Painting the cannons? Options
blagojevich06
#1 Posted : 13 May 2014 11:04:39
Rank: Newbie
Hi everyone, hope you're enjoying the build so far.
I have a question about painting the cannons - I noticed in the photos that they have black lines along the supports that accentuate the red colour scheme. How do you paint the cannons without painting over these black lines? Is it just a matter of finding a fine enough brush or is there a particular technique?
Cheers!
#2 Posted : 13 May 2014 11:56:30
hi, do you mean the slots on the gun trollys? if so, they are painted red the same as the trollys,it's just that they are slotted and shadow make it look like they are painted.
blagojevich06
#3 Posted : 13 May 2014 12:11:53
Rank: Newbie
Cheers for the reply, but are you sure about that? It doesn't look like it here:
#4 Posted : 13 May 2014 12:59:20
picture not showing, need to reduce to 800 x 600 pixels.
blagojevich06
#5 Posted : 13 May 2014 21:52:35
Rank: Newbie
Strange, I copied it directly from another thread. I'll try attaching it.
blagojevich06 attached the following image(s):
#6 Posted : 13 May 2014 22:12:56
Hi Blag....
It does look as if the lines may be painted in as you say, your best way is to paint the entire carriage in red and once dry use a black or dark brown wash or ink to fill in the lines. Both Citadel and Humbrol do good washes, the Citadel is water based whilst the newer Humbrol ones are enamel but both will do the job. You will need a good quality thin brush, either 0 or 1 would do.
I find that both types sometimes need further diluting to work best.
Post up some pics to show us how you get on!
Best of Luck
Robin
This page was generated in 0.126 seconds.
