27 Pages «<7891011>»
George1 Build Options
George1
#161 Posted : 11 May 2014 12:21:17
stevie_o wrote:
Lovely work on the launch George, coming along nicelyBigGrin
Hi Steve.
Thanks for looking in and your kind comments. It is greatly appreciated. Cool Cool
George
Building HMS SOTS
George1
#162 Posted : 14 May 2014 06:34:51
Have cut oar rowlocks on Row Boat and seeing I now have Admiralty Paints I thought I'd try painting the anchor for visual effects. I wasn't going to paint anchors till all ready (4) but I'm pretty sure I will be able to match them all.BigGrin
George.
Building HMS SOTS
#163 Posted : 14 May 2014 19:52:33
BigGrin Coming along lovely there George well done Cool Rgd Martyn
George1
#164 Posted : 15 May 2014 02:09:09
Hi Martyn. BigGrin
Thanks for your kind comments. It is appreciated greatly. Cool Cool
George
Building HMS SOTS
George1
#165 Posted : 15 May 2014 06:20:18
Issue 10 constructed.
Bowsprit dry fit only then put away till after planking.BigGrin
Rest of items being keel strakes have been put away with heavy book on top to keep flat till used after planking.BigGrin
In the long photo of false keel and ribs a lot are dry fitted so not absolutely square as will be when glued. BigGrin
One thing I can't understand is why give us keel strakes in this issue that can't be used till after planking but could have given us some more launch items instead.Confused I understand the strakes are a continuation of the bowsprit but not required for quite some time.
George
Building HMS SOTS
bb1949
#166 Posted : 15 May 2014 09:15:18
Cannot explain the logic for that I'm sorry. However your build is still looking good for your build. I plan to do my bow sprit over the weekend, and I am going to redo the skiff so I have two of them. Right now I have to fly to Sydney but back tomorrow midday.
Until then ,
Brex.
George1
#167 Posted : 15 May 2014 09:39:45
Hi Brex BigGrin
Thanks for compliments.Cool
Did you purchase a second 8 issue ? To make second row boat/ launch/ skiff.BigGrin
Are you intending on putting both on the deck ?
There isn't a second one is there in later issues?
George
Building HMS SOTS
jonny7england
#168 Posted : 15 May 2014 10:21:43
Cracking good work there George..Coming along very nicely!! Wink ThumpUp
George1
#169 Posted : 15 May 2014 11:02:39
Hi jonny7england. BigGrin
Thanks for looking in and your comments as always much appreciated. Cool Cool
George
Building HMS SOTS
MichaelKan
#170 Posted : 15 May 2014 11:10:16
Rank: Amateur Level 1
Looks great George.
I'm seeing nearly all builders go with Balsa infills. It has put me in a quandry.... Do I or Don't I? I think I can plank w/o the infills. It'll just be a very slow, metilculous process which I'm fine with. hmmmm........ I'll be certainly thinking about it until I do it.
Michael
George1
#171 Posted : 15 May 2014 11:22:00
Hi Michael BigGrin
Thanks for compliment. It's appreciated. Cool Cool
Regarding balsa infills SOTS it certainly isn't mandatory. More a help especially at bow and stern if not elsewhere. Also glue will stick to the balsa too as well and helps re laying planks. Of course there is quite a lot of work in doing a full balsa infill as well as a lot of sanding. Some of the older members who have infilled mention that it makes the whole keel area feel really solid. However if you decide to infill more than bow and stern wait till first decking on as no room for rib adjustment into decking slots if hard against balsa.BigGrin
I intend to fully infill once first decking on. BigGrin
Hope that might give you some thoughts.BigGrin
George
Building HMS SOTS
AdamHall
#172 Posted : 16 May 2014 02:39:30
Great work George.
The full length of the ship is now revealled. She certainly takes up some real estate on the workbench.
Adam
George1
#173 Posted : 16 May 2014 02:57:38
AdamHall wrote:
Great work George.
The full length of the ship is now revealed. She certainly takes up some real estate on the workbench.
Adam
Hi Adam BigGrin
Thanks for compliment, appreciated. Cool
Yes the build is getting longer and one starts to get an idea of how big it will be as this part is just the bottom it expands more on top at bow and stern. BigGrin
George
Building HMS SOTS
George1
#174 Posted : 17 May 2014 07:40:59
Hi BigGrin
If any long time experienced members look in can you enlighten me on query below; BigGrin
I noticed one build where the Bowsprit has been infilled with balsa.
Is there any logic for this as there is for infill of false keel?
Confused
Or was it to stop warping of Bowsprit having to be put aside for considerable time re planking. Confused
I have no idea just what is going to be glued to the Bowsprit that is helped by a balsa infill. Confused
If there is a good reason then I have plenty of time at the moment waiting on kit issues to infill the Bowsprit and would do so. BigGrin
Building HMS SOTS
jock
#175 Posted : 17 May 2014 07:57:56
The balsa infill help with the bow planking on ships with buff bows eg. Bounty Endeavor Beagle
Previous builds
Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour
http://jockspage.webs.com/
George1
#176 Posted : 17 May 2014 08:02:59
Hi Jock
Thanks for your input here. Cool Cool
I'll check it out and hopefully be enlightened further. BigGrin
It was an infill on SOTS Bowsprit. BigGrin
George
Building HMS SOTS
#177 Posted : 17 May 2014 11:55:20
George1 wrote:
Hi BigGrin
Confused
Hi George, I didn't make this up until it was required to be attached to the bow... nor did I use any infills for this section.. This pic may help you decide whether to use infills for this area or not..
Hope it helps..
George1
#178 Posted : 17 May 2014 15:13:45
Hi Alan. BigGrin
Appreciate you looking in and your input on this query.Cool Cool
From the pic you supplied I can't see any reason to infill the Bowsprit.
There looks to be "Bling" to go right where bottom of balsa infill would be in the way.Confused
I'd guess and say any balsa infills in Bowsprit would as I guessed be only necessary to stop any warp while waiting for fitting and not needed otherwise. BigGrin
You have enlightened me on this so thanks again, it's greatly appreciated and will save some unnecessary work. Cool Cool
George
Building HMS SOTS
#179 Posted : 17 May 2014 22:41:14
hi, no that particular infill,was a mistake by the builder, he ended up removing it(I think)
#180 Posted : 17 May 2014 23:35:38
George1 wrote:
Hi Alan. BigGrin
George
Hi George, you are spot on.... There is no need to infill this section but I would recommend you store the parts flat until needed and not put them together until you get to the stage of actually fitting to the bow..... Keep doing what you are doing, you are doing a great job..... Cool Cool .. Will be following your progress with interest.... Cool Cool
This page was generated in 0.209 seconds.
