16 Pages «<910111213>»
ARPurchase's build of the D51 Options
Dennis
#201 Posted : 19 May 2014 09:55:06
Hi Andy,
Good to see the use of soldering. Certainly the cab lends itself to the technique.
Dennis
Gary O
#202 Posted : 19 May 2014 13:11:20
Are you soldering with a torch or an iron? I used to do a lot of soldering at Boeing. ..Also have soldered some copper water pipes. I guess one can't mix solder and epoxy methods as heat causes epoxy to soften.
Gary
D51, Senna McLaren. Pocher Alfa Romeo 8C-2300 Monza 1931 1/8 scale. Pocher Lamborghini Aventador white roadster.Tamiya 1/12 Ferrari Enzo. Toyota GT2000.
#203 Posted : 19 May 2014 16:29:58
BigGrin Hi Dennis
Thanks for looking in and your comments , the cab certainly needs to be soldered as a butt joint where it is will never hold with just glue in my opinion
#204 Posted : 19 May 2014 16:38:25
BigGrin Hi Gary
I used a 70 watt equivalent butane gas soldering iron that you can use a solder tip or the tip is removable so there is a flame only. For this I used the flame as I wanted to heat the metal up quickly, I put the solder on the inside and let it flow through the joint my only mistake was using to much solder but it will clean up ok with a little elbow grease.
I got the soldering iron off flea bay there is a wide choice, hope this helps
Gary O
#205 Posted : 19 May 2014 17:26:57
I've been having good luck with the medium thick CA and 30 minute epoxy...of course whatever method is used requires thorough preclean. I wipe parts with lacquer thinner as soon as they come out of the pack...then go over with steel wool or 400 (if it's a glue joint) then wipe with thinner again. Things will get another pre clean prior to etch primer or paint (inside smokebox)
#206 Posted : 19 May 2014 20:27:38
BigGrin Hi Gary
You clean up like I do but without the steal wool bit generally your right about most of the glue joints being well catered for with super glue or epoxy, it was just in this case that I felt solder was the way to go. When you see the parts Im sure you will agree and the solder helps fill the gaps here aswell
#207 Posted : 27 June 2014 17:15:30
BigGrin Hi All
More bits for the cab and cab floor this month and a little to add to the boiler
#208 Posted : 25 July 2014 15:57:09
BigGrin Hi All
More done on the D 51
Added seat backrests, gutters, window frames, roof bars and roof with all its extra's to the upper cab. added the two plates to the lower cab floor and then made up the 1st of the smoke deflectors, painted them and added to the front right hand side.
More soon
#209 Posted : 25 July 2014 16:17:22
Very nice indeed.
Just had my second set of parts so planning to make a start on the next delivery.
Your moving on a a pace with this one and very neatly as well.
Happy modelling
#210 Posted : 25 July 2014 18:25:57
BigGrin Hi Tony
#211 Posted : 26 July 2014 10:46:12
Sweet Andy, in fact very sweet....Drool Drool
#212 Posted : 26 July 2014 19:13:04
BigGrin Hi Alan
#213 Posted : 17 August 2014 19:42:05
BigGrin Hi All
The front pony wheel frame has been added after making up and painting it as has the trailing frame for the rear wheel.
The other smoke deflector after painting has also now been added to the front of the engine.
The cab floor,cab and fire box has now been fixed in position upon the engine but the cab roof has not been permantly fixed as yet. More soon
#214 Posted : 17 August 2014 19:54:18
Very nice continuation of your build.
It really is a monster of a machine and I get at the stage you are on weighs a ton.
Love the weathering on the fire box doors.
Thanks for sharing your updates.
Happy modelling
mark 2
#215 Posted : 17 August 2014 20:10:42
Hi Andy BigGrin .
All i can say is wow your D51 is looking fantastic Love Drool.
A master craftsman.
Best regards.
#216 Posted : 17 August 2014 22:44:25
BigGrin Hi Tony
Thanks for looking in and your comments and your right she is certainly getting heavy now.
#217 Posted : 17 August 2014 22:45:35
BigGrin Hi Mark
Thank you for your kind comments and looking in on my build
#218 Posted : 18 August 2014 00:02:11
#219 Posted : 18 August 2014 19:52:58
BigGrin Hi Steve
I think that you may be right about the box, thanks for looking in and your comments
#220 Posted : 18 August 2014 20:58:59
Great stuff Andy Drool looking very nice indeed and you can get a good impression of how heavy the thing must weigh just by looking at it come together... Superb
Spencer
This page was generated in 0.432 seconds.
