Joined: 16/03/2014 Posts: 516 Points: 1,563 Location: Perth Western Australia
stevie_o wrote:Lovely work on the launch George, coming along nicely Steve Hi Steve. Thanks for looking in and your kind comments. It is greatly appreciated. Regards George Building HMS SOTS
Have cut oar rowlocks on Row Boat and seeing I now have Admiralty Paints I thought I'd try painting the anchor for visual effects. I wasn't going to paint anchors till all ready (4) but I'm pretty sure I will be able to match them all.  Regards George. Building HMS SOTS
 Coming along lovely there George well done  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote: Coming along lovely there George well done  Rgd Martyn Hi Martyn. Thanks for your kind comments. It is appreciated greatly. Regards George Building HMS SOTS
Issue 10 constructed. Bowsprit dry fit only then put away till after planking. Rest of items being keel strakes have been put away with heavy book on top to keep flat till used after planking. In the long photo of false keel and ribs a lot are dry fitted so not absolutely square as will be when glued. One thing I can't understand is why give us keel strakes in this issue that can't be used till after planking but could have given us some more launch items instead.  I understand the strakes are a continuation of the bowsprit but not required for quite some time.     Regards George Building HMS SOTS
Joined: 27/02/2014 Posts: 149 Points: 456 Location: Forest Lake QLD
Cannot explain the logic for that I'm sorry. However your build is still looking good for your build. I plan to do my bow sprit over the weekend, and I am going to redo the skiff so I have two of them. Right now I have to fly to Sydney but back tomorrow midday.
Until then ,
Brex.
Hi Brex Thanks for compliments. Did you purchase a second 8 issue ? To make second row boat/ launch/ skiff. Are you intending on putting both on the deck ? There isn't a second one is there in later issues? Regards George Building HMS SOTS
Cracking good work there George..Coming along very nicely!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
jonny7england wrote:Cracking good work there George..Coming along very nicely!!  Hi jonny7england. Thanks for looking in and your comments as always much appreciated. Regards George Building HMS SOTS
 Rank: Amateur Level 1  Groups: Registered
Joined: 01/04/2014 Posts: 36 Points: 108 Location: Brisbane, Australia
Looks great George.
I'm seeing nearly all builders go with Balsa infills. It has put me in a quandry.... Do I or Don't I? I think I can plank w/o the infills. It'll just be a very slow, metilculous process which I'm fine with. hmmmm........ I'll be certainly thinking about it until I do it.
Michael
Hi Michael Thanks for compliment. It's appreciated.  Regarding balsa infills SOTS it certainly isn't mandatory. More a help especially at bow and stern if not elsewhere. Also glue will stick to the balsa too as well and helps re laying planks. Of course there is quite a lot of work in doing a full balsa infill as well as a lot of sanding. Some of the older members who have infilled mention that it makes the whole keel area feel really solid. However if you decide to infill more than bow and stern wait till first decking on as no room for rib adjustment into decking slots if hard against balsa.  I intend to fully infill once first decking on. Hope that might give you some thoughts. Regards George Building HMS SOTS
Joined: 17/04/2014 Posts: 99 Points: 303 Location: Perth, Western Australia
Great work George.
The full length of the ship is now revealled. She certainly takes up some real estate on the workbench.
Adam
AdamHall wrote:Great work George.
The full length of the ship is now revealed. She certainly takes up some real estate on the workbench.
Adam Hi Adam Thanks for compliment, appreciated. Yes the build is getting longer and one starts to get an idea of how big it will be as this part is just the bottom it expands more on top at bow and stern. Regards George Building HMS SOTS
Hi If any long time experienced members look in can you enlighten me on query below; I noticed one build where the Bowsprit has been infilled with balsa. Is there any logic for this as there is for infill of false keel? Or was it to stop warping of Bowsprit having to be put aside for considerable time re planking. I have no idea just what is going to be glued to the Bowsprit that is helped by a balsa infill. If there is a good reason then I have plenty of time at the moment waiting on kit issues to infill the Bowsprit and would do so. Building HMS SOTS
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 08/03/2011 Posts: 65 Points: 187 Location: Bendigo Australia
The balsa infill help with the bow planking on ships with buff bows eg. Bounty Endeavor Beagle Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
Hi Jock Thanks for your input here. It's appreciated. I'll check it out and hopefully be enlightened further.  It was an infill on SOTS Bowsprit. Regards George Building HMS SOTS
George1 wrote:Hi If any long time experienced members look in can you enlighten me on query below; I noticed one build where the Bowsprit has been infilled with balsa. Is there any logic for this as there is for infill of false keel? Or was it to stop warping of Bowsprit having to be put aside for considerable time re planking. I have no idea just what is going to be glued to the Bowsprit that is helped by a balsa infill. If there is a good reason then I have plenty of time at the moment waiting on kit issues to infill the Bowsprit and would do so. Hi George, I didn't make this up until it was required to be attached to the bow... nor did I use any infills for this section.. This pic may help you decide whether to use infills for this area or not.. Hope it helps.. Regards Alan Gandale attached the following image(s):
Hi Alan. Appreciate you looking in and your input on this query. From the pic you supplied I can't see any reason to infill the Bowsprit. There looks to be "Bling" to go right where bottom of balsa infill would be in the way. I'd guess and say any balsa infills in Bowsprit would as I guessed be only necessary to stop any warp while waiting for fitting and not needed otherwise. You have enlightened me on this so thanks again, it's greatly appreciated and will save some unnecessary work. Regards George Building HMS SOTS
hi, no that particular infill,was a mistake by the builder, he ended up removing it(I think) Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
George1 wrote:Hi Alan. Appreciate you looking in and your input on this query. From the pic you supplied I can't see any reason to infill the Bowsprit. There looks to be "Bling" to go right where bottom of balsa infill would be in the way. I'd guess and say any balsa infills in Bowsprit would as I guessed be only necessary to stop any warp while waiting for fitting and not needed otherwise. You have enlightened me on this so thanks again, it's greatly appreciated and will save some unnecessary work. Regards George Hi George, you are spot on.... There is no need to infill this section but I would recommend you store the parts flat until needed and not put them together until you get to the stage of actually fitting to the bow..... Keep doing what you are doing, you are doing a great job.....  .. Will be following your progress with interest.... Regards Alan
