Hi All, This is the start of issue 11. This is the build of the pilot`s harness. The first part to be constructed is the right hand lap belt. Number of parts, seven. Size, take a look.  First parts. Pic 1 Now the folds on these parts have to be very accurate, as they depict straps folded onto themselves and then stitched together. No margin for error, because once folded on this scale of brass I don`t think you`d be able to refold. (These parts are 0.2mm thick) The first result. Pic 2 Things start adding up now, the next parts. Pic 3 Both ends of this strap have to be bent back on themselves, so I put in 90 degree bends, then fitted , continued the fold and glued. Pic 4 That pic shows the first stage of fitting and the next one shows the end result, with the lower buckle fitted. Pic 5 Two parts to be added in the next stage:Pic 6 The smaller part (light stone in colour) has to be bent to fit inside the buckle. Then the Khaki Drab part is fixed behind. Pic 7 Just one more part to add to this strap. So, the final pic of one of four straps. Pic 8 I have taken over an hour, to make sure that the parts above have been assembled to the best of my ability. I am, as always open to comments and/or advise. This type of build is a first for me, so it`s a learning curve all the way. Any of the straps that are a repeat, will be shown in their finished state, as things are obviously duplicated. See you all soon with the next update. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work Del and a great little guide on the harness - now you know how to make these you can throw a few together for your Lanc build Steve
stevie_o wrote:Nice work Del and a great little guide on the harness - now you know how to make these you can throw a few together for your Lanc build Steve Hi Steve, You don`t know how close that is. To come soon, the rest of the harness, control levers, etc. These parts are even smaller than the Stuka. (Due to scale) I haven`t forgot your passion for the Lanc Steve. It`s on it`s way when my work shifts allow a good spell on your favorite of my builds. Look in soon, next big shift break only eight days away. Happy building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, So here we go, Pilot`s harness, (the rest of) Followed by the construction of the rear gunners seat. OMG, would not want to sit on that in a dog fight. So, the continuation of the pilots harness. The left hand lap belt is a less involved version of the right, so will just show a completed pic of the item. Pic 1 Ok, so now the shoulder straps are made. These are made up of similar components, so I will just show stage pics of the construction. Pics 2-4 That is the complete left shoulder strap. The right hand one is the mirror copy, so with both constructed and the two lap belts, here`s the completed harness. Only thing to do is to fit them to the seat, but some painting to do first. Result. Pic 5 As you can see at the top of the shoulder straps, there is bare brass. These parts will be folded through the buckles on the rear of the pilot`s seat. (More on that at a later stage)  . I have completed the rear gunners seat, but that will be an update for tomorrow, as finished a 14 hour shift today and back in at 4am tomorrow. Good night all. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Hi Del Nice work as usual regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Del Nice work as usual regards Andy Hi Andy, Thanks for taking a look and the kind comments Regards delboy271155 Derek COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Cracking build as usual Derek. Just can't believe how small the detail is your having to work with. Peter Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Lovely work on the straps Del Steve
petpole wrote:Cracking build as usual Derek. Just can't believe how small the detail is your having to work with.
Peter Hi Peter, Many thanks for the positive comments. As for the size and amount of detail, this phrase comes to mind. "You ain`t seen nothing yet" There is a shed load of detail still to come. I am obviously privvy to this, as I bought the kit complete (so to speak), but copyright stops me from posting pics of the mag instructions. So, I know what`s coming up and everyone else is in for a good few surprises. Happy building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
stevie_o wrote:Lovely work on the straps Del Steve Hi Steve, Thanks for taking the time to look in. The straps, were a little less daunting than they looked in the instructions. Suffice to say, that when you had to feed a strap, in and out of a buckle you had to use a very gentle touch. Those straps are 0.2mm thick, so if creased in the wrong place, you would have trouble getting them flat again. Will be dealing with the micro belts for the Lanc in the next couple of days. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, So here`s the next installment. Issue 12 "The gunners seat "Rather him than me"  The parts. Pic 1 To construct this the way the instructions show, I`d need to be an octopus. On the grounds that I wasn`t the last time I looked, I fixed it together in a way that worked for me. Now, several of the parts of the gunners seat have to be bent to the correct shape. Some have pre scored bend points and vary in size, others have to be formed in an undefined arc to fit where the instructions show. So, here`s the easy bits. Pic 2 Bring in the hold and fold 5.5, for all of these parts. Pic 3 The next part is shown partly folded, but if you look at the right hand end plate you can see a hole. A matching hole is in the other end, so folding has to be accurate so the micro thin rod fits through without any problems. Pic 4 Having finished the folding this is what you end up with, but the pic is a bit fuzzy trying to show the scale. Pic 5 Next part gets a bit larger (not a lot) and requires folding into a box section, the two free ends being glued together. Pic 6 This is a pic of the parts assembled/formed at this point. Pic 7 It`s at this point that the long brass pins come into play. These form the pivot points of the seat base, they have to be glued to the seat support arms, but not any other parts. I applied glue to the back of the pin head with a toothpick, pulled the pin through the holes to locate the seat arms flat, then moved them gently away and let them set at right angles. Having put a pin in each end of the seat arms for one side (watching for correct orientation of parts/part numbers, you need to form everything up to accept the seat base arms on the other side. Bring in the "OCTOPUS".  Pic 8 It`s now time to get everything straight and fit the lower seat arms on the other side of the seat, to include the straight fitting of the pins and centre rod of the seat base. Pic 9 So with that done, my move was to make sure that everything was straight and square. The next parts start adding to the seat structure. Pic 10 The last pic shows the first disk plate added and the second to the right side. Next the part to the right fits in the middle of the main disc. Pic 11 From here on in,I`m assembling the "basket seat" for the gunner. Pic 12 The part shows the top frame surface of the seat. This is formed into an arc at the back edge. This allows for the lower basket section to be folded and make the main seat section. Pic 13 The lower basket section is a one piece unit that needs a lot of freehand bending to fit the upper rim. Four pins set it square. The curved parts of the lower seat have to be formed to meet the upper frame. Pic 14 When all of the lower basket arms are folded up and stuck in place you end up with this result. Pic 15 This is the inverted pic of the seat panel, as it shows the bend forming required. When you turn it up the right way and fix it to the seat base the final result to this point is shown here.Pic 16 Now there is still a large amount of detail still to add to this seat, but that`s for another day. At this point I would like to apologize for the length of some of these posts, but I think you would miss some, if not a lot of the detail if I cut them short. That`s all for today, Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Hi Derek More nice work on the gunners seat, although it looks very uncomfortable I think you will find that the gunners parachute fitted into the framework and that was his pillow untill bale out or landing. Keep the pics coming and posts as they are they show all you need to see and do regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Derek More nice work on the gunners seat, although it looks very uncomfortable I think you will find that the gunners parachute fitted into the framework and that was his pillow untill bale out or landing. Keep the pics coming and posts as they are they show all you need to see and do regards Andy Hi Andy, Thought that would be the case of the lumpy seat, as the pilot`s seat has the dip, as does a Spitfire pilot`s seat. Wonder if they were granted sick leave if they had "PILES" Hopefully the good work continues in the next issue where one part goes "large"  Issue 13, coming soon. Happy building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Here comes issue 13. Not a lot of work, but does include a large part On the flip side it also includes small parts, nothing new there then. So, here`s a pic of the brass fret. Pic 1 The detail, in this floor plate of the rear gunners position is FAB. Close-up. Pic 2 Ok, sorry that`s the big part, back to the mini parts,  The base of a box section, I think.(more to add later)Pic 3 The previous part gets fully folded and glued shut to form a square. This has four locating lugs to secure to the base plate.Pic 4 So, when the box is closed and glued it`s fitted into the relevant place on the gunners floor. A trim piece is then added and the result is as follows. Pic 5 This is followed by two very small parts that form a pedal lever. Photo not good, must invest in a close-up camera,but here`s the next stage. Pic 6 So, with the lever base in place, the pedal foot plate is added and then followed by a patterned non slip plate. Pic 7 Sorry pic is fuzzy, but Iphone close-up not good. Two triangular parts are added to the floor. Pic 8 The last two parts must be set at right angles to the base plate, as two small parts are added to these prior to being painted and having other parts added. Pic 9 With these parts added, the whole frame and added parts are positioned and stuck to the main air frame. The small parts first. Pic 10 The whole assembly is now added to the air frame. Pic 11 This was a dry fit and just as well as there were a few high spots that needed a very slight filing, to get everything flat. (0.25 mm at worst). That done the final fit took place. Pic 12 Well that`s the end of issue 13. Issue 14, takes on the detailing of the air frame, with the addition of riveted plates for extra detail. The brass fret. Pic 13 For a close-up of the detail. Pic 14 So that`s it for today. At Duxford tomorrow for the D-Day air show, so will update this thread soon and weather permitting put up some pics of the display. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, So, you`ve seen the detailing parts for issue 14. These parts give the rivet detail to the bulkhead between the pilot and rear gunner, plus the bracing plates at other double rib sections. In addition to that, there is also additional detailing for the top rails. The following pics will show the parts and where they are positioned, but where parts are duplicated for both sides of the fuselage, I will say so. The first pic, shows the top plate detail in place between the two sides of the bulkhead. The part has to be slightly curved by hand, so as to fit to the curved surface it has to stick too. Pic 1 The two parts in the next pic, fit to the same bulkhead, but one each side, obvious as to which is which by the cut-outs to fit around the support brackets. Pic 2 Here`s pics of the parts in place. Pic 3-4 That`s the larger parts done, now we go small scale again!! These parts are reinforcement plates for the air-frame and they are duplicated for both sides, so will show one side only. Pic 5 You only have the thickness of the brass frame to stick some of these parts too(0.75mm), so gets a bit fiddly getting these in place.Pic 6 So, with both sides done, we move onto the next parts(also duplicated). These parts are fitted to the frame in the middle of the rear gunner section of the air-frame. Pic 7 It was at this point that I returned to "Google Translate". The part with the open ends is not symmetrical, it has three rivets at one end(either side) and four at the other. So having translated the relevant info, I was no further forward as it don`t tell you anything relevant. So, took magnifying glass to the mag pics and the three rivet end is the lower end of the part. Here they are fitted. Pic 8 At this stage we have eight parts to install. All parts are fitted to the top rail of the air-frame. Four and then two identical and two generic to the relevant side of the fuselage. This is a pic of two of the four parts that are the same and they fit on the top rail, within the forward part of the rear gunners section of the air-frame. Pic 9 Fitted like this on both sides. Pic 10 We then fit the two end rail enhancements. Pic 11 This is another duplicated part , so here`s one fitted. Pic 12 Ok, so that leaves two parts that are not identical. Pic 13 These parts are fitted to the top rail within the pilot`s section of the air-frame. Bit hard to see, so part fitted between the red arrows and alternate part fitted to the other side. Pic 14 So, that`s the end of issue 14, that`s 10% of the build done and only the cockpit built, with still more to come in that section. Here`s the part fret for issue 15. Pic 15 The above parts add more detail to the pilots area of the cockpit and two stringers to the air-frame. Happy building Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking awesome Derek  I've done a lot of etch in my days but I think this would send me over the edge  not saying I wouldn't love to do one some day.. SWMBO permitting! Spencer
Warthog wrote:Looking awesome Derek  I've done a lot of etch in my days but I think this would send me over the edge  not saying I wouldn't love to do one some day.. SWMBO permitting! Spencer Hi Spencer, Thanks for taking a look. Unlike you I`ve had very little dealings with etch, until recently. That said this is etch, on etch, on etch in places, but it`s one infectious build. I can`t leave it alone.(Unless working  ) Happy building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Really fine, fiddly and painstaking work there Derek, think you are doing a cracking job of this one.....  .. Very well done..... Regards Alan
Amazing work Del, this is going to be a lovely finished model Steve
Joined: 23/03/2014 Posts: 185 Points: 545 Location: Essex
Guest (10)
