assembling stage 12 and when fitting brake supports to underframe I noticed that both the right one and left one were not at right angles to the frame.First does this matter?and second do they need to be altered using say pliers.I am concerned that if I do this I may break the brass altogether.Can anyone give me some advice.Many Thanks ,CliveConfused
#2 Posted : 23 May 2014 18:50:28
BigGrin Hi Clive
Can you post a picture of the parts in situe so to speak but one thing you could try is swapping them round to see if this improves things
Hope this is of help
#3 Posted : 23 May 2014 18:53:59
They should look like this..
crbc54
#4 Posted : 24 May 2014 12:30:52
Dear Andy and Tomick,Managed to solve problem.I have made the brake supports sit at right angles to frame using a little bit of force using my fingers.Thank you very much for replying.Regards,Clive
#5 Posted : 24 May 2014 12:37:28
BigGrin Glad you got it sortedCool
This page was generated in 0.090 seconds.
