Gary O's Build Options
Gary O
#1 Posted : 13 May 2014 20:20:49
First..I have decided to paint mine. I know all those shiny brass bits are impressive, but I'd like it to look like the real one. Hope to have the first package by weekend...in the meantime I've been getting together my painting supplies. Badger seems to be the way to for air brushing. They have a wide selection of railroad colours.
I also have a subscription to the Senna McLaren so I can play with those bits in between the loco assembly stages.
Gary O attached the following image(s):
D51, Senna McLaren. Pocher Alfa Romeo 8C-2300 Monza 1931 1/8 scale. Pocher Lamborghini Aventador white roadster.Tamiya 1/12 Ferrari Enzo. Toyota GT2000.
Gary O
#2 Posted : 15 May 2014 18:02:45
Got Pack 1 today!!
Also here is a pic of what I'd like the finished product to look like. I'd even go for some Orient Express decals if I could find some.
#3 Posted : 15 May 2014 22:02:12
BigGrin Hi Gary
Looks like a plan there , one word of advice though the airbrush is it powered by aerosol propellant as the problem they don't tell you is as the propellant runs out the pressure drops and thus makes spraying harder. That's why a good compressor is a must for air-brushing
Gary O
#4 Posted : 16 May 2014 01:56:37
I have a compressor with water separator and regulator....just waiting for a longer braided line to go between the air brush and compressor.
Gary O
#5 Posted : 16 May 2014 13:37:28
I was in a bit of a panic this morning. I thought I had bought a couple of good sets of small screwdrivers....but neglected to see if they actually fit the heads of the screws. I had applied 30 minute epoxy to the ring and inserted it only to find I couldn't drive the screws in. I finally found one that is used for eyeglass screws...before the epoxy started to set!!!
Apologies....I have been forgetting to resize my photos before uploading....I realized that was why they don't show directly. I'll try to remember in later posts.
#6 Posted : 16 May 2014 13:46:57
Hi Gary
Just a quick tip with regard to pic size, if your camera has a setting for "web" or "email" then use this when you take your pics, no need to resize then - that's what I do anywayBigGrin
Gary O
#7 Posted : 16 May 2014 14:24:45
I had thought of that, but then I would have to keep fiddling with my camera settings. Pity the edit feature doesn't seem to let one go back in and edit the images.
#8 Posted : 16 May 2014 22:10:08
BigGrin Hi Gary
Nice start, I download my pics to my PC and edit there before posting
Gary O
#9 Posted : 17 May 2014 13:19:17
All done with 1 thru 8. I painted the spark arrestor before installing, later I'll shoot some more flat black inside. The red stripes on the feedwater tank are masking tape so it will have brass bands on there when it's done. I've noticed that quite a few tanks on the D51 have these brass bands.
mwb
#10 Posted : 17 May 2014 13:29:07
Hi Gary,
Now that is really looking good. You're off to a great start.
#11 Posted : 17 May 2014 21:07:03
BigGrin Hi Gary
Looking great and very neat work
#12 Posted : 17 May 2014 21:48:34
Gary O
#13 Posted : 11 June 2014 23:55:07
Pack #2 done. I did some prepainting prior to assembly.
#14 Posted : 12 June 2014 22:09:51
BigGrin Looking good GaryCool
#15 Posted : 13 June 2014 00:18:32
Kremmen
#16 Posted : 20 June 2014 17:00:56
Wow - clean work! ThumpUp
#17 Posted : 20 June 2014 17:54:04
very tasty, well done.Cool
Gary O
#18 Posted : 19 July 2014 19:19:28
Finally received Pack #3. I'm prepainting any screw together parts.
#19 Posted : 20 July 2014 08:58:08
BigGrin Looking great GaryCool
Gary O
#20 Posted : 21 August 2014 20:39:37
PACK 4 Done
