162 Pages «<125126127128129>»
#2521 Posted : 11 May 2014 10:57:15
der Gohfelder wrote:
Hi Alan!
As allways - very nice! I like it very much!
Regards, Bernd
Thanks Bernd, appreciate your comments as always... Cool Cool
Best regards
#2522 Posted : 11 May 2014 11:07:57
Chantel36 wrote:
Tonight I painted the dummy gun supports dull black, have given it two coats so far.... Not quite there yet, will give it the last coat tomorrow evening.....Mellow Mellow
Hi
Thank you for your diary of your build. Your diary not only has provided me with much insight but also inspiration to pick up the hobby again after many months of setting aside my build. I am currently on Issue 14 and I have a question with regards to the dummy gun supports. What happens in later builds with the gap between deck 1 and 2 as it seems to be quite a big gap. Do you perhaps have any advice on things to consider before I start the planking process which is I am rather nervous about? I appreciate any advice you can offer or reference to any particular sections within your bild.
Thank you again for taking the time to docomeent your build.
Chantel
Thank you for your kind comments Chantel and it pleases me no end to know my build has given you the inspiration to continue with yours... Am happy to help members in any way I can and will always respond to you should you have a problem or query regarding the SOTS... Cool Cool .. Firstly, don't be too concerned about the gap on the dummy gun supports, where the gaps exist additional supports are added on top of the first supports later in the build... What I would say is when fixing the supports ensure you fix them securely, securely enough to take the riggors of drilling holes into them later to take the dummy gun barrels.... Add additional braces behind the supports if necessary as these will not be seen when you fix the decks into position... Cool Cool .. In addition, I also bevelled the bottom edges of the supports to ensure a better fit...Cool I would also say, don't be overly concerned about planking, follow the instructions, takr your time and you won't go far wrong. I covered planking of the hull quite extensively in my diary and the diary index should help you find the relevant posts... Biggest advice I can give is don't force any plank into position, let the planks lay where they want to go and use tapered planks to fill any gaps....Cool Cool .. There is plenty of information on planking throughout this forum so have a look at other diaries, especially Mr T's Official Diary and of course the know how section of the forum. Good luck with your build and ask away should you have any concerns....
Hope this helps..
#2523 Posted: : 11 May 2014 11:16:32
Coming along nicely Alan Cool
Spencer
#2524 Posted : 11 May 2014 11:18:23
Spencer
Thanks Spencer, appreciate you looking in..
#2525 Posted : 11 May 2014 14:41:39
Hi Alan.
You're really coming along well with those racks and Bitts! A lovely job!Cool
I checked back on that little mock up of the pin rail I did just to see if there was any weakness apparent. The wood I used was left over from the Grimsby and was a dark wood, possibly Sapele, the rail itself was 5.5mm in width, 2mm thick and 31mm long including a 1/2mm set into the posts. The holes I drilled were 2mm which were actually a little oversized, (just happened to be the easiest drill bit to find!BigGrin )
There are six holes across the rail and I tried it to see if it would take any pressure ... if your wood dimensions are anywhere near those above I don't think you'll need to worry! I think either my finger bones or the joint between the rail and the posts would go before the rail did!
I was surprised myself just how strong it was (and with cheapie Poundshop PVA as well!)
The only re-inforcing I would recommend would be to brass pin the posts into the deck planks where you can, that would be the weakest part I think.
Keep them coming, better every time!Cool Cool Cool
Robin
#2526 Posted : 11 May 2014 23:34:23
Plymouth57 wrote:
Hi Alan.
Robin
Thanks Robin and thanks for the reassurance regarding the strength of you modified pin rails.... Although mine are now in place it will seriously be considered for the future builds..... Cool Cool .. Thanks again...
claret
#2527 Posted : 21 May 2014 09:02:45
Hi Alan,
She is coming along a treat. credit to you.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#2528 Posted : 21 May 2014 20:24:37
claret wrote:
Hi Alan,
Claret
Thanks Claret, always appreciate your comments and looking in..... Cool Cool
#2529 Posted: : 21 May 2014 20:41:32
Week 90 now complete... week 89 was simply the supply of 2 cannon kits, cannons I intend to make up later in 2 batches, those for the main deck and then those for the other decks... Cool Cool .. Issue 90 was the fitting of 2 lanterns on each side of the side galleries. 9 Cleats were also fitted but here I found what I believe to be a measurement error.. Instructions say to fit a cleat either side of the quarterdeck parapets 4mm from the front rail... Looking at the mag photos, this shows the cleats in behind the first upright post on the parapet and well away from the front edge of the front rail which is 4mm wide, this just does not work. Positioning of the cleat works out to be 12mm from the front rail and not 4m.. or at least this is where I have placed them Cool Cool .. Finally in this issue, fitted 20 eyebolts in total on the decks, these were first blackened and set in place with superglue gel....Cool Cool .. Looks like issue 91 will just be the fitting of more bling... Happy building all..
#2530 Posted : 21 May 2014 20:57:19
Beautiful Alan! The more bling she gets, the more majestic she looks!Cool
It always pays to double check between the written instructions and the build photos, typing errors are far easier to make than getting the photo wrong in the magazine! Even the DelPrado instructions are a little 'out' now and again!BigGrin If in doubt, go with the photo!
The SOTS book that we both have has become my weekly 'read' in Tescos now, VERY detailed descriptions and a darned good read too! (when I'm not stocking up on wooden stirrers for Messines!Blushing )BigGrin
Really coming on well and looking forward to the next additions! Cool
Robin
#2531 Posted : 21 May 2014 21:00:32
BigGrin looking goodCool
#2532 Posted : 21 May 2014 21:01:32
She looks more stunning every time I see her Cool Cool
Think I have spotted a great display opportunity for you. looks like she will fit in the fish tank, would be good to see her afloat don't you think BigGrin BigGrin BigGrin Blink
#2533 Posted : 21 May 2014 22:16:05
Robin
Thanks for your kind comments Robin, always appreciated.... They do say a picture paints a thousand words and in this case it's very true....Cool Cool .. Went by the pics on the mag so will soon see if it is the right decision.... Cool Cool .. Thanks again....
#2534 Posted : 21 May 2014 22:17:09
Thanks Andy...
#2535 Posted : 21 May 2014 22:20:15
Thanks for looking in and the positive comments Jase, appreciated... Don't think the pics do the build true justice, she looks even better in the flesh.... Cool Cool .. Somehow I don't think this one will ever see water but as for your comment, the fish tank being 6ft would take the Titanic very well, that may be a better option.... BigGrin BigGrin .. Thanks again...
Glebecraft
#2536 Posted : 24 May 2014 10:46:25
Simply stunning AlanDrool your planking of the parapet walls is definately an idea I will steal when I get to that stage.
Graham
Building; Sovereign of the Seas
Collecting; Nelson`s Victory
#2537 Posted : 24 May 2014 11:32:16
Thanks for the kind comments and for looking in Graham, appreciated.. Cool Cool .. You are more than welcome to use any of my ideas on your build... look forward to seeing how you get on...
#2538 Posted : 24 May 2014 22:37:41
For your first build this is looking very nice indeed, good job
#2539 Posted : 25 May 2014 00:59:25
Thanks Dave, thanks for looking in and commenting.... Cool Cool .. The great thing about this for me is the learning process I've gone through to get to this stage.... it's been fab.....Cool Cool
#2540 Posted : 26 May 2014 14:12:50
Hi Alan, BigGrin
Looking Cool as always. Drool Drool
Can`t be long before the rigging start now.
Keep up the excellent work.
Happy building
Guest (11)
This page was generated in 0.448 seconds.
