I decided to follow Kev's example and limited the carbon decal to the top and bottom surfaces of the steering wheel. Also added some to the paddles and display unit. The after market decal set has some truely microscopic parts Those numbers on the thumbwheels are insane !! RM1 attached the following image(s):
you're nearly there mate, keep up the great work Aidan :D
Thanks Aiden. It feels like I'm running a Marathon but the end is in sight !! Malc.
good things take time my friend. just don't rush to the end and it will be perfect. good luck Malc Aidan :D
I've been trying some stuff with the airbrush and decided to put some heat effect on the pipes. Sprayed with metallic silver and then Smoke. Also opened up the ends (very carefully with a dremel tool) and painted flat blackRM1 attached the following image(s):
I've tried to put a "fluid level" in the brake reservoirs. A brush coat of Tamiya smoke up to a line and then a light dusting with flat white. The Brembo decals finish it off. RM1 attached the following image(s):
No deliveries this year yet but the distributer assures me that SA will get the new stock soon. So it gives a chance to add a few extras like the Carbon decal on the camera mount and black paint inside the cowl. (thanks to kev for the idea)RM1 attached the following image(s):
Looking good Malc  not long before you cross the chequered flag! Spencer
Joined: 01/04/2014 Posts: 2 Points: 6 Location: Nigel
Hi Malc, Great build, did you recieve any issues yet. I'm also waiting for 76, 78 82 83 84 85 received last mag in november
Regards, Martin
Hi Martin,thanks for the kind comment. Like you I'm also awaiting 8 issues. haven't seen anything since last year. I need 55,58,74,77,78,79,80,85. The models at a point where it can't continue at all . The distributors tell me that there are four issues in the post (should be with me next week)but the fact that I've received issue 84 and still not 55 & 58 tells me there's a level of confusion somewhere. If I hear more I'll let you know. Malc.
Hi Malc, thanks for the reply, good news to hear that there is stock again
Martin
Great news At last another delivery. Only 4 more issues to get !! Very pleased to get number 58 at last with the seat belt bits. Looks like the M23 build will go on hold for a while.RM1 attached the following image(s):
Got going again after a couple of months waiting for the missing issues !! Seatbelts sorted RM1 attached the following image(s):
At last I'm able to put some of the major assemblies together. It all seems to fit rather well. ( Once I'd found all those "E" type screws from the previous issues ! )RM1 attached the following image(s):
This week added the tops to the side ducting and put seat temporarily inplace. RM1 attached the following image(s):
Joined: 09/05/2014 Posts: 2 Points: -4 Location: Vaal Triangle
It really is pathetic the way the local supplier handles this. I've been onto them, back and forth, them making promises, but obviously nothing happening. I'm sure they don't know what they're doing...
Hi Zentie, I'm also getting concerned about the last few issues My last email to the suppliers has not got a response and previously they were very good. I've only had four issues this year!! I'll post if I get any better news. Malc
Work done on the rear cowl. The wing section is a bit fiddely and it may be better to bond it when it finally gets attached to the flip-ups.RM1 attached the following image(s):
Still not received the four missing issues !!! Anyway the work continues, really pleased with the overall look RM1 attached the following image(s):
